[petsc-users] Error in PETSc configuration on Mac Sonoma
Barry Smith bsmith at petsc.dev
Tue Jun 11 21:10:45 CDT 2024
   The issue is here
configure:31815: /Users/danyangsu/Soft/PETSc/petsc-3.20.5/macos-gnu-opt/bin/mpif90 -o conftest -I.  -ffree-line-length-none -ffree-line-length-0 -Wno-lto-type-mismatch -g -O -fallow-argument-mismatch    conftest.f90 -ldl -lm  >&5
ld: warning: -commons use_dylibs is no longer supported, using error treatment instead
ld: common symbol '_mpifcmb5_' from '/private/var/folders/jm/wcm4mv8s3v1gqz383tcf_4c00000gp/T/ccqBB7yf.o' conflicts with definition from dylib '_mpifcmb5_' from '/Users/danyangsu/Soft/PETSc/petsc-3.20.5/macos-gnu-opt/lib/libmpifort.12.dylib'
Perhaps someone has the fix.
> On Jun 11, 2024, at 9:05 PM, Danyang Su <danyang.su at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear All,
> I recently upgraded my MacOS to Sonoma and found some issue in PETSc configuration, which does not occur before. The main issue is from hdf5 fortran binding. It’s more likely something is broken after system upgrade, but not clear which part.
> Any suggestions?
> Thanks and regards,
> Danyang
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240611/af0833f3/attachment-0001.html>
