[petsc-users] local/global DMPlex Vec output
Matteo Semplice matteo.semplice at uninsubria.it
Mon Oct 21 11:21:19 CDT 2024
Dear petsc-users,
     I am having issues with output of parallel data attached to a
DMPlex (or maybe more fundamental ones about DMPlex...).
So I currently
 1. create a DMPlex (DMPlexCreateGmshFromFile or DMPlexCreateBoxMesh)
 2. partition it
 3. and create a section for my data layout with
    DMPlexCreateSection(ctx.dmMesh, NULL, numComp, numDof, numBC, NULL,
    NULL, NULL, NULL, &sUavg)
 4. DMSetLocalSection(ctx.dmMesh, sUavg)
 5. create solLoc and solGlob vectors with DMCreateGlobalVector and
    DMCreateLocalVector
 6. solve ....
 7. VecView(ctx.solGlob, vtkViewer) on a .vtu file
but when I load data in ParaView I get more cells than expected and it
is as if the cells in the halo are put twice in output. (I could create
a MWE if the above is not clear)
I guess that the culprit is point (4), but if I replace it with
DMSetGlobalSection then I cannot create the local vector at point (5).
How should I handle this properly? In my code I need to create both
local and global vectors, to perform at least GlobalToLocal and to save
the global data.
(On a side note, I tried also HDF5 but then it complains about the DM
not having a DS...; really, any working solution that allows data to be
explored with Paraview is fine)
Thanks for any advice!
Matteo Semplice
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241021/85313967/attachment.html>
