[petsc-users] Unconstrained optimization question
Barry Smith bsmith at petsc.dev
Wed Jun 26 16:02:19 CDT 2024
  Please run with -tao_monitor -tao_converged_reason and see why it has stopped.
  Barry
> On Jun 26, 2024, at 4:34 PM, Palmer, Bruce J via petsc-users <petsc-users at mcs.anl.gov> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Hi,
> I’m trying to do an unconstrained optimization on a molecular scale problem. Previously, I was looking at an artificial molecular problem where all parameters were of order 1 and so the objective function and variables were also in the range of 1 or at least within a few orders of magnitude of 1.
> More recently, I’ve been trying to apply this optimization to a real molecular system. Between Avogadro’s number (6.022e23) and Boltzmann’s constant (1.38e-16) combined with very small distances (1.0e-8 cm), etc. the objective function values and the values of the optimization variables have very large values (~1e86 and ~1e9, respectively). I’ve verified that the analytic gradients of the objective function that I’m calculating are correct by comparing them with numerical derivatives.
> I’ve tried using the LMVM and Conjugate Gradient optimizations, both of which worked previously, but I find that the optimization completes one objective function evaluation and then declares that the problem is converged and stops. I could find a set of units where everything is approximately 1 but I was hoping that there are some parameters I can set in the optimization that will get it moving again. Any suggestions?
> Bruce Palmer
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240626/05f244ce/attachment-0001.html>
