[petsc-users] Mat indices for DMPlex jacobian
Matteo Semplice
matteo.semplice at uninsubria.it
Wed Sep 25 08:28:34 CDT 2024
On 23/09/2024 17:16, Matthew Knepley wrote:
> On Mon, Sep 23, 2024 at 5:33 AM Matteo Semplice via petsc-users
> <petsc-users at mcs.anl.gov> wrote:
> Dear petsc,
> I need to hand-code a jacobian and I can't figure out how to
> translate the DMplex points/fields to matrix indices.
> My DMPlex has a section with m fields per cell (which makes for
> n>m dof
> per cell since some fields are vector). Say I want to insert an nxn
> block for the row corresponding to cell c and coloumn of its
> neighbour
> d. I guess that I should call either
> MatSetValues/MatSetValuesLocal or
> the blocked variants, but how do I find the row/col indices to
> pass in
> starting from the c/d dmplex points? And, while I am at it, which
> MatSetValues version standard/Local standard/blocked is best?
> I looked for a petsc example, but fails to find it: if there's
> one, can
> you just point me to it?
> 1. In FEM, the main unit of indices is usually the closure, so we provide
> https://urldefense.us/v3/__https://petsc.org/main/manualpages/DMPlex/DMPlexGetClosureIndices/__;!!G_uCfscf7eWS!YwF8ebZtFAZdHXKPu98AWB7KPuScfxMu4dRoe8ZqVaPVoEO_nX_qJa-zS6pOWHnPUs2ME6GB7l_SlHBl8ypyOPOQXzbVSC9xXhd8tw$
> which is what is used inside of
> https://urldefense.us/v3/__https://petsc.org/main/manualpages/DMPlex/DMPlexMatSetClosure/__;!!G_uCfscf7eWS!YwF8ebZtFAZdHXKPu98AWB7KPuScfxMu4dRoe8ZqVaPVoEO_nX_qJa-zS6pOWHnPUs2ME6GB7l_SlHBl8ypyOPOQXzbVSC8i-x5AVA$
> 2. These indices are calculated using the global section, so you can just
> DMGetGlobalSection(dm, &gs);
> and then use PetscSectionGetDof() and PetscSectionGetOffset(), knowing
> that
> off-process values are encoded as -(off + 1), so you need to convert
> those.
> Does this make sense?
Yes! Thank you!
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240925/644174aa/attachment.html>
