[petsc-users] [MPI GPU Aware] KSP_DIVERGED
Junchao Zhang
junchao.zhang at gmail.com
Mon Sep 16 11:14:21 CDT 2024
Could you try petsc/main to see if the problem persists?
--Junchao Zhang
On Mon, Sep 16, 2024 at 10:51 AM LEDAC Pierre <Pierre.LEDAC at cea.fr> wrote:
> Hi all,
> We are using PETSc 3.20 in our code and running succesfully several
> solvers on Nvidia GPU with OpenMPI library which are not GPU aware (so I
> need to add the flag -use_gpu_aware_mpi 0).
> But now, when using OpenMPI GPU Aware library (OpenMPI 4.0.5 ou 4.1.5 from
> NVHPC), some parallel calculations failed with *KSP_DIVERGED_ITS* or
> *KSP_DIVERGED_DTOL*
> with several configurations. It may run wells on a small test case with
> (matrix is symmetric):
> *-ksp_type cg -pc_type gamg -pc_gamg_type classical*
> But suddenly with a number of devices for instance bigger than 4 or 8, it
> may fail.
> If I switch to another solver (BiCGstab), it may converge:
> *-ksp_type bcgs -pc_type gamg -pc_gamg_type classical*
> The more sensitive cases where it diverges are the following:
> *-ksp_type cg -pc_type hypre -pc_hypre_type boomeramg *
> And the *bcgs* turnaroud doesn't work each time...
> It seems to work without problem with aggregation (at least 128 GPUs on my
> simulation):
> *-ksp_type cg -pc_type gamg -pc_gamg_type agg*
> So I guess there is a weird thing happening in my code during the solve in
> PETSc with MPI GPU Aware, as all the previous configurations works with non
> GPU aware MPI.
> Here is the -ksp_view log during one fail with the first configuration:
> *KSP Object: () 8 MPI processes type: cg maximum iterations=10000,
> nonzero initial guess tolerances: relative=0., absolute=0.0001,
> divergence=10000. left preconditioning using UNPRECONDITIONED norm type
> for convergence test PC Object: () 8 MPI processes type: hypre HYPRE
> BoomerAMG preconditioning Cycle type V Maximum number of levels
> 25 Maximum number of iterations PER hypre call 1 Convergence
> tolerance PER hypre call 0. Threshold for strong coupling 0.7
> Interpolation truncation factor 0. Interpolation: max elements per
> row 0 Number of levels of aggressive coarsening 0 Number of
> paths for aggressive coarsening 1 Maximum row sums 0.9 Sweeps
> down 1 Sweeps up 1 Sweeps on coarse 1
> Relax down l1scaled-Jacobi Relax up
> l1scaled-Jacobi Relax on coarse Gaussian-elimination Relax
> weight (all) 1. Outer relax weight (all) 1. Maximum size
> of coarsest grid 9 Minimum size of coarsest grid 1 Not using
> CF-relaxation Not using more complex smoothers. Measure
> type local Coarsen type PMIS Interpolation type
> ext+i SpGEMM type cusparse linear system matrix = precond
> matrix: Mat Object: () 8 MPI processes type: mpiaijcusparse
> rows=64000, cols=64000 total: nonzeros=311040, allocated
> nonzeros=311040 total number of mallocs used during MatSetValues
> calls=0 not using I-node (on process 0) routines*
> I didn't succeed for the moment creating a reproducer with ex.c examples...
> Did you see this kind of behaviour before?
> Should I update my PETSc version ?
> Thanks for any advice,
> Pierre LEDAC
> Commissariat à l’énergie atomique et aux énergies alternatives
> Centre de SACLAY
> DES/ISAS/DM2S/SGLS/LCAN
> Bâtiment 451 – point courrier n°43
> F-91191 Gif-sur-Yvette
> +33 1 69 08 04 03
> +33 6 83 42 05 79
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240916/94a7d6a0/attachment-0001.html>
