[petsc-users] Memory Used When Reading petscrc
David Scott
d.scott at epcc.ed.ac.uk
Fri Nov 22 19:16:22 CST 2024
OK.
I had started to wonder if that was the case. I'll do some further
investigation.
David
On 22/11/2024 22:10, Matthew Knepley wrote:
> This email was sent to you by someone outside the University.
> You should only click on links or attachments if you are certain that
> the email is genuine and the content is safe.
> On Fri, Nov 22, 2024 at 12:57 PM David Scott <d.scott at epcc.ed.ac.uk>
> wrote:
> Matt,
> Thanks for the quick response.
> Yes 1) is trivially true.
> With regard to 2), from the SLURM output:
> [0] Maximum memory PetscMalloc()ed 29552 maximum size of entire
> process 4312375296
> [1] Maximum memory PetscMalloc()ed 29552 maximum size of entire
> process 4311990272
> Yes only 29KB was malloced but the total figure was 4GB per process.
> Looking at
> mem0 = 16420864.000000000
> mem0 = 16117760.000000000
> mem1 = 4311490560.0000000
> mem1 = 4311826432.0000000
> mem2 = 4311490560.0000000
> mem2 = 4311826432.0000000
> mem0 is written after PetscInitialize.
> mem1 is written roughly half way through the options being read.
> mem2 is written on completion of the options being read.
> The code does very little other than read configuration options.
> Why is so much memory used?
> This is not due to options processing, as that would fall under Petsc
> malloc allocations. I believe we are measuring this
> using RSS which includes the binary, all shared libraries which are
> paged in, and stack/heap allocations. I think you are
> seeing the shared libraries come in. You might be able to see all the
> libraries that come in using strace.
> Thanks,
> Matt
> I do not understand what is going on and I may have expressed
> myself badly but I do have a problem as I certainly cannot use
> anywhere near 128 processes on a node with 128GB of RAM before I
> get an OOM error. (The code runs successfully on 32 processes but
> not 64.)
> Regards,
> David
>> that the email is genuine and the content is safe.
>> On Fri, Nov 22, 2024 at 11:36 AM David Scott
>> <d.scott at epcc.ed.ac.uk> wrote:
>> Hello,
>> I am using the options mechanism of PETSc to configure my CFD
>> code. I
>> have introduced options describing the size of the domain
>> etc. I have
>> noticed that this consumes a lot of memory. I have found that
>> the amount
>> of memory used scales linearly with the number of MPI
>> processes used.
>> This restricts the number of MPI processes that I can use.
>> There are two statements:
>> 1) The memory scales linearly with P
>> 2) This uses a lot of memory
>> Let's deal with 1) first. This seems to be trivially true. If I
>> want every process to have
>> access to a given option value, that option value must be in the
>> memory of every process.
>> The only alternative would be to communicate with some process in
>> order to get values.
>> Few codes seem to be willing to make this tradeoff, and we do not
>> offer it.
>> Now 2). Looking at the source, for each option we store
>> a PetscOptionItem, which I count
>> as having size 37 bytes (12 pointers/ints and a char). However,
>> there is data behind every
>> pointer, like the name, help text, available values (sometimes),
>> I could see it being as large
>> as 4K. Suppose it is. If I had 256 options, that would be 1M. Is
>> this a large amount of memory?
>> The way I read the SLURM output, 29K was malloced. Is this a
>> I am trying to get an idea of the scale.
>> Thanks,
>> Matt
>> Is there anything that I can do about this or do I need to
>> configure my
>> code in a different way?
>> I have attached some code extracted from my application which
>> demonstrates this along with the output from a running it on
>> 2 MPI
>> processes.
>> Best wishes,
>> David Scott
>> The University of Edinburgh is a charitable body, registered
>> in Scotland, with registration number SC005336. Is e
>> buidheann carthannais a th’ ann an Oilthigh Dhùn Èideann,
>> clàraichte an Alba, àireamh clàraidh SC005336.
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cH8SjJvsuVEK1zv8noUjNUJC0VnHFqems68PjB2E94pqxc3q55YprX1q2JXFvPAzXJkh40J1-erXPWdIvc-xrLkRIgg$
>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cH8SjJvsuVEK1zv8noUjNUJC0VnHFqems68PjB2E94pqxc3q55YprX1q2JXFvPAzXJkh40J1-erXPWdIvc-xGybRwKU$ >
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241123/f16f2058/attachment-0001.html>
