[petsc-users] Help Needed Debugging Installation Issue for PETSc with SLEPc
Zongze Yang yangzongze at gmail.com
Fri Mar 15 09:56:09 CDT 2024
Thanks very much!
Best wishes,
Zongze
> On 15 Mar 2024, at 22:50, Pierre Jolivet <pierre at joliv.et> wrote:
> This was fixed 5 days ago in https://urldefense.us/v3/__https://gitlab.com/slepc/slepc/-/merge_requests/638__;!!G_uCfscf7eWS!fPbzaiH98Qdihq74E8kcX8JQE_EGk_PhMqYnheGPjwJD2l8AhgXg3ZrEkFZmV0lfG8vVlKawhAaQq4eSMRZVffeF$ , so you need to use an up-to-date release branch of SLEPc.
> Thanks,
> Pierre
>> On 15 Mar 2024, at 3:44 PM, Zongze Yang <yangzongze at gmail.com> wrote:
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> Hi,
>> I am currently facing an issue while attempting to install PETSc with SLEPc. Despite not encountering any errors in the log generated by the 'make' command, I am receiving an error message stating "Error during compile".
>> I would greatly appreciate it if someone could provide me with some guidance on debugging this issue.
>> I have attached the configure logs and make logs for both PETSc and SLEPc for your reference.
>> Below is an excerpt from the make.log file of SLEPc:
>>     CLINKER default/lib/libslepc.3.020.1.dylib
>> ld: warning: -commons use_dylibs is no longer supported, using error treatment instead
>> ld: warning: duplicate -rpath '/Users/zzyang/opt/firedrake/firedrake-real-int32-debug/src/petsc/default/lib' ignored
>> ld: warning: dylib (/opt/homebrew/Cellar/gcc/13.2.0/lib/gcc/current/libgfortran.dylib) was built for newer macOS version (14.0) than being linked (12.0)
>> ld: warning: dylib (/opt/homebrew/Cellar/gcc/13.2.0/lib/gcc/current/libquadmath.dylib) was built for newer macOS version (14.0) than being linked (12.0)
>>    DSYMUTIL default/lib/libslepc.3.020.1.dylib
>> gmake[6]: Leaving directory '/Users/zzyang/opt/firedrake/firedrake-real-int32-debug/src/petsc/default/externalpackages/git.slepc'
>> gmake[5]: Leaving directory '/Users/zzyang/opt/firedrake/firedrake-real-int32-debug/src/petsc/default/externalpackages/git.slepc'
>> *******************************ERROR************************************
>>  Error during compile, check default/lib/slepc/conf/make.log
>>  Send all contents of ./default/lib/slepc/conf to slepc-maint at upv.es <mailto:slepc-maint at upv.es>
>> Finishing make run at 五, 15  3 2024 21:04:17 +0800
>> Thank you very much for your attention and support.
>> Best wishes,
>> Zongze
>> <logs.tar.gz>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240315/599e250b/attachment-0001.html>
