[petsc-users] Fortran Linker Issue on Mac Sonoma
William Thacher
wthacher at lbl.gov
Mon May 6 21:02:44 CDT 2024
Hello,
I am encountering an issue when configuring/building PETSc on a Mac with
Sonoma 14.4.1. Here are the exact steps I have performed so far:
1. Pulled the most recent release of PETSc
2. Ran "./configure --ignoreLinkOutput=1 LDFLAGS=-Wl,-ld_classic"
In the configuration process (line 2518 of attached configure.log) it looks
like there is a linker error when testing the fortran compiler. (I get the
same error if I just run ./configure)
If I run the make command given after running step 2. above, the C/C++ code
builds fine, but I would also like to build the Fortran code.
Have you all seen this error before on Mac Sonoma/have any ideas for a
workaround?
I installed open-mpi through Homebrew and upgraded before building PETSc.
Appreciate the help,
Will
Will Thacher
Graduate Student Researcher, Lawrence Berkeley National Lab
PhD Student, Applied Science and Technology Group, UC Berkeley
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240506/79f9d5c7/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240506/79f9d5c7/attachment-0001.obj>
