[petsc-users] Memory Used When Reading petscrc
Fri Nov 22 16:10:43 CST 2024
On Fri, Nov 22, 2024 at 12:57 PM David Scott <d.scott at epcc.ed.ac.uk> wrote:
> Matt,
> Thanks for the quick response.
> Yes 1) is trivially true.
> With regard to 2), from the SLURM output:
> [0] Maximum memory PetscMalloc()ed 29552 maximum size of entire process
> 4312375296
> [1] Maximum memory PetscMalloc()ed 29552 maximum size of entire process
> 4311990272
> Yes only 29KB was malloced but the total figure was 4GB per process.
> Looking at
>  mem0 =    16420864.000000000
>  mem0 =    16117760.000000000
>  mem1 =    4311490560.0000000
>  mem1 =    4311826432.0000000
>  mem2 =    4311490560.0000000
>  mem2 =    4311826432.0000000
> mem0 is written after PetscInitialize.
> mem1 is written roughly half way through the options being read.
> mem2 is written on completion of the options being read.
> The code does very little other than read configuration options. Why is so
> much memory used?
This is not due to options processing, as that would fall under Petsc
malloc allocations. I believe we are measuring this
using RSS which includes the binary, all shared libraries which are paged
in, and stack/heap allocations. I think you are
seeing the shared libraries come in. You might be able to see all the
libraries that come in using strace.
     Matt
> I do not understand what is going on and I may have expressed myself badly
> but I do have a problem as I certainly cannot use anywhere near 128
> processes on a node with 128GB of RAM before I get an OOM error. (The code
> runs successfully on 32 processes but not 64.)
> Regards,
> David
> On 22/11/2024 16:53, Matthew Knepley wrote:
> This email was sent to you by someone outside the University.
> You should only click on links or attachments if you are certain that the
> email is genuine and the content is safe.
> On Fri, Nov 22, 2024 at 11:36 AM David Scott <d.scott at epcc.ed.ac.uk>
> wrote:
>> Hello,
>> I am using the options mechanism of PETSc to configure my CFD code. I
>> have introduced options describing the size of the domain etc. I have
>> noticed that this consumes a lot of memory. I have found that the amount
>> of memory used scales linearly with the number of MPI processes used.
>> This restricts the number of MPI processes that I can use.
> There are two statements:
> 1) The memory scales linearly with P
> 2) This uses a lot of memory
> Let's deal with 1) first. This seems to be trivially true. If I want every
> process to have
> access to a given option value, that option value must be in the memory of
> every process.
> The only alternative would be to communicate with some process in order to
> get values.
> Few codes seem to be willing to make this tradeoff, and we do not offer it.
> Now 2). Looking at the source, for each option we store a PetscOptionItem,
> which I count
> as having size 37 bytes (12 pointers/ints and a char). However, there is
> data behind every
> pointer, like the name, help text, available values (sometimes), I could
> see it being as large
> as 4K. Suppose it is. If I had 256 options, that would be 1M. Is this a
> large amount of memory?
> The way I read the SLURM output, 29K was malloced. Is this a large amount
> of memory?
> I am trying to get an idea of the scale.
>   Thanks,
>       Matt
>> Is there anything that I can do about this or do I need to configure my
>> code in a different way?
>> I have attached some code extracted from my application which
>> demonstrates this along with the output from a running it on 2 MPI
>> processes.
>> Best wishes,
>> David Scott
>> The University of Edinburgh is a charitable body, registered in Scotland,
>> with registration number SC005336. Is e buidheann carthannais a th’ ann an
>> Oilthigh Dhùn Èideann, clàraichte an Alba, àireamh clàraidh SC005336.
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZLozvsSwhcAXnBdZ4m-ImNu-aXxMX8SpsHB7SM320hlG3hZEq3hw7UvNnb4c2hzs2_t_rAlLN5oIdM6Uw7ol$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZLozvsSwhcAXnBdZ4m-ImNu-aXxMX8SpsHB7SM320hlG3hZEq3hw7UvNnb4c2hzs2_t_rAlLN5oIdCKCLif4$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZLozvsSwhcAXnBdZ4m-ImNu-aXxMX8SpsHB7SM320hlG3hZEq3hw7UvNnb4c2hzs2_t_rAlLN5oIdM6Uw7ol$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZLozvsSwhcAXnBdZ4m-ImNu-aXxMX8SpsHB7SM320hlG3hZEq3hw7UvNnb4c2hzs2_t_rAlLN5oIdCKCLif4$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241122/a8a88919/attachment.html>
