[petsc-users] Unconstrained optimization question
Palmer, Bruce J
Bruce.Palmer at pnnl.gov
Wed Jun 26 16:48:11 CDT 2024
This is a fortran code that doesn’t make use of argc,argv (I tried running with the runtime options anyway, in case you implemented some magic I’m not familiar with, but didn’t see anything new in the output). I have a call to TaoView(tao, PETSC_VIEWER_STDOUT_SELF,ierr) in the code and it reports back
Tao Object: 1 MPI process
type: cg
CG Type: prp
Gradient steps: 0
Reset steps: 0
TaoLineSearch Object: 1 MPI process
type: more-thuente
maximum function evaluations=30
tolerances: ftol=0.0001, rtol=1e-10, gtol=0.9
total number of function evaluations=0
total number of gradient evaluations=0
total number of function/gradient evaluations=0
Termination reason: 0
convergence tolerances: gatol=1e-08, steptol=0., gttol=0.
Residual in Function/Gradient:=7.54237e+75
Objective value=2.96082e+86
total number of iterations=0, (max: 100)
total number of function/gradient evaluations=1, (max: 4000)
Solution converged: ||g(X)||/|f(X)| <= grtol
Bruce
Date: Wednesday, June 26, 2024 at 2:02 PM
To: Palmer, Bruce J <Bruce.Palmer at pnnl.gov>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Unconstrained optimization question
Check twice before you click! This email originated from outside PNNL.
Please run with -tao_monitor -tao_converged_reason and see why it has stopped.
Barry
On Jun 26, 2024, at 4:34 PM, Palmer, Bruce J via petsc-users <petsc-users at mcs.anl.gov> wrote:
This Message Is From an External Sender
This message came from outside your organization.
I’m trying to do an unconstrained optimization on a molecular scale problem. Previously, I was looking at an artificial molecular problem where all parameters were of order 1 and so the objective function and variables were also in the range of 1 or at least within a few orders of magnitude of 1.
More recently, I’ve been trying to apply this optimization to a real molecular system. Between Avogadro’s number (6.022e23) and Boltzmann’s constant (1.38e-16) combined with very small distances (1.0e-8 cm), etc. the objective function values and the values of the optimization variables have very large values (~1e86 and ~1e9, respectively). I’ve verified that the analytic gradients of the objective function that I’m calculating are correct by comparing them with numerical derivatives.
I’ve tried using the LMVM and Conjugate Gradient optimizations, both of which worked previously, but I find that the optimization completes one objective function evaluation and then declares that the problem is converged and stops. I could find a set of units where everything is approximately 1 but I was hoping that there are some parameters I can set in the optimization that will get it moving again. Any suggestions?
Bruce Palmer
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240626/818530a3/attachment.html>
