[petsc-users] getinfo for Mat of type nest
Edoardo alinovi edoardo.alinovi at gmail.com
Fri Oct 4 01:50:09 CDT 2024
Jed, Junchao,
Thanks for getting me back!
Junchao, I cannot provide you with an input file as I am plugging just part
of that code into mine. I am building blocks of the full matrix on my own,
not reading from the file unfortunately. I can share a branch of my code
with a 3x3 cavity toy case, but that would require compiling it and it
might be a bit inconvenient for you.
Jed, I am using fieldsplit indeed, it's just the matrix that is assembled
in a 2x2 block form. Here is the full backtrace:
*[0]PETSC ERROR: --------------------- Error Message
*[0]PETSC ERROR: No support for this operation for this object type*
*[0]PETSC ERROR: No method getinfo for Mat of type nest*
*[0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the
program crashed before usage or a spelling mistake, etc!*
*[0]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_p_pc_type value:
hypre source: command line*
*[0]PETSC ERROR:   Option left: name:-UPeqn_fieldsplit_u_pc_type value:
bjacobi source: command line*
*[0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!a6ejiT9ML4BpeAAcqVuIMX-J7sA75OiyYcHeUd6-INXK8sR-gcQPA3ndqsgpzphK4tIBnE13dbzycfmUkwST7aXF6oxXipY$
<https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!a6ejiT9ML4BpeAAcqVuIMX-J7sA75OiyYcHeUd6-INXK8sR-gcQPA3ndqsgpzphK4tIBnE13dbzycfmUkwST7aXF6oxXipY$ > for trouble shooting.*
*[0]PETSC ERROR: Petsc Release Version 3.20.4, unknown *
*[0]PETSC ERROR: flubio_coupled on a linux_x86_64 named
localhost.localdomain by edo Thu Oct  3 14:17:20 2024*
*[0]PETSC ERROR: Configure options PETSC_ARCH=linux_x86_64 FOPTFLAGS=-O3
COPTFLAGS=-O3 CXXOPTFLAGS=-O3 -with-debugging=no -download-fblaslapack=1
-download-superlu_dist -download-mumps -download-hypre -download-metis
-download-parmetis -download-scalapack -download-ml -download-slepc
-download-hpddm -download-cmake
-with-mpi-dir=/home/edo/software_repo/openmpi-5.0.1/build/*
*[0]PETSC ERROR: #1 MatGetInfo() at
/home/edo/software_repo/petsc/src/mat/interface/matrix.c:3005*
*[0]PETSC ERROR: #2 PCSetUp_GAMG() at
/home/edo/software_repo/petsc/src/ksp/pc/impls/gamg/gamg.c:619*
*[0]PETSC ERROR: #3 PCSetUp() at
/home/edo/software_repo/petsc/src/ksp/pc/interface/precon.c:1080*
*[0]PETSC ERROR:   It appears a new error in the code was triggered after a
previous error, possibly because:*
*[0]PETSC ERROR:   -  The first error was not properly handled via (for
example) the use of*
*[0]PETSC ERROR:      PetscCall(TheFunctionThatErrors()); or*
*[0]PETSC ERROR:   -  The second error was triggered while handling the
first error.*
*[0]PETSC ERROR:   Above is the traceback for the previous unhandled error,
below the traceback for the next error*
*[0]PETSC ERROR:   ALL ERRORS in the PETSc libraries are fatal, you should
add the appropriate error checking to the code*
*[0]PETSC ERROR: #4 KSPSetUp() at
/home/edo/software_repo/petsc/src/ksp/ksp/interface/itfunc.c:415*
first error.*
*[0]PETSC ERROR: #5 KSPSolve_Private() at
/home/edo/software_repo/petsc/src/ksp/ksp/interface/itfunc.c:832*
*[0]PETSC ERROR: #6 KSPSolve() at
/home/edo/software_repo/petsc/src/ksp/ksp/interface/itfunc.c:1079*
This the code I am doing right now:
*            M = this%setMomentumBlockMatrix()            C =
this%setPressureBlockMatrix()            G =
this%setPressureGradBlockMatrix()            D = this%setDivBlockMatrix()
          bhat = this%setPressureMomentumRhs()
!------------------!            ! Create Ahat !
!-----------------!            ! Bottom left block of  Ahat
Mat_array(4) = M                        ! Extraction of the diagonal of M
          call MatCreateVecs(M, PETSC_NULL_VEC, v, ierr) !v has the
parallel distribution of M            call MatGetDiagonal(M, v, ierr)
      call MatCreateDiagonal(v, diag_2M, ierr)            call
MatScale(diag_2M, 2.0, ierr) ! store 2*diagonal part of M            call
MatConvert(diag_2M, MATAIJ, MAT_INPLACE_MATRIX, diag_2M, ierr)
call VecReciprocal(v, ierr)            ! Creation of D_M_inv_G = D_M_inv*G
          call MatDuplicate(G,MAT_COPY_VALUES, D_M_inv_G, ierr) ! D_M_inv_G
contains G            call MatCreateVecs(D_M_inv_G, PETSC_NULL_VEC,
v_redistributed, ierr) ! v_redistributed has the parallel distribution of
D_M_inv_G            call VecGetOwnershipRange(v, col_min, col_max, ierr)
          call ISCreateStride(PETSC_COMM_WORLD, col_max-col_min, col_min,
1, is_from, ierr)            call VecGetOwnershipRange(v_redistributed,
col_min, col_max, ierr)            call ISCreateStride(PETSC_COMM_WORLD,
col_max-col_min, col_min, 1, is_to, ierr)            call
VecScatterCreate(v,is_from,v_redistributed,is_to, scat, ierr)
call VecScatterBegin(scat, v,
v_redistributed,INSERT_VALUES,SCATTER_FORWARD, ierr)            call
VecScatterEnd(  scat, v, v_redistributed,INSERT_VALUES,SCATTER_FORWARD,
ierr)            call MatDiagonalScale( D_M_inv_G, v_redistributed,
PETSC_NULL_VEC, ierr) ! D_M_inv_G contains D_M_inv*G            call
ISDestroy(is_to, ierr)            call ISDestroy(is_from, ierr)
! Creation of  Chat (PETSC_DEFAULT_REAL ->  PETSC_DETERMINE)
call MatMatMult(D, D_M_inv_G, MAT_INITIAL_MATRIX, PETSC_DEFAULT_REAL,
 Chat, ierr) !  Chat contains D*D_M_inv*G            call MatAXPY( Chat,
1.0, C, SUBSET_NONZERO_PATTERN, ierr) !  Chat contains C + D*D_M_inv*G
      Mat_array(1) =  Chat ! Top left block of  Ahat                    !
Creation of  Ghat            call MatMatMult(M, D_M_inv_G,
MAT_INITIAL_MATRIX, PETSC_DEFAULT_REAL,  Ghat, ierr) !  Ghat contains
M*D_M_inv*G            call MatAYPX( Ghat, -1.0, G,
UNKNOWN_NONZERO_PATTERN, ierr) !  Ghat contains G - M*D_M_inv*G
Mat_array(3) =  Ghat ! Bottom left block of  Ahat                    !
Creation of -D            call MatScale(D,-1.0, ierr)
Mat_array(2) = D ! Top right block of  Ahat                    ! Creation
of  Ahat = transformed+ reordered A_input            call
MatCreateNest(PETSC_COMM_WORLD, 2, PETSC_NULL_IS, 2, PETSC_NULL_IS,
Mat_array,  Ahat, ierr)                    ! Creation of Pmat
Mat_array(4) = diag_2M            Mat_array(2) = PETSC_NULL_MAT ! Cancel
top right block            call MatCreateNest(PETSC_COMM_WORLD, 2,
PETSC_NULL_IS, 2, PETSC_NULL_IS, Mat_array, Pmat, ierr);
! Finalisation of the preconditioner            call
ISCreateStride(PETSC_COMM_WORLD, numberOfElements, 0, 1, is_P_hat, ierr);
          call ISCreateStride(PETSC_COMM_WORLD, (3-bdim)*numberOfElements,
numberOfElements, 1, is_U_hat, ierr);            !----------------!
    ! KSP PART !            !----------------!            call
KSPSetOperators(this%ksp,  Ahat, Pmat, ierr)            call
KSPGetPC(this%ksp, pc, ierr)            call PCSetFromOptions(pc, ierr)
        call PCSetUp(pc, ierr)            call KSPSetFromOptions(this%ksp,
ierr)            call KSPSetUp(this%ksp, ierr)            call
VecDuplicate(bhat, xhat, ierr)            ! I think it makes sense to move
this part where fieldsplit preconditioner is defined            call
PCFieldSplitSetIS(pc, "phat", is_P_hat, ierr)            call
PCFieldSplitSetIS(pc, "uhat", is_U_hat, ierr)            call
KSPSolve(this%ksp, bhat, xhat, ierr)*
KSP id FGMRES + fieldsplit with default settings.
Many thanks!
Il giorno gio 3 ott 2024 alle ore 19:01 Junchao Zhang <
junchao.zhang at gmail.com> ha scritto:
> Could you also provide input files to run your code?
> --Junchao Zhang
> On Thu, Oct 3, 2024 at 5:14 AM Edoardo alinovi <edoardo.alinovi at gmail.com>
> wrote:
>> Hi Barry,
>> I am trying to port this preconditioner I found presented at the last
>> PETSc conference into may code:
>> https://urldefense.us/v3/__https://github.com/ndjinga/SOLVERLAB/blob/master/CoreFlows/examples/C/SaddlePointPreconditioner/SaddlePointLinearSolver.c__;!!G_uCfscf7eWS!a6ejiT9ML4BpeAAcqVuIMX-J7sA75OiyYcHeUd6-INXK8sR-gcQPA3ndqsgpzphK4tIBnE13dbzycfmUkwST7aXF2QaZ-jc$
>> <https://urldefense.us/v3/__https://github.com/ndjinga/SOLVERLAB/blob/master/CoreFlows/examples/C/SaddlePointPreconditioner/SaddlePointLinearSolver.c__;!!G_uCfscf7eWS!a-JnrBsta75n_WDtxUNd7Xb8_m7tg1pWSxwWNTmUBSfpBwISq4IxJkbM6QgADd-x23Q_2s-d6d6bOWCKGRMxMzHyc9DDm7A$>
>> So far so good, I am just translating C to Fortran, however when I try to
>> solve my linear system with:
>> call KSPSetOperators(ksp,  Ahat, Pmat, ierr)
>> call KSPSolve(ksp, bhat, xhat, ierr)
>> with Ahat and Pmat being indeed two nest MatNest, created from an array
>> of Mat as:
>> call MatCreateNest(PETSC_COMM_WORLD, 2, PETSC_NULL_IS, 2, PETSC_NULL_IS,
>> However I am getting this error on getinfo:
>> from C to Fortran
>> <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!a-JnrBsta75n_WDtxUNd7Xb8_m7tg1pWSxwWNTmUBSfpBwISq4IxJkbM6QgADd-x23Q_2s-d6d6bOWCKGRMxMzHyRUMnyvE$>
>> How can I get rid of this issue?
>> Many thanks!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241004/4ab2af3c/attachment-0001.html>
