[petsc-users] Help Needed Debugging Installation Issue for PETSc with SLEPc
Pierre Jolivet
pierre at joliv.et
Fri Mar 15 09:50:44 CDT 2024
This was fixed 5 days ago in https://urldefense.us/v3/__https://gitlab.com/slepc/slepc/-/merge_requests/638__;!!G_uCfscf7eWS!Z6nHLo3qh8bAe4zTIkJHhBcLc2WyVfPb47nBF38kwu8pyoNFz11wVdiL2ytUg66oHoVPkjBafopf_Gag8j6dXQ$ , so you need to use an up-to-date release branch of SLEPc.
Pierre
> On 15 Mar 2024, at 3:44 PM, Zongze Yang <yangzongze at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Hi,
> I am currently facing an issue while attempting to install PETSc with SLEPc. Despite not encountering any errors in the log generated by the 'make' command, I am receiving an error message stating "Error during compile".
> I would greatly appreciate it if someone could provide me with some guidance on debugging this issue.
> I have attached the configure logs and make logs for both PETSc and SLEPc for your reference.
> Below is an excerpt from the make.log file of SLEPc:
> CLINKER default/lib/libslepc.3.020.1.dylib
> ld: warning: -commons use_dylibs is no longer supported, using error treatment instead
> ld: warning: duplicate -rpath '/Users/zzyang/opt/firedrake/firedrake-real-int32-debug/src/petsc/default/lib' ignored
> ld: warning: dylib (/opt/homebrew/Cellar/gcc/13.2.0/lib/gcc/current/libgfortran.dylib) was built for newer macOS version (14.0) than being linked (12.0)
> ld: warning: dylib (/opt/homebrew/Cellar/gcc/13.2.0/lib/gcc/current/libquadmath.dylib) was built for newer macOS version (14.0) than being linked (12.0)
> DSYMUTIL default/lib/libslepc.3.020.1.dylib
> gmake[6]: Leaving directory '/Users/zzyang/opt/firedrake/firedrake-real-int32-debug/src/petsc/default/externalpackages/git.slepc'
> gmake[5]: Leaving directory '/Users/zzyang/opt/firedrake/firedrake-real-int32-debug/src/petsc/default/externalpackages/git.slepc'
> *******************************ERROR************************************
> Error during compile, check default/lib/slepc/conf/make.log
> Send all contents of ./default/lib/slepc/conf to slepc-maint at upv.es <mailto:slepc-maint at upv.es>
> Finishing make run at 五, 15 3 2024 21:04:17 +0800
> Thank you very much for your attention and support.
> Best wishes,
> Zongze
> <logs.tar.gz>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240315/93d6463b/attachment-0001.html>
