[petsc-users] PETSc options
Matthew Knepley
knepley at gmail.com
Mon May 6 10:30:10 CDT 2024
On Mon, May 6, 2024 at 11:15 AM Pierre Jolivet <pierre at joliv.et> wrote:
> On 6 May 2024, at 3:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> On Mon, May 6, 2024 at 1:04 AM Adrian Croucher <a.croucher at auckland.ac.nz>
>> hi,
>> My code has some optional command line arguments -v and -h for output of
>> version number and usage help. These are processed using Fortran's
>> get_command_argument().
>> Since updating PETSc to version 3.21, I get some extra warnings after
>> the output:
>> acro018 at EN438880:~$ waiwera -v
>> 1.5.0b1
>> WARNING! There are options you set that were not used!
>> WARNING! could be spelling mistake, etc!
>> There is one unused database option. It is:
>> Option left: name:-v (no value) source: command line
>> That didn't used to happen. What should I do to make them go away?
> Hi Adrian,
> Barry and Mark's suggestions will make this go away. However, it should
> not happen
> in the first place.
> It should happen if Adrian was previously not using 3.19.X or below.
> See https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/6601__;!!G_uCfscf7eWS!bVUciSLxU1Cw3mv04eO2KtlHR8v6ZR7CRE_CpMzmxmCn4x58fUdEJ4L-dknPq_yMbgnc9OkN_O8aOSu_aPK3$
I forgot. Not my favorite change.
Okay. You can shut this off using
PetscCall(PetscOptionsSetValue(NULL, "-options_left", "0"))
Matt
> Thanks,
> Pierre
> We should try to figure this out.
> This warning is usually activated by the -options_left argument. Could
> that be in the
> PETSC_OPTIONS env variable, or in ~/.petscrc?
> Thanks,
> Matt
>> Regards, Adrian
>> Dr Adrian Croucher
>> Senior Research Fellow
>> Department of Engineering Science
>> Waipapa Taumata Rau / University of Auckland, New Zealand
>> email: a.croucher at auckland.ac.nz
>> tel: +64 (0)9 923 4611
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bVUciSLxU1Cw3mv04eO2KtlHR8v6ZR7CRE_CpMzmxmCn4x58fUdEJ4L-dknPq_yMbgnc9OkN_O8aOQZGyQDX$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fo7-rCLfudbdd6yHxfeF1pyKANLJjDLd2VvUtM7xc31s9AoJjSSu-vjiyaVVAhNAqV6c4s-9aJPkL3lFP1DF$>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bVUciSLxU1Cw3mv04eO2KtlHR8v6ZR7CRE_CpMzmxmCn4x58fUdEJ4L-dknPq_yMbgnc9OkN_O8aOQZGyQDX$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bVUciSLxU1Cw3mv04eO2KtlHR8v6ZR7CRE_CpMzmxmCn4x58fUdEJ4L-dknPq_yMbgnc9OkN_O8aOXbl1p93$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240506/b8f0c510/attachment.html>
