[petsc-users] PETSc options
Adrian Croucher a.croucher at auckland.ac.nz
Mon May 6 18:46:30 CDT 2024
On 7/05/24 1:11 am, Barry Smith wrote:
>    Yes, just call PetscOptionsHasName() with -v and ignore the result.
Thanks Barry, that does the trick. Yes, I was using PETSc <3.19 before
which is why it didn't show up until now.
- Adrian
>> On Mon, May 6, 2024 at 1:04 AM Adrian Croucher
>> <a.croucher at auckland.ac.nz> wrote:
>>     hi,
>>     My code has some optional command line arguments -v and -h for output of
>>     version number and usage help. These are processed using Fortran's
>>     get_command_argument().
>>     Since updating PETSc to version 3.21, I get some extra warnings after
>>     the output:
>>     acro018 at EN438880:~$ waiwera -v
>>     1.5.0b1
>>     WARNING! There are options you set that were not used!
>>     WARNING! could be spelling mistake, etc!
>>     There is one unused database option. It is:
>>     Option left: name:-v (no value) source: command line
>>     That didn't used to happen. What should I do to make them go away?
>>     Regards, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
Waipapa Taumata Rau / University of Auckland, New Zealand
email:a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240507/15eed5de/attachment.html>
