[petsc-users] Question on MatMatmult
Frank Bramkamp
bramkamp at nsc.liu.se
Wed May 29 15:10:18 CDT 2024
Ah ok,
Then I will have a look at matconvert.
And then maybe later switch to AIJ as well.
Thanks of the help, Frank
> On 29 May 2024, at 16:57, Barry Smith <bsmith at petsc.dev> wrote:
> You can use MatConvert()
>> On May 29, 2024, at 10:53 AM, Frank Bramkamp <bramkamp at nsc.liu.se> wrote:
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> Hello Hong,
>> Thank you for the clarification.
>> If I already have a BAIJ matrix format, can I then convert it later into AIJ format as well ?!
>> In that case I would have two matrices, but that would be ok for testing.
>> I think that you sometimes convert different matrix formats into each other ?!
>> Since I typically have BAIJ format, I also use a blocked ILU, which would turn into a point wise ILU
>> for an AIJ matrix. That is why I typically have the BAIJ format.
>> Otherwise, I have to change it into an AIJ format from the beginning.
>> Thanks for the quick help,
>> Frank
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240529/8a40a19a/attachment-0001.html>
