[petsc-users] [EXTERNAL] Re: Running PETSc with a Kokkos backend on OLCF Frontier
Sircar, Arpan sircara at ornl.gov
Fri Jun 14 14:44:51 CDT 2024
Hi Junchao and Barry,
I tried adding -log_view to my OpenFOAM command since that is what I am running the entire package through. However, it does not recognize that as a valid option. I am not sure where to put that tag in this setup.
I am however using a Kokkos profiling tool, the output of which (for the GPU run) is attached with this email. Do let me know if this is useful or if you have ideas of where to put the -log_view tag.
Junchao - Great nice running into you here.
Arpan
Sent: Friday, June 14, 2024 3:16 PM
To: Sircar, Arpan <sircara at ornl.gov>
Cc: Barry Smith <bsmith at petsc.dev>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Gottiparthi, Kalyan <gottiparthik at ornl.gov>
Subject: Re: [petsc-users] [EXTERNAL] Re: Running PETSc with a Kokkos backend on OLCF Frontier
Arpan,
   Did you add -log_view ?
--Junchao Zhang
On Fri, Jun 14, 2024 at 2:00 PM Sircar, Arpan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hi Barry, Thanks for your prompt response. These are run with with the same PETSc solvers but the one on GPUs (log_pKok) uses mataijkokkos while the other one does not. Please let me know if you need any other information. Thanks, Arpan From: 
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hi Barry,
Arpan
From: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Sent: Friday, June 14, 2024 1:47 PM
To: Sircar, Arpan <sircara at ornl.gov<mailto:sircara at ornl.gov>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Gottiparthi, Kalyan <gottiparthik at ornl.gov<mailto:gottiparthik at ornl.gov>>
Subject: [EXTERNAL] Re: [petsc-users] Running PETSc with a Kokkos backend on OLCF Frontier
   Please run both the CPU solvers and GPU solvers cases with -log_view and send the two outputs.
   Barry
On Jun 14, 2024, at 1:35 PM, Sircar, Arpan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
We have been working with OpenFOAM (an open-source CFD software) which can transfer its matrices to PETSc to use its linear solvers. This has been tested and is working well on OCLF's Frontier machine. Next we are trying to use the Kokkos backend to run it on Frontier GPUs. While the OpenFOAM+PETSc+Kokkos environment built correctly on Frontier using the modules sourced (attached file bash_petsc4foam_gpu) and configuring PETSc correctly (attached file config_gpu), the GPU solve seems to take more time than the CPU solve.
The PETSc run-time options we are using are attached to this email (file fvSolution_petsc_pKok_Uof). Could you please take a look  and let us know if this combination of options is fine? In this approach we are trying to solve the pressure equation only on the GPUs.
Arpan
Arpan Sircar
R&D Associate Staff
Thermal Hydraulics Group
Nuclear Energy and Fuel Cycle Division
Oak Ridge National Laboratory
<fvSolution_petsc_pKok_Uof><bash_petsc4foam_gpu><config_gpu>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240614/dec25652/attachment-0001.html>
Desc: log.kok
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240614/dec25652/attachment-0001.obj>
