[petsc-users] Install PETSc with option `--with-shared-libraries=1` failed on MacOS
Zongze Yang yangzongze at gmail.com
Sun Mar 17 08:58:01 CDT 2024
Adding the flag `--download-openblas-make-options=TARGET=GENERIC` did not resolve the issue. The same error persisted.
Best wishes,
Zongze
> On 17 Mar 2024, at 20:58, Pierre Jolivet <pierre at joliv.et> wrote:
>> On 17 Mar 2024, at 1:04 PM, Zongze Yang <yangzongze at gmail.com> wrote:
>> Thank you for providing the instructions. I try the first option.
>> Now, the error of the configuration is related to OpenBLAS.
>> Add `--CFLAGS=-Wno-int-conversion` to configure command resolve this. Should this be reported to OpenBLAS? Or need to fix the configure in petsc?
> I see our linux-opt-arm runner is using the additional flag '--download-openblas-make-options=TARGET=GENERIC', could you maybe try to add that as well?
> I don’t think there is much to fix on our end, OpenBLAS has been very broken lately on arm (current version is 0.3.26 but we can’t update because there is a huge performance regression which makes the pipeline timeout).
> Thanks,
> Pierre
>> The configure.log is attached. The errors are show below:
>>     src/lapack_wrappers.c:570:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
>>         RELAPACK_sgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
>>     src/../inc/relapack.h:74:216: note: passing argument to parameter here
>>     void RELAPACK_sgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const float *, const float *, const blasint *, const float *, const blasint *, const float *, float *, const blasint *);
>>     src/lapack_wrappers.c:583:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
>>         RELAPACK_dgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
>>     src/../inc/relapack.h:75:221: note: passing argument to parameter here
>>     void RELAPACK_dgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const double *, const double *, const blasint *, const double *, const blasint *, const double *, double *, const blasint *);
>>     src/lapack_wrappers.c:596:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
>>         RELAPACK_cgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
>>     src/../inc/relapack.h:76:216: note: passing argument to parameter here
>>     void RELAPACK_cgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const float *, const float *, const blasint *, const float *, const blasint *, const float *, float *, const blasint *);
>>     src/lapack_wrappers.c:609:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
>>         RELAPACK_zgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
>>     src/../inc/relapack.h:77:221: note: passing argument to parameter here
>>     void RELAPACK_zgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const double *, const double *, const blasint *, const double *, const blasint *, const double *, double *, const blasint *);
>>     4 errors generated.
>> Best wishes,
>> Zongze
>> <configure.log.tar.gz>
>>> On 17 Mar 2024, at 18:48, Pierre Jolivet <pierre at joliv.et> wrote:
>>> You need this MR https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7365__;!!G_uCfscf7eWS!eCQRfbol7FDQiO0o78iDit2saij_ydIUtCfRQnsQAt-h_YcXr2Yi2BFnFnqHZp0FO3Lhpyr2RKdHZ-T-OF94HpwQ$
>>> main has been broken for macOS since https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7341__;!!G_uCfscf7eWS!eCQRfbol7FDQiO0o78iDit2saij_ydIUtCfRQnsQAt-h_YcXr2Yi2BFnFnqHZp0FO3Lhpyr2RKdHZ-T-OIhlJwLx$ , so the alternative is to revert to the commit prior.
>>> It should work either way.
>>> Thanks,
>>> Pierre
>>>> On 17 Mar 2024, at 11:31 AM, Zongze Yang <yangzongze at gmail.com <mailto:yangzongze at gmail.com>> wrote:
>>>> This Message Is From an External Sender
>>>> This message came from outside your organization.
>>>> Hi, PETSc Team,
>>>> I am trying to install petsc with the following configuration
>>>> ./configure \
>>>>     --download-bison \
>>>>     --download-mpich \
>>>>     --download-mpich-configure-arguments=--disable-opencl \
>>>>     --download-hwloc \
>>>>     --download-hwloc-configure-arguments=--disable-opencl \
>>>>     --download-openblas \
>>>>     --download-openblas-make-options="'USE_THREAD=0 USE_LOCKING=1 USE_OPENMP=0'" \
>>>>     --with-shared-libraries=1 \
>>>>     --with-fortran-bindings=0 \
>>>>     --with-zlib \
>>>>     LDFLAGS=-Wl,-ld_classic
>>>> The log shows that
>>>>    Exhausted all shared linker guesses. Could not determine how to create a shared library!
>>>> I recently updated the system and Xcode, as well as homebrew.
>>>> Thanks for your attention to this matter.
>>>> Best wishes,
>>>> Zongze
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240317/2ea6b9e6/attachment-0001.html>
