[petsc-users] ParMmg crashes when run in parallel: Assertion failed: (isfinite(dd)), function PMMG_hashNorver_normals, file analys_pmmg.c, line 1072
Pierre Jolivet
pierre at joliv.et
Mon Oct 7 10:34:05 CDT 2024
Your mesh is tiny, you should not use ParMmg but plain Mmg instead which is much more robust.
I don’t know how easy it is to do with DMPlex though (gather a DM and a metric on a single process), especially from the command line.
Pierre
> On 7 Oct 2024, at 4:46 PM, Zongze Yang <yangzongze at gmail.com> wrote:
> Hi PETSc team,
> I noticed that the ParMmg interface for overlap (https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7593__;!!G_uCfscf7eWS!bh5eQHxA8QXn10TtTUOI5lmjFbfxFBtZz9CQoiYgyZSR7oDMYp8NK2HHP2UaWRXmU82ddDBpMx3ctAfX8GFQAuL_$ ) has been fixed. I tried using the updated version in my code, but it did not perform as expected when refining the attached mesh (or fine mesh of the same geometry) in parallel.
> Here are the details output: The first two sequential runs work correctly. However, when running the code in parallel without refinement, some warnings are generated. After refining the mesh in parallel, the code crashes.
> ❯ mpiexec -n 1 python test_adapt.py -dm_adaptor parmmg
> ❯ mpiexec -n 1 python test_adapt.py -dm_adaptor parmmg -refine 1
> ❯ mpiexec -n 2 python test_adapt.py -dm_adaptor parmmg
> ## Warning: MMG5_interpreg_ani: 608: unexpected case (null normal), impossible interpolation.
> ## Warning: MMG5_movbdyregpt_ani: unable to compute optimal position for at least 1 point.
> ❯ mpiexec -n 2 python test_adapt.py -dm_adaptor parmmg -refine 1
> Assertion failed: (isfinite(dd)), function PMMG_hashNorver_normals, file analys_pmmg.c, line 1072.
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = PID 22704 RUNNING AT yzzs-mac.local
> = EXIT CODE: 6
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Abort trap: 6 (signal 6)
> This typically refers to a problem with your application.
> Please see the FAQ page for debugging suggestions
> ❯ mpiexec -n 2 python test_adapt.py -dm_adaptor parmmg -overlap
> ❯ mpiexec -n 2 python test_adapt.py -dm_adaptor parmmg -overlap -refine
> = PID 25424 RUNNING AT yzzs-mac.local
> = EXIT CODE: 6
> The mesh geometry is a cylinder with an interface. The geometry file of gmsh, the mesh file, and the code are attached. Could someone take a look and help identify the issue?
> Thank you!
> Best regards,
> Zongze
> <cylinder_test.msh>
> <test_adapt.py>
> <geometry.png>
> <cylinder.geo>
