[petsc-users] [EXTERNAL] Re: Running PETSc with a Kokkos backend on OLCF Frontier
Junchao Zhang junchao.zhang at gmail.com
Fri Jun 14 14:16:20 CDT 2024
Arpan,
   Did you add -log_view ?
--Junchao Zhang
On Fri, Jun 14, 2024 at 2:00 PM Sircar, Arpan via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi Barry, Thanks for your prompt response. These are run with with the
> same PETSc solvers but the one on GPUs (log_pKok) uses mataijkokkos while
> the other one does not. Please let me know if you need any other
> information. Thanks, Arpan From:
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> Hi Barry,
> Thanks for your prompt response. These are run with with the same PETSc
> solvers but the one on GPUs (log_pKok) uses mataijkokkos while the other
> one does not.
> Please let me know if you need any other information.
> Thanks,
> Arpan
> *From:* Barry Smith <bsmith at petsc.dev>
> *Sent:* Friday, June 14, 2024 1:47 PM
> *To:* Sircar, Arpan <sircara at ornl.gov>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Gottiparthi,
> Kalyan <gottiparthik at ornl.gov>
> *Subject:* [EXTERNAL] Re: [petsc-users] Running PETSc with a Kokkos
>    Please run both the CPU solvers and GPU solvers cases with -log_view
> and send the two outputs.
>    Barry
> On Jun 14, 2024, at 1:35 PM, Sircar, Arpan via petsc-users <
> Hi,
> We have been working with OpenFOAM (an open-source CFD software) which can
> transfer its matrices to PETSc to use its linear solvers. This has been
> tested and is working well on OCLF's Frontier machine. Next we are trying
> to use the Kokkos backend to run it on Frontier GPUs. While the
> OpenFOAM+PETSc+Kokkos environment built correctly on Frontier using the
> modules sourced (attached file *bash_petsc4foam_gpu*) and configuring
> PETSc correctly (attached file *config_gpu*), the GPU solve seems to take
> more time than the CPU solve.
> The PETSc run-time options we are using are attached to this email (file
> *fvSolution_petsc_pKok_Uof*). Could you please take a look  and let us
> know if this combination of options is fine? In this approach we are trying
> to solve the pressure equation only on the GPUs.
> Thanks,
> Arpan
> *Arpan Sircar*
> R&D Associate Staff
> Thermal Hydraulics Group
> Nuclear Energy and Fuel Cycle Division
> *Oak Ridge National Laboratory*
> <fvSolution_petsc_pKok_Uof><bash_petsc4foam_gpu><config_gpu>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240614/302eadd2/attachment.html>
