[petsc-users] Question on MatMatmult
Barry Smith
bsmith at petsc.dev
Wed May 29 09:57:27 CDT 2024
You can use MatConvert()
> On May 29, 2024, at 10:53 AM, Frank Bramkamp <bramkamp at nsc.liu.se> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Hello Hong,
> Thank you for the clarification.
> If I already have a BAIJ matrix format, can I then convert it later into AIJ format as well ?!
> In that case I would have two matrices, but that would be ok for testing.
> I think that you sometimes convert different matrix formats into each other ?!
> Since I typically have BAIJ format, I also use a blocked ILU, which would turn into a point wise ILU
> for an AIJ matrix. That is why I typically have the BAIJ format.
> Otherwise, I have to change it into an AIJ format from the beginning.
> Thanks for the quick help,
> Frank
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240529/957d975c/attachment-0001.html>
