[petsc-users] getinfo for Mat of type nest
Pierre Jolivet pierre at joliv.et
Fri Oct 4 02:02:00 CDT 2024
> On 4 Oct 2024, at 8:50 AM, Edoardo alinovi <edoardo.alinovi at gmail.com> wrote:
> Jed, Junchao,
> Thanks for getting me back!
> Junchao, I cannot provide you with an input file as I am plugging just part of that code into mine. I am building blocks of the full matrix on my own, not reading from the file unfortunately. I can share a branch of my code with a 3x3 cavity toy case, but that would require compiling it and it might be a bit inconvenient for you.
> Jed, I am using fieldsplit indeed, it's just the matrix that is assembled in a 2x2 block form. Here is the full backtrace:
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: No method getinfo for Mat of type nest
> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
> [0]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_pc_type value: hypre source: command line
> [0]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_pc_type value: bjacobi source: command line
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!firbtqTDrSSyq61w7-MZvVgFlq4mbFVINLG5rFdWel7q49yeL78quSjJJ_-BZVfe7WAvCMwoKHfM8YSs9bCJ1w$  <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!a6ejiT9ML4BpeAAcqVuIMX-J7sA75OiyYcHeUd6-INXK8sR-gcQPA3ndqsgpzphK4tIBnE13dbzycfmUkwST7aXF6oxXipY$> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.20.4, unknown
> [0]PETSC ERROR: flubio_coupled on a linux_x86_64 named localhost.localdomain by edo Thu Oct  3 14:17:20 2024
> [0]PETSC ERROR: Configure options PETSC_ARCH=linux_x86_64 FOPTFLAGS=-O3 COPTFLAGS=-O3 CXXOPTFLAGS=-O3 -with-debugging=no -download-fblaslapack=1 -download-superlu_dist -download-mumps -download-hypre -download-metis -download-parmetis -download-scalapack -download-ml -download-slepc -download-hpddm -download-cmake -with-mpi-dir=/home/edo/software_repo/openmpi-5.0.1/build/
> [0]PETSC ERROR: #1 MatGetInfo() at /home/edo/software_repo/petsc/src/mat/interface/matrix.c:3005
> [0]PETSC ERROR: #2 PCSetUp_GAMG() at /home/edo/software_repo/petsc/src/ksp/pc/impls/gamg/gamg.c:619
> [0]PETSC ERROR: #3 PCSetUp() at /home/edo/software_repo/petsc/src/ksp/pc/interface/precon.c:1080
> [0]PETSC ERROR:   It appears a new error in the code was triggered after a previous error, possibly because:
> [0]PETSC ERROR:   -  The first error was not properly handled via (for example) the use of
> [0]PETSC ERROR:      PetscCall(TheFunctionThatErrors()); or
> [0]PETSC ERROR:   -  The second error was triggered while handling the first error.
> [0]PETSC ERROR:   Above is the traceback for the previous unhandled error, below the traceback for the next error
> [0]PETSC ERROR:   ALL ERRORS in the PETSc libraries are fatal, you should add the appropriate error checking to the code
> [0]PETSC ERROR: #4 KSPSetUp() at /home/edo/software_repo/petsc/src/ksp/ksp/interface/itfunc.c:415
> [0]PETSC ERROR: #5 KSPSolve_Private() at /home/edo/software_repo/petsc/src/ksp/ksp/interface/itfunc.c:832
> [0]PETSC ERROR: #6 KSPSolve() at /home/edo/software_repo/petsc/src/ksp/ksp/interface/itfunc.c:1079
> This the code I am doing right now:
>             M = this%setMomentumBlockMatrix()
>             C = this%setPressureBlockMatrix()
>             G = this%setPressureGradBlockMatrix()
>             D = this%setDivBlockMatrix()
>             bhat = this%setPressureMomentumRhs()
>             ! Create Ahat !
>             ! Bottom left block of  Ahat
>             Mat_array(4) = M
>             ! Extraction of the diagonal of M
>             call MatCreateVecs(M, PETSC_NULL_VEC, v, ierr) !v has the parallel distribution of M
>             call MatGetDiagonal(M, v, ierr)
>             call MatCreateDiagonal(v, diag_2M, ierr)
>             call MatScale(diag_2M, 2.0, ierr) ! store 2*diagonal part of M
>             call MatConvert(diag_2M, MATAIJ, MAT_INPLACE_MATRIX, diag_2M, ierr)
>             call VecReciprocal(v, ierr)
>             ! Creation of D_M_inv_G = D_M_inv*G
>             call MatDuplicate(G,MAT_COPY_VALUES, D_M_inv_G, ierr) ! D_M_inv_G contains G
>             call MatCreateVecs(D_M_inv_G, PETSC_NULL_VEC, v_redistributed, ierr) ! v_redistributed has the parallel distribution of D_M_inv_G
>             call VecGetOwnershipRange(v, col_min, col_max, ierr)
>             call ISCreateStride(PETSC_COMM_WORLD, col_max-col_min, col_min, 1, is_from, ierr)
>             call VecGetOwnershipRange(v_redistributed, col_min, col_max, ierr)
>             call ISCreateStride(PETSC_COMM_WORLD, col_max-col_min, col_min, 1, is_to, ierr)
>             call VecScatterCreate(v,is_from,v_redistributed,is_to, scat, ierr)
>             call VecScatterBegin(scat, v, v_redistributed,INSERT_VALUES,SCATTER_FORWARD, ierr)
>             call VecScatterEnd(  scat, v, v_redistributed,INSERT_VALUES,SCATTER_FORWARD, ierr)
>             call MatDiagonalScale( D_M_inv_G, v_redistributed, PETSC_NULL_VEC, ierr) ! D_M_inv_G contains D_M_inv*G
>             call ISDestroy(is_to, ierr)
>             call ISDestroy(is_from, ierr)
>             ! Creation of  Chat (PETSC_DEFAULT_REAL ->  PETSC_DETERMINE)
>             call MatMatMult(D, D_M_inv_G, MAT_INITIAL_MATRIX, PETSC_DEFAULT_REAL,  Chat, ierr) !  Chat contains D*D_M_inv*G
>             call MatAXPY( Chat, 1.0, C, SUBSET_NONZERO_PATTERN, ierr) !  Chat contains C + D*D_M_inv*G
>             Mat_array(1) =  Chat ! Top left block of  Ahat
>             !  Creation of  Ghat
>             call MatMatMult(M, D_M_inv_G, MAT_INITIAL_MATRIX, PETSC_DEFAULT_REAL,  Ghat, ierr) !  Ghat contains M*D_M_inv*G
>             call MatAYPX( Ghat, -1.0, G, UNKNOWN_NONZERO_PATTERN, ierr) !  Ghat contains G - M*D_M_inv*G
>             Mat_array(3) =  Ghat ! Bottom left block of  Ahat
>             !  Creation of -D
>             call MatScale(D,-1.0, ierr)
>             Mat_array(2) = D ! Top right block of  Ahat
>             ! Creation of  Ahat = transformed+ reordered A_input
>             call MatCreateNest(PETSC_COMM_WORLD, 2, PETSC_NULL_IS, 2, PETSC_NULL_IS, Mat_array,  Ahat, ierr)
>             ! Creation of Pmat
>             Mat_array(4) = diag_2M
>             Mat_array(2) = PETSC_NULL_MAT ! Cancel top right block
>             call MatCreateNest(PETSC_COMM_WORLD, 2, PETSC_NULL_IS, 2, PETSC_NULL_IS, Mat_array, Pmat, ierr);
>             ! Finalisation of the preconditioner
>             call ISCreateStride(PETSC_COMM_WORLD, numberOfElements, 0, 1, is_P_hat, ierr);
>             call ISCreateStride(PETSC_COMM_WORLD, (3-bdim)*numberOfElements, numberOfElements, 1, is_U_hat, ierr);
>             ! KSP PART !
>             call KSPSetOperators(this%ksp,  Ahat, Pmat, ierr)
>             call KSPGetPC(this%ksp, pc, ierr)
>             call PCSetFromOptions(pc, ierr)
>             call PCSetUp(pc, ierr)
>             call KSPSetFromOptions(this%ksp, ierr)
>             call KSPSetUp(this%ksp, ierr)
>             call VecDuplicate(bhat, xhat, ierr)
>             ! I think it makes sense to move this part where fieldsplit preconditioner is defined
>             call PCFieldSplitSetIS(pc, "phat", is_P_hat, ierr)
>             call PCFieldSplitSetIS(pc, "uhat", is_U_hat, ierr)
>             call KSPSolve(this%ksp, bhat, xhat, ierr)
> KSP id FGMRES + fieldsplit with default settings.
Apparently not, otherwise GAMG would not be called.
In particular, it looks like the code is currently trying to call GAMG on the global outer MatNest, whereas you likely want to call it on just one of the inner block.
Please send the complete code, complete options file, and complete command line arguments you are using, because with just the snippet you sent and the stack trace, the code is indeed not expected to work, e.g., I see no occurence of -pc_type fieldsplit or PCSetType(pc, PCFIELDSPLIT).
Pierre
> Many thanks!
> Il giorno gio 3 ott 2024 alle ore 19:01 Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> ha scritto:
>> Could you also provide input files to run your code?
>> --Junchao Zhang
>> On Thu, Oct 3, 2024 at 5:14 AM Edoardo alinovi <edoardo.alinovi at gmail.com <mailto:edoardo.alinovi at gmail.com>> wrote:
>>> Hi Barry,
>>> I am trying to port this preconditioner I found presented at the last PETSc conference into may code:
>>> https://urldefense.us/v3/__https://github.com/ndjinga/SOLVERLAB/blob/master/CoreFlows/examples/C/SaddlePointPreconditioner/SaddlePointLinearSolver.c__;!!G_uCfscf7eWS!firbtqTDrSSyq61w7-MZvVgFlq4mbFVINLG5rFdWel7q49yeL78quSjJJ_-BZVfe7WAvCMwoKHfM8YS_aI5DUg$  <https://urldefense.us/v3/__https://github.com/ndjinga/SOLVERLAB/blob/master/CoreFlows/examples/C/SaddlePointPreconditioner/SaddlePointLinearSolver.c__;!!G_uCfscf7eWS!a-JnrBsta75n_WDtxUNd7Xb8_m7tg1pWSxwWNTmUBSfpBwISq4IxJkbM6QgADd-x23Q_2s-d6d6bOWCKGRMxMzHyc9DDm7A$>
>>> So far so good, I am just translating C to Fortran, however when I try to solve my linear system with:
>>> call KSPSetOperators(ksp,  Ahat, Pmat, ierr)
>>> call KSPSolve(ksp, bhat, xhat, ierr)
>>> with Ahat and Pmat being indeed two nest MatNest, created from an array of Mat as:
>>> However I am getting this error on getinfo:
>>> from C to Fortran
>>> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!firbtqTDrSSyq61w7-MZvVgFlq4mbFVINLG5rFdWel7q49yeL78quSjJJ_-BZVfe7WAvCMwoKHfM8YSs9bCJ1w$  <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!a-JnrBsta75n_WDtxUNd7Xb8_m7tg1pWSxwWNTmUBSfpBwISq4IxJkbM6QgADd-x23Q_2s-d6d6bOWCKGRMxMzHyRUMnyvE$> for trouble shooting.
>>> How can I get rid of this issue?
>>> Many thanks!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241004/9e2dc02f/attachment-0001.html>
