[petsc-users] Residual at the fieldsplit level
miguel.salazar miguel.salazar at corintis.com
Tue Sep 17 09:37:48 CDT 2024
 >In my reading, it says
>Residual norms for firedrake_0_ solve.
>    0 KSP Residual norm 4.621368953027e+02
>     so the residual in the first (0th) split  does correspond to the outer-most KSP residual norm (not printed but equal to the SNES at the first iteration of Newton.
>     It is the residual norm of the first field of the first field that is 1
>Residual norms for firedrake_0_fieldsplit_0_ solve.
 >     0 KSP Residual norm 1.000000000000e+00
Is the residual of the outer solve (it is being printed).
Is the residual of the first field. I am not sure what you are referring to with “the residual norm of the first field of the first field”
Miguel
MIGUEL ANGEL SALAZAR DE TROYA
Head of Software Engineering
miguel.salazar at corintis.com<mailto:miguel.salazar at corintis.com>
Corintis SA
EPFL Innovation Park Building C
1015 Lausanne
        [cid:2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png]
Here at Corintis we care for your privacy. That is why we have taken appropriate measures to ensure that the data you have provided to us is always secure.
Date: Tuesday, 17 September 2024 at 16:24
To: miguel.salazar <miguel.salazar at corintis.com>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Residual at the fieldsplit level
Initial residual: 462.13689530272404
  0 SNES Function norm 4.621368953027e+02
      1 KSP Residual norm 3.501082228626e-15
      Residual norms for firedrake_0_fieldsplit_1_ solve.
      0 KSP Residual norm 0.000000000000e+00
      1 KSP Residual norm 0.000000000000e+00
    1 KSP Residual norm 1.612167203819e-12
  1 SNES Function norm 1.599350481360e-12
Using the fieldsplit additive preconditioner, the problem converges in a single KSP iteration, as expected. However, I do not understand why the residual of fieldsplit_0 (1e+0) does not coincide with the outer residual (462.13689530272404). It should be the case given that only fieldsplit_0 has a non-zero residual contribution. The fact that it is just 1 is suspicious. Is there something about how the fieldsplit works that I am missing?
   Or am I missing something
   Barry
      0 KSP unpreconditioned resid norm 4.621368953027e+02 true resid norm 4.621368953027e+02 ||r(i)||/||b|| 1.000000000000e+00
        0 KSP none resid norm 1.000000000000e+00 true resid norm 3.501082228626e-15 ||r(i)||/||b|| 3.501082228626e-15
      1 KSP none resid norm 3.501082228626e-15 true resid norm 3.501082228626e-15 ||r(i)||/||b|| 3.501082228626e-15
        0 KSP none resid norm 0.000000000000e+00 true resid norm 0.000000000000e+00 ||r(i)||/||b|| inf
      1 KSP none resid norm 0.000000000000e+00 true resid norm 0.000000000000e+00 ||r(i)||/||b|| inf
    1 KSP unpreconditioned resid norm 1.612167203819e-12 true resid norm 1.589286585800e-12 ||r(i)||/||b|| 3.438995245681e-15
On Sep 17, 2024, at 1:04 AM, miguel.salazar <miguel.salazar at corintis.com> wrote:
These are the new options (with ksp_monitor_true_residual)
solver_mumps_assembled = {
    "ksp_type": "preonly",
    "ksp_monitor": None,
    "ksp_monitor_true_residual": None,
    "pc_type": "python",
    "pc_python_type": "firedrake.AssembledPC",
    "assembled_pc_type": "lu",
    "assembled_pc_factor_mat_solver_type": "mumps",
    "assembled_mat_mumps_icntl_14": 200,
    "assembled_mat_mumps_icntl_24": 1,
solver_fieldsplit = {
    "mat_type": "matfree",
    "snes_monitor": None,
    "snes_type": "newtonls",
    "ksp_type": "fgmres",
    "ksp_rtol": 1e-1,
    "pc_type": "fieldsplit",
    "pc_fieldsplit_type": "additive",
    "fieldsplit_0": solver_mumps_assembled,
    "fieldsplit_1": solver_mumps_assembled,
And this is the output
The true residual is very low. (3.501082228626e-15)
Corintis SA
1015 Lausanne
<2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png>
From: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Date: Monday, 16 September 2024 at 19:34
To: miguel.salazar <miguel.salazar at corintis.com<mailto:miguel.salazar at corintis.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
  Try ksp_monitor_true_residual. Let's see if it is an issue of preconditioned vs unpreconditioned residual.
On Sep 16, 2024, at 1:05 PM, miguel.salazar <miguel.salazar at corintis.com<mailto:miguel.salazar at corintis.com>> wrote:
Hello,
I have this simple example on Firedrake to illustrate my point.  I am solving for a two-component poisson equation (uncoupled). Only the first component has a non-zero residual.
import firedrake as fd
from firedrake import inner, grad, dx, sin, pi
N = 10
mesh = fd.UnitSquareMesh(N, N)
V = fd.FunctionSpace(mesh, "CG", 1)
W = V * V
u = fd.Function(W)
v = fd.TestFunction(W)
a = inner(grad(u[0]), grad(v[0])) * dx + inner(grad(u[1]), grad(v[1])) * dx
x = fd.SpatialCoordinate(mesh)
f = fd.Function(V)
f.interpolate(fd.Constant(1e4) * sin(x[0] * pi) * sin(2 * x[1] * pi))
L = f * v[0] * dx
F = a - L
bcs = [fd.DirichletBC(W.sub(0), fd.Constant(2.0), (1,))]
def snes_firedrake_residual(F, u, bcs):
    for bcs_ in bcs:
        bcs_.apply(u)
    residual = fd.assemble(F, bcs=bcs, zero_bc_nodes=True)
    with residual.dat.vec_ro as r:
        print("Initial residual:", r.norm())
problem = fd.NonlinearVariationalProblem(F, u, bcs=bcs)
    "ksp_rtol": 1e-1,
solver = fd.NonlinearVariationalSolver(problem, solver_parameters=solver_fieldsplit)
solver.solve()
The PETSc output is as follow
Miguel
Corintis SA
1015 Lausanne
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240917/cd4e1d0e/attachment-0001.html>
Name: 2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png
Type: image/png
Desc: 2024-08-1609_02_11-re_mailmigrationfromgoogletooffice365-sebastien.gobel at corintis.com-co_4456a1bf-dd3e-46b7-85f9-21f278e66a79.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240917/cd4e1d0e/attachment-0001.png>
