[petsc-users] PETSc options
Barry Smith
bsmith at petsc.dev
Mon May 6 08:11:51 CDT 2024
> On May 6, 2024, at 8:38 AM, Mark Adams <mfadams at lbl.gov> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> I don't know why this should have changed, but you can either not feed -v to PETSc (a pain probably), use PETSc's getOptions methods instead of Fortran's, or make a dummy call PETSc's methods in addition to yours.
Yes, just call PetscOptionsHasName() with -v and ignore the result.
> Hope this helps,
> Mark
> On Mon, May 6, 2024 at 1:04 AM Adrian Croucher <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
>> hi,
>> My code has some optional command line arguments -v and -h for output of
>> version number and usage help. These are processed using Fortran's
>> get_command_argument().
>> Since updating PETSc to version 3.21, I get some extra warnings after
>> the output:
>> acro018 at EN438880:~$ waiwera -v
>> 1.5.0b1
>> WARNING! There are options you set that were not used!
>> WARNING! could be spelling mistake, etc!
>> There is one unused database option. It is:
>> Option left: name:-v (no value) source: command line
>> That didn't used to happen. What should I do to make them go away?
>> Regards, Adrian
>> Dr Adrian Croucher
>> Senior Research Fellow
>> Department of Engineering Science
>> Waipapa Taumata Rau / University of Auckland, New Zealand
>> email: a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>
>> tel: +64 (0)9 923 4611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240506/61015345/attachment-0001.html>
