[petsc-users] [MPI GPU Aware] KSP_DIVERGED
Satish Balay
balay.anl at fastmail.org
Mon Sep 16 11:57:02 CDT 2024
And/Or - try latest OpenMPI [or MPICH] and see if that makes a difference.
--download-mpich or --download-openmpi with latest petsc should build gpu-aware-mpi
Satish
On Mon, 16 Sep 2024, Junchao Zhang wrote:
> Could you try petsc/main to see if the problem persists?
> --Junchao Zhang
> On Mon, Sep 16, 2024 at 10:51 AM LEDAC Pierre <Pierre.LEDAC at cea.fr> wrote:
> > Hi all,
> > We are using PETSc 3.20 in our code and running succesfully several
> > solvers on Nvidia GPU with OpenMPI library which are not GPU aware (so I
> > need to add the flag -use_gpu_aware_mpi 0).
> > But now, when using OpenMPI GPU Aware library (OpenMPI 4.0.5 ou 4.1.5 from
> > NVHPC), some parallel calculations failed with *KSP_DIVERGED_ITS* or
> > *KSP_DIVERGED_DTOL*
> > with several configurations. It may run wells on a small test case with
> > (matrix is symmetric):
> > *-ksp_type cg -pc_type gamg -pc_gamg_type classical*
> > But suddenly with a number of devices for instance bigger than 4 or 8, it
> > may fail.
> > If I switch to another solver (BiCGstab), it may converge:
> > *-ksp_type bcgs -pc_type gamg -pc_gamg_type classical*
> > The more sensitive cases where it diverges are the following:
> > *-ksp_type cg -pc_type hypre -pc_hypre_type boomeramg *
> > And the *bcgs* turnaroud doesn't work each time...
> > It seems to work without problem with aggregation (at least 128 GPUs on my
> > simulation):
> > *-ksp_type cg -pc_type gamg -pc_gamg_type agg*
> > So I guess there is a weird thing happening in my code during the solve in
> > PETSc with MPI GPU Aware, as all the previous configurations works with non
> > GPU aware MPI.
> > Here is the -ksp_view log during one fail with the first configuration:
> > *KSP Object: () 8 MPI processes type: cg maximum iterations=10000,
> > nonzero initial guess tolerances: relative=0., absolute=0.0001,
> > divergence=10000. left preconditioning using UNPRECONDITIONED norm type
> > for convergence test PC Object: () 8 MPI processes type: hypre HYPRE
> > BoomerAMG preconditioning Cycle type V Maximum number of levels
> > 25 Maximum number of iterations PER hypre call 1 Convergence
> > tolerance PER hypre call 0. Threshold for strong coupling 0.7
> > Interpolation truncation factor 0. Interpolation: max elements per
> > row 0 Number of levels of aggressive coarsening 0 Number of
> > paths for aggressive coarsening 1 Maximum row sums 0.9 Sweeps
> > down 1 Sweeps up 1 Sweeps on coarse 1
> > Relax down l1scaled-Jacobi Relax up
> > l1scaled-Jacobi Relax on coarse Gaussian-elimination Relax
> > weight (all) 1. Outer relax weight (all) 1. Maximum size
> > of coarsest grid 9 Minimum size of coarsest grid 1 Not using
> > CF-relaxation Not using more complex smoothers. Measure
> > type local Coarsen type PMIS Interpolation type
> > ext+i SpGEMM type cusparse linear system matrix = precond
> > matrix: Mat Object: () 8 MPI processes type: mpiaijcusparse
> > rows=64000, cols=64000 total: nonzeros=311040, allocated
> > nonzeros=311040 total number of mallocs used during MatSetValues
> > calls=0 not using I-node (on process 0) routines*
> > I didn't succeed for the moment creating a reproducer with ex.c examples...
> > Did you see this kind of behaviour before?
> > Should I update my PETSc version ?
> > Thanks for any advice,
> > Pierre LEDAC
> > Commissariat à l’énergie atomique et aux énergies alternatives
> > Centre de SACLAY
> > DES/ISAS/DM2S/SGLS/LCAN
> > Bâtiment 451 – point courrier n°43
> > F-91191 Gif-sur-Yvette
> > +33 1 69 08 04 03
> > +33 6 83 42 05 79
