[petsc-users] About PC hpddm
Ng, Cho-Kuen cho at slac.stanford.edu
Wed May 8 23:31:04 CDT 2024
I used spack to install petsc with hpddm as follows.
o spack install petsc+hpddm
o spack install slepc ^petsc+hpddm
I got the following runtime error of finding the library hpddm_petsc.
argv0 -ksp_converged_reason -ksp_view_final_residual -ksp_type gmres -pc_type hpddm -ksp_monitor -log_view -options_left -device_view
$$$$$$$$$$$$$$ buildmatrix petsc
[6]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[6]PETSC ERROR: Petsc has generated inconsistent data
[6]PETSC ERROR: /global/cfs/cdirs/ace3p/software/spack/var/spack/environments/demo1/.spack-env/view/lib/libhpddm_petsc not found
Is there something wrong with the install procedure?
Cho
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240509/7d36e09f/attachment-0001.html>
