[petsc-users] Install PETSc with option `--with-shared-libraries=1` failed on MacOS
Zongze Yang
yangzongze at gmail.com
Sun Mar 17 07:04:21 CDT 2024
Thank you for providing the instructions. I try the first option.
Now, the error of the configuration is related to OpenBLAS.
Add `--CFLAGS=-Wno-int-conversion` to configure command resolve this. Should this be reported to OpenBLAS? Or need to fix the configure in petsc?
The configure.log is attached. The errors are show below:
src/lapack_wrappers.c:570:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
RELAPACK_sgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
src/../inc/relapack.h:74:216: note: passing argument to parameter here
void RELAPACK_sgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const float *, const float *, const blasint *, const float *, const blasint *, const float *, float *, const blasint *);
src/lapack_wrappers.c:583:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
RELAPACK_dgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
src/../inc/relapack.h:75:221: note: passing argument to parameter here
void RELAPACK_dgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const double *, const double *, const blasint *, const double *, const blasint *, const double *, double *, const blasint *);
src/lapack_wrappers.c:596:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
RELAPACK_cgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
src/../inc/relapack.h:76:216: note: passing argument to parameter here
void RELAPACK_cgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const float *, const float *, const blasint *, const float *, const blasint *, const float *, float *, const blasint *);
src/lapack_wrappers.c:609:81: error: incompatible integer to pointer conversion passing 'blasint' (aka 'int') to parameter of type 'const blasint *' (aka 'const int *'); take the address with & [-Wint-conversion]
RELAPACK_zgemmt(uplo, transA, transB, n, k, alpha, A, ldA, B, ldB, beta, C, info);
src/../inc/relapack.h:77:221: note: passing argument to parameter here
void RELAPACK_zgemmt(const char *, const char *, const char *, const blasint *, const blasint *, const double *, const double *, const blasint *, const double *, const blasint *, const double *, double *, const blasint *);
4 errors generated.
Best wishes,
Zongze
> On 17 Mar 2024, at 18:48, Pierre Jolivet <pierre at joliv.et> wrote:
> You need this MR https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7365__;!!G_uCfscf7eWS!bUnys903wnuB3NvLnoQEH8iD_BqwKe6SWm2uXtRSRIFro2s8QswVwytOJP_iJvq_VnGlbXXsz234SXVcQ8zhJ-WC$
> main has been broken for macOS since https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/7341__;!!G_uCfscf7eWS!bUnys903wnuB3NvLnoQEH8iD_BqwKe6SWm2uXtRSRIFro2s8QswVwytOJP_iJvq_VnGlbXXsz234SXVcQ2Q2MLSV$ , so the alternative is to revert to the commit prior.
> It should work either way.
> Thanks,
> Pierre
>> On 17 Mar 2024, at 11:31 AM, Zongze Yang <yangzongze at gmail.com <mailto:yangzongze at gmail.com>> wrote:
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> Hi, PETSc Team,
>> I am trying to install petsc with the following configuration
>> ./configure \
>> --download-bison \
>> --download-mpich \
>> --download-mpich-configure-arguments=--disable-opencl \
>> --download-hwloc \
>> --download-hwloc-configure-arguments=--disable-opencl \
>> --download-openblas \
>> --download-openblas-make-options="'USE_THREAD=0 USE_LOCKING=1 USE_OPENMP=0'" \
>> --with-shared-libraries=1 \
>> --with-fortran-bindings=0 \
>> --with-zlib \
>> LDFLAGS=-Wl,-ld_classic
>> The log shows that
>> Exhausted all shared linker guesses. Could not determine how to create a shared library!
>> I recently updated the system and Xcode, as well as homebrew.
>> Thanks for your attention to this matter.
>> Best wishes,
>> Zongze
>> <configure.log.tar.gz>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240317/eb4fd732/attachment-0002.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240317/eb4fd732/attachment-0001.gz>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240317/eb4fd732/attachment-0003.html>
