[petsc-users] Help with Integrating PETSc into Fortran Groundwater Flow Simulation Code
Sat May 18 18:35:20 CDT 2024
On Sat, May 18, 2024 at 7:29 PM Shatanawi, Sawsan Muhammad <
sawsan.shatanawi at wsu.edu> wrote:
> Hello everyone,
> Thank you all for your feedback, it helped me a lot.
> I read the PETSc document and examples related to the Jacobian and
> modified my code.
> Now I am getting errors related to the memory access.  I tried to debug
> but couldn't find out how to fix it.
I think the right way to find the bug is to start with either
a) Valgrind (https://urldefense.us/v3/__http://www.valgrind.org__;!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46n-sW_2y$ )
or
b) Address Sanitizer, which is a feature of the clang compiler
(-fsanitize=address)
You can also run with -malloc_debug in PETSc, which can detect some errors.
      Matt
> sshatanawi/SawSim: Sawsan's Simulation (SawSim) is a groundwater dynamics
> scheme to be integrated into Noah MP land surface model (github.com)
> <https://urldefense.us/v3/__https://github.com/sshatanawi/SawSim__;!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46t8nZWfw$ >   is the link to the code in the
> GitHub, I would appreciate it if you could have a look at it and guide me
> how to fix it.
> I believe the problem is in the memory of LHS and res_vector because they
> are new vectors I created.
> Thank you in advance for your help, I really appreciate it
> Bests,
> Sawsan
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Saturday, May 11, 2024 1:56 AM
> *To:* Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu>
> *Cc:* Barry Smith <bsmith at petsc.dev>; petsc-users at mcs.anl.gov <
> petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Help with Integrating PETSc into Fortran
> *[EXTERNAL EMAIL]*
> On Fri, May 10, 2024 at 6:30 PM Shatanawi, Sawsan Muhammad via petsc-users
> <petsc-users at mcs.anl.gov> wrote:
> Good afternoon, I have tried SNESComputeJacobianDefaultColor(), but the
> arguments needed are confusing me. Would you please have a look at my code
> and the error messages I am getting? I didn't understand what the nonzero
> values of the sparse
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> Good afternoon,
> I have tried SNESComputeJacobianDefaultColor(), but the arguments needed
> are confusing me.
> Would you please have a look at my code and the error messages I am
> getting?
> I didn't understand what the nonzero values of the sparse Jacobian would
> be.
> 1) You are not checking any of the return values from PETSc calls. Look at
> the PETSc Fortran examples.
>      You  should wrap all PETSc calls in PetscCall() or PetscCallA().
> 2) You are not intended to directly
> call SNESComputeJacobianDefaultColor(). PETSc will do this automatically if
> you do not set of Jacobian function.
> 3) As Barry points out, coloring will not work unless we understand the
> nonzero structure of your Jacobian. This can happen by either:
>   a) Using a DM: This is the easiest. Find the type that matches your
> grid, or
>   b) Preallocating your Jacobian: Here you give the nonzero structure of
> your Jacobian, but not the values.
>        Currently you do not do this. Instead you just give the size, not
> the nonzero structure (columns for
>        each row).
>   Thanks,
>      Matt
> Thank you for your patience and help
> Bests,
> Sawsan
> *From:* Barry Smith <bsmith at petsc.dev>
> *Sent:* Thursday, May 9, 2024 12:05 PM
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *[EXTERNAL EMAIL]*
> On May 9, 2024, at 2:52 PM, Shatanawi, Sawsan Muhammad via petsc-users <
> Hello everyone,
> Thank you for your responses and feedback,
> I checked PFLOTRAN and found that it is a model to simulate groundwater
> flow, contaminant transport, and other subsurface processes.
> my goal is not to simulate the groundwater flow, my goal is to develop a
> code from scratch to simulate the groundwater flow with specific
> conditions, and then integrate this code with land surface models.
> Later, the simulation of this code will be on a large scale.
> I want PETSc to calculate the Jacobian because the system is large and has
> complex nonlinear behavior, and I don’t risk calculating the derivative by
> myself.
> My A-Matrix has parts of source terms that depend on the flow fields, and
> independent parts will be in the RHS vector.
>     With coloring SNESComputeJacobianDefaultColor() PETSc can compute
> Jacobian's pretty efficiently. You do not to provide the residual function
> and you need to provide the nonzero pattern of the sparse Jacobian; that is
> what residual components f_i are coupled to what input variables in the
> array x_i. This information comes from your PDE and discretization and
> appears implicitly in your residual function.
>   Barry
> I hope I have answered your questions, and I apologize that I wasn’t clear
> from the beginning, I was trying to keep my descriptions brief.
> Bests,
> Sawsan
> *Sent:* Tuesday, May 7, 2024 5:17 PM
> *[EXTERNAL EMAIL]*
> On Tue, May 7, 2024 at 2:23 PM Shatanawi, Sawsan Muhammad via petsc-users <
> Hello everyone,
> I hope this email finds you well.
>  My Name is Sawsan Shatanawi, and I was developing a Fortran code for
> simulating groundwater flow in a 3D system with nonlinear behavior.  I
> solved the nonlinear system using the PCG solver and Picard iteration, but
> I did not get good results although I checked my matrix and RHS and
> everything, I decided to change my solver to Newton Rapson method.
> I checked PETSc documents but I have a few questions:
> 1) My groundwater system is time-dependent, so should I use TS only
> instead of SNES?
> You could use TS, but it is not necessary. You could use SNES and your own
> timestepping. THe advantage of TS is that you can try many different
> timesteppers without recoding (just like you can
> try many different linear and nonlinear solvers).
> 2) My system has its deltaT, would using deltaT as dt affect my solver, or
> is it better to use TS-PETSc dt? Also, would using PETSc dt affect the
> simulation of the groundwater system
> It sounds like your dt comes from your timestepper. If you use TS, you
> would use the dt from that.
> 3) I want my Jacobian matrix to be calculated by PETSc automatically
> PETSc can calculate a full Jacobian for smaller problems, or a
> finite-difference Jacobian for any problem (but this impacts the solver).
> It should be straightfoward to code up the analytic Jacobian. Is there a
> reason it would be a problem?
> 4) Do I need to define and calculate the residual vector?
> Yes.
> My A-Matrix contains coefficients and external sources and my RHS vector
> includes the boundary conditions
> It is strange that your matrix would contain source terms. Do they depend
> on the flow fields?
> Barry is right, you should consider PFlotran, and at least know why it
> would not work for your problem if you don't use it.
>   Thanks,
>      Matt
> Please find the attached file contains a draft of my code
> Thank you in advance for your time and help.
> Best regards,
>  Sawsan
> *From:* Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu>
> *Sent:* Tuesday, January 16, 2024 10:43 AM
> *To:* Junchao Zhang <junchao.zhang at gmail.com>
> *Cc:* Barry Smith <bsmith at petsc.dev>; Matthew Knepley <knepley at gmail.com>;
> Mark Adams <mfadams at lbl.gov>; petsc-users at mcs.anl.gov <
> Hello all,
> Thank you for your valuable help. I will do your recommendations and hope
> it will run without any issues.
> Bests,
> Sawsan
> *From:* Junchao Zhang <junchao.zhang at gmail.com>
> *Sent:* Friday, January 12, 2024 8:46 AM
> *[EXTERNAL EMAIL]*
> Hi, Sawsan,
>    First in test_main.F90, you need to call VecGetArrayF90(temp_solution,
> H_vector, ierr) and  VecRestoreArrayF90 (temp_solution, H_vector, ierr)  as
> Barry mentioned.
>    Secondly, in the loop of test_main.F90, it calls GW_solver(). Within
> it, it calls PetscInitialize()/PetscFinalize(). But without MPI being
> initialized, PetscInitialize()/PetscFinalize()* can only be called once.*
>         do timestep =2 , NTSP
>                call GW_boundary_conditions(timestep-1)
>                 !print *,HNEW(1,1,1)
>            call GW_elevation()
>                ! print *, GWTOP(2,2,2)
>            call GW_conductance()
>                ! print *, CC(2,2,2)
>            call GW_recharge()
>                ! print *, B_Rech(5,4)
>            call GW_pumping(timestep-1)
>                ! print *, B_pump(2,2,2)
>            call GW_SW(timestep-1)
>                 print *,B_RIVER (2,2,2)
>            call GW_solver(timestep-1,N)
>            call GW_deallocate_loop()
>         end do
> A solution is to delete PetscInitialize()/PetscFinalize() in
> GW_solver_try.F90 and move it to test_main.F90,  outside the do loop.
> diff --git a/test_main.F90 b/test_main.F90
> index b5997c55..107bd3ee 100644
> --- a/test_main.F90
> +++ b/test_main.F90
> @@ -1,5 +1,6 @@
>  program test_GW
> +#include <petsc/finclude/petsc.h>
>          use petsc
>          use GW_constants
>          use GW_param_by_user
> @@ -8,6 +9,9 @@ program test_GW
>          implicit none
>          integer :: N
>          integer :: timestep
> +        PetscErrorCode ierr
> +        call PetscInitialize(ierr)
>          call GW_domain(N)
>          !print *, "N=",N
>          !print *, DELTAT
> @@ -37,4 +41,5 @@ program test_GW
>          end do
>          print *, HNEW(NCOL,3,2)
>          call GW_deallocate ()
> +        call PetscFinalize(ierr)
>  end program test_GW
> With that, the MPI error will be fixed.  The code could run to
> gw_deallocate () before abort.  There are other memory errors. You can
> install/use valgrind to fix them.  Run it with  valgrind ./GW.exe  and look
> through the output
> Thanks.
> --Junchao Zhang
> On Thu, Jan 11, 2024 at 10:49 PM Shatanawi, Sawsan Muhammad <
> Hello,
> Thank you all for your help.
> I have changed VecGetArray to VecGetArrayF90, and the location of destory
> call. but I want to make sure that VecGet ArrayF90 is to make a new array(
> vector) that I can use in the rest of my Fortran code?
> when I run it and debugged it, I got
>   5.2000000E-03
>    50.00000
>    10.00000
>   0.0000000E+00
> PETSC: Attaching gdb to
> /weka/data/lab/richey/sawsan/GW_CODE/code2024/SS_GWM/./GW.exe of pid 33065
> on display :0.0 on machine sn16
> Unable to start debugger in xterm: No such file or directory
>   0.0000000E+00
> Attempting to use an MPI routine after finalizing MPICH
> srun: error: sn16: task 0: Exited with exit code 1
> [sawsan.shatanawi at login-p2n02 SS_GWM]$ gdb ./GW/exe
> GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-100.el7
> Copyright (C) 2013 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later <
> https://urldefense.us/v3/__http://gnu.org/licenses/gpl.html__;!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46kYNzfsG$
> <https://urldefense.com/v3/__http://gnu.org/licenses/gpl.html__;!!JmPEgBY0HMszNaDT!o4qS1zaFLg2L8PlawWJVyYsJpnwYHuL6SIIZsmzTO98RCzbP26HwTi_0-ipCS_D2SBG0X4gtEnM13-nbzFEFKvtraKaM$>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-redhat-linux-gnu".
> For bug reporting instructions, please see:
> <https://urldefense.us/v3/__http://www.gnu.org/software/gdb/bugs/__;!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46ld4Xv6T$
> <https://urldefense.com/v3/__http://www.gnu.org/software/gdb/bugs/__;!!JmPEgBY0HMszNaDT!o4qS1zaFLg2L8PlawWJVyYsJpnwYHuL6SIIZsmzTO98RCzbP26HwTi_0-ipCS_D2SBG0X4gtEnM13-nbzFEFKjO8jNfs$>
> ./GW/exe: No such file or directory.
> (gdb) run
> Starting program:
> No executable file specified.
> Use the "file" or "exec-file" command.
> (gdb) bt
> No stack.
> (gdb)
> If the highlighted line is the error, I don't know why when I write gdb ,
> it does not show me the location of error
> The code : sshatanawi/SS_GWM (github.com)
> <https://urldefense.com/v3/__https://github.com/sshatanawi/SS_GWM__;!!JmPEgBY0HMszNaDT!o4qS1zaFLg2L8PlawWJVyYsJpnwYHuL6SIIZsmzTO98RCzbP26HwTi_0-ipCS_D2SBG0X4gtEnM13-nbzFEFKp8i33ur$>
> I really appreciate your helps
> Sawsan
> *Sent:* Wednesday, January 10, 2024 5:35 PM
> *Cc:* Shatanawi, Sawsan Muhammad <sawsan.shatanawi at wsu.edu>; Mark Adams <
> mfadams at lbl.gov>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *[EXTERNAL EMAIL]*
> On Jan 10, 2024, at 6:49 PM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> Hi, Sawsan,
>  I could build your code and I also could gdb it.
> $ gdb ./GW.exe
> $ Thread 1 "GW.exe" received signal SIGSEGV, Segmentation fault.
> 0x00007ffff1e6d44f in vecgetarray_ (x=0x7fffffffa718, fa=0x0,
> ia=0x7fffffffa75c, ierr=0x0) at
> /scratch/jczhang/petsc/src/vec/vec/interface/ftn-custom/zvectorf.c:257
> 257       *ierr = VecGetArray(*x, &lx);
> (gdb) bt
> #0  0x00007ffff1e6d44f in vecgetarray_ (x=0x7fffffffa718, fa=0x0,
> #1  0x000000000040b6e3 in gw_solver (t_s=1.40129846e-45, n=300) at
> GW_solver_try.F90:169
> #2  0x000000000040c6a8 in test_gw () at test_main.F90:35
> ierr=0x0  caused the segfault.  See
> https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/VecGetArray/*vecgetarray__;Iw!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46oes_GFt$
> <https://urldefense.com/v3/__https://petsc.org/release/manualpages/Vec/VecGetArray/*vecgetarray__;Iw!!JmPEgBY0HMszNaDT!tqBApprMfYxwNz4Zvnk8coNE5AeWjA9wSdAM7QJcIIVP1z0VDsVIalo4Sew2b0fW3bZtTAbPh-h0MUsZ9Km12jA$>,
> you should use VecGetArrayF90 instead.
> BTW,  Barry,  the code
> https://urldefense.us/v3/__https://github.com/sshatanawi/SS_GWM/blob/main/GW_solver_try.F90*L169__;Iw!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46i3_INb_$
> <https://urldefense.com/v3/__https://github.com/sshatanawi/SS_GWM/blob/main/GW_solver_try.F90*L169__;Iw!!JmPEgBY0HMszNaDT!tqBApprMfYxwNz4Zvnk8coNE5AeWjA9wSdAM7QJcIIVP1z0VDsVIalo4Sew2b0fW3bZtTAbPh-h0MUsZh2eAi4o$>
>  has "call VecGetArray(temp_solution, H_vector, ierr)".    I don't find
> petsc Fortran examples doing VecGetArray.  Do we still support it?
>     This is not the correct calling sequence for VecGetArray() from
> Fortran.
>     Regardless, definitely should not be writing any new code that uses
> VecGetArray() from Fortran. Should use VecGetArrayF90().
> --Junchao Zhang
> On Wed, Jan 10, 2024 at 2:38 PM Shatanawi, Sawsan Muhammad via petsc-users
> Hello all,
> I hope you are doing well.
> Generally, I use gdb <the name of my exe.file> to debug the code.
>  I got the attached error message.
> I have tried to add the flag -start_in_debugger in the make file, but it
> didn't work, so it seems I was doing it in the wrong way
> This is the link for the whole code: sshatanawi/SS_GWM (github.com)
> <https://urldefense.com/v3/__https://github.com/sshatanawi/SS_GWM__;!!JmPEgBY0HMszNaDT!tqBApprMfYxwNz4Zvnk8coNE5AeWjA9wSdAM7QJcIIVP1z0VDsVIalo4Sew2b0fW3bZtTAbPh-h0MUsZ1Veab3M$>
> GitHub - sshatanawi/SS_GWM
> Contribute to sshatanawi/SS_GWM development by creating an account on
> GitHub.
> github.com
> <https://urldefense.com/v3/__http://github.com/__;!!JmPEgBY0HMszNaDT!tqBApprMfYxwNz4Zvnk8coNE5AeWjA9wSdAM7QJcIIVP1z0VDsVIalo4Sew2b0fW3bZtTAbPh-h0MUsZ8rcrPiA$>
> You can read the description of the code in " Model Desprciption.pdf"
> the compiling file is makefile_f90 where you can find the linked code
> files
> Bests,
> Sawsan
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* Friday, January 5, 2024 4:53 AM
> *Cc:* Matthew Knepley <knepley at gmail.com>; petsc-users at mcs.anl.gov <
> *[EXTERNAL EMAIL]*
> This is a segv. As Matt said, you need to use a debugger for this or add
> print statements to narrow down the place where this happens.
> You will need to learn how to use debuggers to do your project so you
> might as well start now.
> If you have a machine with a GUI debugger that is easier but command line
> debuggers are good to learn anyway.
> I tend to run debuggers directly (eg, lldb ./a.out -- program-args ...)
> and use a GUI debugger (eg, Totalview or DDT) if available.
> Mark
> On Wed, Dec 20, 2023 at 10:02 PM Shatanawi, Sawsan Muhammad via
> petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello Matthew,
> Thank you for your help. I am sorry that I keep coming back with my error
> messages, but I reached a point that I don't know how to fix them, and I
> don't understand them easily.
> The list of errors is getting shorter, now I am getting the attached error
> messages
> Thank you again,
> Sawsan
> *Sent:* Wednesday, December 20, 2023 6:54 PM
> *[EXTERNAL EMAIL]*
> On Wed, Dec 20, 2023 at 9:49 PM Shatanawi, Sawsan Muhammad via petsc-users
> Hello Barry,
> Thank you a lot for your help, Now I am getting the attached error message.
> Do not destroy the PC from KSPGetPC()
>   THanks,
>      Matt
> Bests,
> Sawsan
> *Sent:* Wednesday, December 20, 2023 6:32 PM
> *Cc:* Mark Adams <mfadams at lbl.gov>; petsc-users at mcs.anl.gov <
> *[EXTERNAL EMAIL]*
> Instead of
>     call PCCreate(PETSC_COMM_WORLD, pc, ierr)
>     call PCSetType(pc, PCILU,ierr) ! Choose a preconditioner type (ILU)
>     call KSPSetPC(ksp, pc,ierr)  ! Associate the preconditioner with the
> KSP solver
> do
>     call KSPGetPC(ksp,pc,ierr)
> Do not call KSPSetUp(). It will be taken care of automatically during the
> solve
> On Dec 20, 2023, at 8:52 PM, Shatanawi, Sawsan Muhammad via petsc-users <
> Hello,
> I don't think that I set preallocation values when I created the matrix,
> would you please have look at my code. It is just the petsc related part
> from my code.
> I was able to fix some of the error messages. Now I have a new set of
> error messages related to the KSP solver (attached)
> I appreciate your help
> Sawsan
> *Sent:* Wednesday, December 20, 2023 6:44 AM
> *[EXTERNAL EMAIL]*
> Did you set preallocation values when you created the matrix?
> Don't do that.
> On Wed, Dec 20, 2023 at 9:36 AM Shatanawi, Sawsan Muhammad <
> Hello,
> I am trying to create a sparse matrix( which is as I believe a zero
> matrix) then adding some nonzero elements to it over a loop, then
> assembling it
> Get Outlook for iOS
> <https://urldefense.com/v3/__https://aka.ms/o0ukef__;!!JmPEgBY0HMszNaDT!uUJ_jeYf45gcXDGR_PeMjhU7hbd_fKcXJPn0pM9eb-YQihKNYuXMYM9x-hglsbXsCFIwNBWgHXdetHODupsOloE$>
> *Sent:* Wednesday, December 20, 2023 2:48 AM
> *[EXTERNAL EMAIL]*
> I am guessing that you are creating a matrix, adding to it, finalizing it
> ("assembly"), and then adding to it again, which is fine, but you are
> adding new non-zeros to the sparsity pattern.
> If this is what you want then you can tell the matrix to let you do that.
> Otherwise you have a bug.
> Mark
> On Tue, Dec 19, 2023 at 9:50 PM Shatanawi, Sawsan Muhammad via petsc-users
> Hello everyone,
>  My Name is Sawsan Shatanawi, and I am currently working on developing a
> Fortran code for simulating groundwater flow in a 3D system. The code
> involves solving a nonlinear system, and I have created the matrix to be
> solved using the PCG solver and Picard iteration. However, when I tried
> to assign it as a PETSc matrix I started getting a lot of error messages.
> I am kindly asking if someone can help me, I would be happy to share my
> code with him/her.
> Please find the attached file contains a list of errors I have gotten
> Thank you in advance for your time and assistance.
> Best regards,
>  Sawsan
> <Matrix_RHS.F90><out.txt><solver.F90>
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46kPxN7eB$
> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!JmPEgBY0HMszNaDT!uskvAyF0pMMWDbMIexr9g4qN46V7Rea17GQdNIVG2vH_HMaX7mXgie4ZYgusmPpss_DS7H1_8vn8arGQNSkC$>
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!JmPEgBY0HMszNaDT!uQ_CqaGbVrhAwdolHoSQABYOvUa_lcGbqSBo0R5vr6xf8cZbIdMji6gOsfHzJJg2Rl4pB9RLvcxAdNkAkI3m$>
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!JmPEgBY0HMszNaDT!smICTGbSXrPHqMB6bHUNt1_rI9gtQR9Hw4rx7P_iIWaRDqYgwdFTHh8UL1N_9qHLFXbfPt2JZyat1djSVOuC$>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46kPxN7eB$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!an0a5TBb_2F0Yl9de3r2Rr5Lde7DTjTZJaHL4BLVhBks6EHjOrKhtOsm9NFyMydeBwa6UGgfAXF46vRpHBJ4$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240518/c6c9e364/attachment-0001.html>
