[petsc-users] About the complex version of gmres.
Barry Smith
bsmith at petsc.dev
Fri Jun 7 21:12:11 CDT 2024
If I run with -pc_type lu it solves the system
If I run with the default (ILU) -ksp_monitor_true_residual -ksp_converged_reason it does not converge. In fact, it makes no real progress to the solution.
It is always important to use KSPGetConvergedReason() or -ksp_converged_reason or -ksp_error_if_not_converged to check that the solver has actually converged.
If I run with -ksp_gmres_restart 100 it converges in 75 iterations.
Barry
> On Jun 7, 2024, at 8:03 PM, neil liu <liufield at gmail.com> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Dear Petsc developers,
> I am using Petsc to solve a complex system ,AX=B.
> A is complex and B is real.
> And the petsc was configured with
> Configure options --download-mpich --download-fblaslapack=1 --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-triangle --with-scalar-type=complex
> A and B were also imported to matlab and the same system was solved.
> The direct and iterative solver in matlab give the same result, which are quite different from the result from Petsc.
> A and B are attached. x from petsc is also attached. I am using only one processor.
> It is weird.
> Thanks a lot.
> Xiaodong
> <A.m><xPetsc.m><B.m>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240607/8cd9003f/attachment-0001.html>
