[petsc-users] Residual at the fieldsplit level
Barry Smith
bsmith at petsc.dev
Tue Sep 17 09:49:25 CDT 2024
So firedrake_0 is the object prefix of your SNES object?
> On Sep 17, 2024, at 10:37 AM, miguel.salazar <miguel.salazar at corintis.com> wrote:
> >In my reading, it says
> >Residual norms for firedrake_0_ solve.
> > 0 KSP Residual norm 4.621368953027e+02
> > so the residual in the first (0th) split does correspond to the outer-most KSP residual norm (not printed but equal to the SNES at the first iteration of Newton.
> > It is the residual norm of the first field of the first field that is 1
> >Residual norms for firedrake_0_fieldsplit_0_ solve.
> > 0 KSP Residual norm 1.000000000000e+00
> Is the residual of the outer solve (it is being printed).
> Is the residual of the first field. I am not sure what you are referring to with “the residual norm of the first field of the first field”
> Thanks,
> Miguel
> MIGUEL ANGEL SALAZAR DE TROYA
> Head of Software Engineering
> miguel.salazar at corintis.com <mailto:miguel.salazar at corintis.com>
> Corintis SA
> EPFL Innovation Park Building C
> 1015 Lausanne
> <2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png>
> Here at Corintis we care for your privacy. That is why we have taken appropriate measures to ensure that the data you have provided to us is always secure.
> From: Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Date: Tuesday, 17 September 2024 at 16:24
> To: miguel.salazar <miguel.salazar at corintis.com <mailto:miguel.salazar at corintis.com>>
> Cc: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> Subject: Re: [petsc-users] Residual at the fieldsplit level
> Initial residual: 462.13689530272404
> 0 SNES Function norm 4.621368953027e+02
> 1 KSP Residual norm 3.501082228626e-15
> Residual norms for firedrake_0_fieldsplit_1_ solve.
> 0 KSP Residual norm 0.000000000000e+00
> 1 KSP Residual norm 0.000000000000e+00
> 1 KSP Residual norm 1.612167203819e-12
> 1 SNES Function norm 1.599350481360e-12
> Using the fieldsplit additive preconditioner, the problem converges in a single KSP iteration, as expected. However, I do not understand why the residual of fieldsplit_0 (1e+0) does not coincide with the outer residual (462.13689530272404). It should be the case given that only fieldsplit_0 has a non-zero residual contribution. The fact that it is just 1 is suspicious. Is there something about how the fieldsplit works that I am missing?
> Or am I missing something
> Barry
> 0 KSP unpreconditioned resid norm 4.621368953027e+02 true resid norm 4.621368953027e+02 ||r(i)||/||b|| 1.000000000000e+00
> 0 KSP none resid norm 1.000000000000e+00 true resid norm 3.501082228626e-15 ||r(i)||/||b|| 3.501082228626e-15
> 1 KSP none resid norm 3.501082228626e-15 true resid norm 3.501082228626e-15 ||r(i)||/||b|| 3.501082228626e-15
> 0 KSP none resid norm 0.000000000000e+00 true resid norm 0.000000000000e+00 ||r(i)||/||b|| inf
> 1 KSP none resid norm 0.000000000000e+00 true resid norm 0.000000000000e+00 ||r(i)||/||b|| inf
> 1 KSP unpreconditioned resid norm 1.612167203819e-12 true resid norm 1.589286585800e-12 ||r(i)||/||b|| 3.438995245681e-15
> On Sep 17, 2024, at 1:04 AM, miguel.salazar <miguel.salazar at corintis.com <mailto:miguel.salazar at corintis.com>> wrote:
> These are the new options (with ksp_monitor_true_residual)
> solver_mumps_assembled = {
> "ksp_type": "preonly",
> "ksp_monitor": None,
> "ksp_monitor_true_residual": None,
> "pc_type": "python",
> "pc_python_type": "firedrake.AssembledPC",
> "assembled_pc_type": "lu",
> "assembled_pc_factor_mat_solver_type": "mumps",
> "assembled_mat_mumps_icntl_14": 200,
> "assembled_mat_mumps_icntl_24": 1,
> solver_fieldsplit = {
> "mat_type": "matfree",
> "snes_monitor": None,
> "snes_type": "newtonls",
> "ksp_type": "fgmres",
> "ksp_rtol": 1e-1,
> "pc_type": "fieldsplit",
> "pc_fieldsplit_type": "additive",
> "fieldsplit_0": solver_mumps_assembled,
> "fieldsplit_1": solver_mumps_assembled,
> And this is the output
> The true residual is very low. (3.501082228626e-15)
> Corintis SA
> 1015 Lausanne
> Date: Monday, 16 September 2024 at 19:34
> Try ksp_monitor_true_residual. Let's see if it is an issue of preconditioned vs unpreconditioned residual.
> On Sep 16, 2024, at 1:05 PM, miguel.salazar <miguel.salazar at corintis.com <mailto:miguel.salazar at corintis.com>> wrote:
> Hello,
> I have this simple example on Firedrake to illustrate my point. I am solving for a two-component poisson equation (uncoupled). Only the first component has a non-zero residual.
> import firedrake as fd
> from firedrake import inner, grad, dx, sin, pi
> N = 10
> mesh = fd.UnitSquareMesh(N, N)
> V = fd.FunctionSpace(mesh, "CG", 1)
> W = V * V
> u = fd.Function(W)
> v = fd.TestFunction(W)
> a = inner(grad(u[0]), grad(v[0])) * dx + inner(grad(u[1]), grad(v[1])) * dx
> x = fd.SpatialCoordinate(mesh)
> f = fd.Function(V)
> f.interpolate(fd.Constant(1e4) * sin(x[0] * pi) * sin(2 * x[1] * pi))
> L = f * v[0] * dx
> F = a - L
> bcs = [fd.DirichletBC(W.sub(0), fd.Constant(2.0), (1,))]
> def snes_firedrake_residual(F, u, bcs):
> for bcs_ in bcs:
> bcs_.apply(u)
> residual = fd.assemble(F, bcs=bcs, zero_bc_nodes=True)
> with residual.dat.vec_ro as r:
> print("Initial residual:", r.norm())
> problem = fd.NonlinearVariationalProblem(F, u, bcs=bcs)
> "ksp_rtol": 1e-1,
> solver = fd.NonlinearVariationalSolver(problem, solver_parameters=solver_fieldsplit)
> solver.solve()
> The PETSc output is as follow
> Thanks,
> Miguel
> Corintis SA
> 1015 Lausanne
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240917/8492ffed/attachment-0001.html>
