[petsc-users] PETSc options
Pierre Jolivet pierre at joliv.et
Mon May 6 10:15:35 CDT 2024
> On 6 May 2024, at 3:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> On Mon, May 6, 2024 at 1:04 AM Adrian Croucher <a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>> wrote:
>> hi,
>> My code has some optional command line arguments -v and -h for output of
>> version number and usage help. These are processed using Fortran's
>> get_command_argument().
>> Since updating PETSc to version 3.21, I get some extra warnings after
>> the output:
>> acro018 at EN438880:~$ waiwera -v
>> 1.5.0b1
>> WARNING! There are options you set that were not used!
>> WARNING! could be spelling mistake, etc!
>> There is one unused database option. It is:
>> Option left: name:-v (no value) source: command line
>> That didn't used to happen. What should I do to make them go away?
> Hi Adrian,
> Barry and Mark's suggestions will make this go away. However, it should not happen
> in the first place.
It should happen if Adrian was previously not using 3.19.X or below.
See https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/6601__;!!G_uCfscf7eWS!ZTd_vYQ25gBqyomaus8Y3ZvnKjc8AdhWKmEE3UIP1XKXce16F5mXog_qr60phhd9LqIo6_dzVSLpfzONhaDkQA$
Pierre
> We should try to figure this out.
> This warning is usually activated by the -options_left argument. Could that be in the
> PETSC_OPTIONS env variable, or in ~/.petscrc?
>   Thanks,
>      Matt
>> Regards, Adrian
>> Dr Adrian Croucher
>> Senior Research Fellow
>> Department of Engineering Science
>> Waipapa Taumata Rau / University of Auckland, New Zealand
>> email: a.croucher at auckland.ac.nz <mailto:a.croucher at auckland.ac.nz>
>> tel: +64 (0)9 923 4611
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ZTd_vYQ25gBqyomaus8Y3ZvnKjc8AdhWKmEE3UIP1XKXce16F5mXog_qr60phhd9LqIo6_dzVSLpfzNkK3KD_g$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fo7-rCLfudbdd6yHxfeF1pyKANLJjDLd2VvUtM7xc31s9AoJjSSu-vjiyaVVAhNAqV6c4s-9aJPkL3lFP1DF$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240506/278670ba/attachment-0001.html>
