[petsc-users] Inquiry about reading an exodus II file from coreform Cubit
neil liu liufield at gmail.com
Sat Sep 21 08:54:32 CDT 2024
Thanks a lot, David. That works.
Then I tried another example from Cubit. The script is defined as follows,
reset
brick x 1
mesh vol 1
block 1 volume 1
sideset 1 surface 1
block 2 surface 1 #sides of these elements can now be referenced in a
sideset
block 2 element type quad
sideset 2 curve 1
Then the mesh was exported as a exodus file (attached), and imported into
Petsc.
Here, the code was stuck by the function, DMPlexCreateExodus().
I think maybe this is due to block 1 is 3D while block 2 is 2D.
But this seems necessary to define an edge using sideset.
Xiaodong
On Fri, Sep 20, 2024 at 3:15 PM David Andrs <andrsd at gmail.com> wrote:
> Before you export the mesh from Cubit, change the element type to
> something like QUAD4. PETSc does not automatically remap SHELL elements to
> QUADs.
> David
> On Fri, Sep 20, 2024 at 8:05 AM neil liu <liufield at gmail.com> wrote:
>> Dear Petsc developers and users,
>> I am trying to read an exodus II file from coreform cubit, but without
>> success,
>> Then I used petsc's built-in exodus file,
>> /share/petsc/datafiles/meshes/sevenside.exo.
>> This file can be read by petsc successfully.
>> And I did a test. This file, sevenside.exo, is imported into coreform
>> Cubit, and then is saved as a new exodus file. This new exodus file can not
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Unrecognized element type SHELL
>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ZpvOEyVekHc8aSibQ_b2zv7q7cr-DxnkTfOTSvDcUuydfpfd6rwcbvH1VRCh3MREIeAyEQ64ZxReP77OQsQN9A$
>> <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fcN-KL0rs3WRHNRfT47zioS4djjyXM7OCr32LT2olmZHm3X1NIk-WMdU9-UR3rNotQSpINEm8NrcMtWTCFqKEg$> for
>> trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.21.1, Apr 26, 2024
>> [0]PETSC ERROR: ./app on a arch-linux-c-opt named localhost.localdomain
>> by xiaodongliu Fri Sep 20 09:36:16 2024
>> [0]PETSC ERROR: Configure options -download-mumps -download-scalapack
>> --with-cc=gcc --with-fc=gfortran --with-cxx=g++ --download-fblaslapack
>> --download-mpich --with-scalar-type=complex --download-triangle
>> --with-debugging=no --download-parmetis --download-metis -download-ptscotch
>> --download-bison --download-hdf5
>> -download-mmg=/home/xiaodongliu/Documents/3rdPartyLib/d5c43d1bcefe598d51428f6a7fee10ec29478b79.tar.gz
>> --download-ctetgen --download-pragmatic --download-eigen
>> --download-netcdf=/home/xiaodongliu/Documents/3rdPartyLib/netcdf-c-4.9.2-p1.tar.gz
>> --download-zlib --download-pnetcdf --download-exodusii
>> [0]PETSC ERROR: #1 ExodusGetCellType_Internal() at
>> /home/xiaodongliu/Documents/petsc-with-docs-3.21.1/petsc-3.21.1/src/dm/impls/plex/plexexodusii.c:1470
>> [0]PETSC ERROR: #2 DMPlexCreateExodus() at
>> /home/xiaodongliu/Documents/petsc-with-docs-3.21.1/petsc-3.21.1/src/dm/impls/plex/plexexodusii.c:1551
>> [0]PETSC ERROR: #3 DMPlexCreateExodusFromFile() at
>> /home/xiaodongliu/Documents/petsc-with-docs-3.21.1/petsc-3.21.1/src/dm/impls/plex/plexexodusii.c:1390
>> Thanks a lot.
>> Xiaodong
>> Compose:
>> [image: Minimize][image: Pop-out][image: Close]
>> PETSc users list
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240921/84f5ee8b/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240921/84f5ee8b/attachment-0001.obj>
