[petsc-users] About the complex version of gmres.
neil liu
liufield at gmail.com
Fri Jun 7 19:03:27 CDT 2024
Dear Petsc developers,
I am using Petsc to solve a complex system ,AX=B.
A is complex and B is real.
And the petsc was configured with
Configure options --download-mpich --download-fblaslapack=1 --with-cc=gcc
--with-cxx=g++ --with-fc=gfortran --download-triangle
--with-scalar-type=complex
A and B were also imported to matlab and the same system was solved.
The direct and iterative solver in matlab give the same result, which are
quite different from the result from Petsc.
A and B are attached. x from petsc is also attached. I am using only one
processor.
It is weird.
Thanks a lot.
Xiaodong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240607/cb570191/attachment-0001.html>
%Mat Object: 1 MPI process
% type: seqaij
% Size = 189 189
% Nonzeros = 1437
zzz = zeros(1437,4);
zzz = [
1 1 1.0000000000000000e+00 0.0000000000000000e+00
2 2 1.0000000000000000e+00 0.0000000000000000e+00
3 3 1.0000000000000000e+00 0.0000000000000000e+00
4 1 1.7448072822336421e+01 0.0000000000000000e+00
4 2 -2.6091031600270316e+01 0.0000000000000000e+00
4 3 -4.6642036408564564e+01 0.0000000000000000e+00
4 4 -1.7939224198902082e+00 0.0000000000000000e+00
4 5 -6.4153074362378362e+01 0.0000000000000000e+00
4 6 -5.2202557943942168e+01 0.0000000000000000e+00
4 90 -9.3878182451303580e+00 0.0000000000000000e+00
4 91 -5.9536194241145509e+01 0.0000000000000000e+00
4 94 1.7177625836072707e+01 0.0000000000000000e+00
4 96 -5.9044935663294808e+01 0.0000000000000000e+00
4 119 -4.6092778739227526e+01 0.0000000000000000e+00
4 128 -1.4251193510127047e+01 0.0000000000000000e+00
4 129 4.4176160666526556e+01 0.0000000000000000e+00
5 1 -1.2509432866168664e+01 0.0000000000000000e+00
5 2 -3.2496769552092829e+01 0.0000000000000000e+00
5 3 -2.9755653068801536e+01 0.0000000000000000e+00
5 4 -6.4153074362378362e+01 0.0000000000000000e+00
5 5 -5.0599229847282807e+01 0.0000000000000000e+00
5 6 -6.4108331015046218e+01 0.0000000000000000e+00
5 85 -2.3288694994240505e+01 0.0000000000000000e+00
5 86 -6.6946413258413395e+00 0.0000000000000000e+00
5 87 4.6646332361794848e+01 0.0000000000000000e+00
5 88 2.5398402558336581e+00 0.0000000000000000e+00
5 89 -1.3477435071945351e+01 0.0000000000000000e+00
5 92 8.7834743682865764e+00 0.0000000000000000e+00
5 94 2.5004277678951695e+01 0.0000000000000000e+00
5 95 6.2165517583852861e+00 0.0000000000000000e+00
5 96 -5.4704938971099068e+01 0.0000000000000000e+00
5 129 2.1086269546187836e+01 0.0000000000000000e+00
6 1 3.6646214685312199e+00 0.0000000000000000e+00
6 2 2.0255311403578581e+01 0.0000000000000000e+00
6 3 2.1432203053040013e+01 0.0000000000000000e+00
6 4 -5.2202557943942168e+01 0.0000000000000000e+00
6 5 -6.4108331015046218e+01 0.0000000000000000e+00
6 6 1.1051463488587196e+01 0.0000000000000000e+00
6 87 4.6646332361931655e+01 0.0000000000000000e+00
6 89 8.7834743682660665e+00 0.0000000000000000e+00
6 90 -6.6946413258602018e+00 0.0000000000000000e+00
6 91 -2.3288694994189619e+01 0.0000000000000000e+00
6 92 -1.3477435072114222e+01 0.0000000000000000e+00
6 93 2.5398402557848376e+00 0.0000000000000000e+00
6 119 6.2165517584039947e+00 0.0000000000000000e+00
7 7 1.0000000000000000e+00 0.0000000000000000e+00
8 8 1.0000000000000000e+00 0.0000000000000000e+00
9 9 1.0000000000000000e+00 0.0000000000000000e+00
10 7 -3.1964378158618654e+01 0.0000000000000000e+00
10 8 3.7058134338963100e-11 0.0000000000000000e+00
10 9 -2.1953433976834411e+01 0.0000000000000000e+00
10 10 4.1309990189710099e+01 0.0000000000000000e+00
10 11 -4.6805068271053599e+01 0.0000000000000000e+00
10 12 -4.6805068270933489e+01 0.0000000000000000e+00
10 100 -1.1604651406189923e+01 0.0000000000000000e+00
10 102 -4.9938558690455395e+01 0.0000000000000000e+00
10 104 -4.1803449556020084e+01 0.0000000000000000e+00
10 120 8.0996542409283077e+00 0.0000000000000000e+00
10 144 -1.6449340668505251e+01 0.0000000000000000e+00
10 145 -1.6935645517826238e+01 0.0000000000000000e+00
10 146 1.8529352742245536e+01 0.0000000000000000e+00
11 3 2.0656677254712516e+01 0.0000000000000000e+00
11 7 2.9210789371887174e+01 0.0000000000000000e+00
11 8 -1.3399321859557700e+01 0.0000000000000000e+00
11 9 2.0656677254547283e+01 0.0000000000000000e+00
11 10 -4.6805068271053599e+01 0.0000000000000000e+00
11 11 -1.4518075109369065e+01 0.0000000000000000e+00
11 12 -5.5828065299118876e+01 0.0000000000000000e+00
11 13 -3.9221733553797215e+01 0.0000000000000000e+00
11 14 -4.6805068270996685e+01 0.0000000000000000e+00
11 45 -1.8529352742247752e+01 0.0000000000000000e+00
11 100 -1.6935645517822817e+01 0.0000000000000000e+00
11 101 -4.1803449555837702e+01 0.0000000000000000e+00
11 102 -1.6449340668442446e+01 0.0000000000000000e+00
11 103 -4.9938558690229470e+01 0.0000000000000000e+00
11 104 8.0996542409131891e+00 0.0000000000000000e+00
11 127 -1.1604651406182441e+01 0.0000000000000000e+00
12 3 2.9210789371869136e+01 0.0000000000000000e+00
12 7 2.0656677254510221e+01 0.0000000000000000e+00
12 8 1.3399321859386362e+01 0.0000000000000000e+00
12 9 3.9221733553626720e+01 0.0000000000000000e+00
12 10 -4.6805068270933489e+01 0.0000000000000000e+00
12 11 -5.5828065299118876e+01 0.0000000000000000e+00
12 12 -1.4518075109375740e+01 0.0000000000000000e+00
12 13 -2.0656677254678179e+01 0.0000000000000000e+00
12 14 -4.6805068270900662e+01 0.0000000000000000e+00
12 90 -1.6935645517848045e+01 0.0000000000000000e+00
12 119 8.0996542409003620e+00 0.0000000000000000e+00
12 120 -4.1803449555874785e+01 0.0000000000000000e+00
12 121 -1.8529352742312085e+01 0.0000000000000000e+00
12 125 -1.6449340668440335e+01 0.0000000000000000e+00
12 144 -4.9938558690418944e+01 0.0000000000000000e+00
12 145 -1.1604651406307708e+01 0.0000000000000000e+00
13 13 1.0000000000000000e+00 0.0000000000000000e+00
14 3 -3.1964378158695439e+01 0.0000000000000000e+00
14 8 3.4338257528616475e-11 0.0000000000000000e+00
14 11 -4.6805068270996685e+01 0.0000000000000000e+00
14 12 -4.6805068270900662e+01 0.0000000000000000e+00
14 13 2.1953433976995857e+01 0.0000000000000000e+00
14 14 4.1309990190123948e+01 0.0000000000000000e+00
14 57 -1.8529352742124665e+01 0.0000000000000000e+00
14 90 -1.1604651406136309e+01 0.0000000000000000e+00
14 101 8.0996542409242807e+00 0.0000000000000000e+00
14 103 -1.6449340668387485e+01 0.0000000000000000e+00
14 119 -4.1803449555941597e+01 0.0000000000000000e+00
14 125 -4.9938558690263804e+01 0.0000000000000000e+00
14 127 -1.6935645517770730e+01 0.0000000000000000e+00
15 15 -5.7622406855444099e+00 1.7668052571739419e+00
15 16 2.5181503824208519e+01 1.1781048114337240e+00
15 17 -5.6201536969092523e+00 5.9676790944058544e-01
15 18 -9.9702168793637611e+00 0.0000000000000000e+00
15 19 1.1025246921080569e+01 0.0000000000000000e+00
15 20 8.3809822830286973e-01 0.0000000000000000e+00
15 131 7.7976060511603873e-01 0.0000000000000000e+00
15 132 -2.6121233995418869e+01 -1.1781048114292538e+00
15 134 6.3265333754418229e+00 -5.9676790943838753e-01
15 177 -2.2120239984752685e+00 -1.5742632787019710e+00
15 179 1.8869095956996489e+01 1.7748727208639972e+00
15 183 2.7874941615753833e+01 2.1356231475037033e+00
15 186 1.8869095957030670e+01 1.7748727208705120e+00
16 15 2.5181503824208519e+01 1.1781048114337240e+00
16 16 -3.4473234756711101e+01 7.0694244338522907e+00
16 17 -1.3727431931887299e+01 8.8998322377797701e-01
16 18 -1.2094023270819218e+01 0.0000000000000000e+00
16 19 -3.2073132473577118e+01 0.0000000000000000e+00
16 20 2.3165717627636887e+01 0.0000000000000000e+00
16 50 2.6615769043051355e+01 0.0000000000000000e+00
16 76 -4.9348022004119612e+00 0.0000000000000000e+00
16 82 -6.6666666666231240e+00 5.9676790943895563e-01
16 83 1.0364306117981794e+01 0.0000000000000000e+00
16 97 2.6405875468888844e+01 -8.8998322377792116e-01
16 98 -4.2458121170373602e+01 0.0000000000000000e+00
16 166 1.6449340668702133e+00 -3.9982358434576998e-01
16 167 -6.5797362673579425e+00 3.1453696833497071e+00
16 177 -2.0514030023892047e+01 -1.3750491365268884e+00
16 183 -5.0394876495463301e+01 -5.5710811412866459e+00
16 184 1.2626968689653392e+01 -1.8901500944919634e+00
16 185 -4.4022983553369235e+00 -1.6550431732394963e+00
16 186 1.6743244955299030e+01 1.5342864293916341e+00
17 17 1.0000000000000000e+00 0.0000000000000000e+00
18 15 -9.9702168793637611e+00 0.0000000000000000e+00
18 16 -1.2094023270819218e+01 0.0000000000000000e+00
18 17 -2.0686423847475293e+01 0.0000000000000000e+00
18 18 -2.3355964821294926e+00 0.0000000000000000e+00
18 19 -3.6817375630969437e+01 0.0000000000000000e+00
18 20 -3.2523457498268151e+01 0.0000000000000000e+00
18 49 -1.7331655952024242e+01 0.0000000000000000e+00
18 70 -4.6268979531464907e+01 0.0000000000000000e+00
18 80 2.0502193746628897e+01 0.0000000000000000e+00
18 105 -3.7684567298535455e+01 0.0000000000000000e+00
18 106 -1.7307994600745232e+01 0.0000000000000000e+00
18 118 1.3369315737140408e+01 0.0000000000000000e+00
18 131 -2.7722719906458007e+01 0.0000000000000000e+00
18 132 1.7699109359304369e+01 0.0000000000000000e+00
18 133 -7.6130096995454721e+00 0.0000000000000000e+00
18 134 3.1605002978394360e+01 0.0000000000000000e+00
19 15 1.1025246921080569e+01 0.0000000000000000e+00
19 16 -3.2073132473577118e+01 0.0000000000000000e+00
19 17 -1.1255925042516349e+01 0.0000000000000000e+00
19 18 -3.6817375630969437e+01 0.0000000000000000e+00
19 19 1.2062187493948660e+00 0.0000000000000000e+00
19 20 -3.3109368148974411e+01 0.0000000000000000e+00
19 50 -5.1165882322008017e+01 0.0000000000000000e+00
19 72 -1.5686699693518971e+01 0.0000000000000000e+00
19 81 -1.4011065680231159e+01 0.0000000000000000e+00
19 83 -1.1075624703850663e+01 0.0000000000000000e+00
19 98 -4.0057194084425106e+01 0.0000000000000000e+00
19 107 -1.3890965936088769e+01 0.0000000000000000e+00
19 130 1.3024439092778930e+01 0.0000000000000000e+00
19 131 -2.7972608592053906e+01 0.0000000000000000e+00
19 132 2.7402267354168380e+01 0.0000000000000000e+00
19 134 1.6919348754188327e+01 0.0000000000000000e+00
20 15 8.3809822830286973e-01 0.0000000000000000e+00
20 16 2.3165717627636887e+01 0.0000000000000000e+00
20 17 2.7331853556115753e+01 0.0000000000000000e+00
20 18 -3.2523457498268151e+01 0.0000000000000000e+00
20 19 -3.3109368148974411e+01 0.0000000000000000e+00
20 20 3.9537361435634551e+01 0.0000000000000000e+00
20 48 -1.7414916428258003e+01 0.0000000000000000e+00
20 49 -5.8035438684986659e+01 0.0000000000000000e+00
20 50 -1.9471890319915452e+01 0.0000000000000000e+00
20 83 -1.6085168960056542e+01 0.0000000000000000e+00
20 98 1.5540144339200694e+01 0.0000000000000000e+00
20 106 -7.0118707534308760e+00 0.0000000000000000e+00
20 118 -4.2976072893144135e+01 0.0000000000000000e+00
21 21 1.0000000000000000e+00 0.0000000000000000e+00
22 22 1.0000000000000000e+00 0.0000000000000000e+00
23 23 1.0000000000000000e+00 0.0000000000000000e+00
24 2 3.0701460828333744e+01 0.0000000000000000e+00
24 21 2.0273185083477792e+01 0.0000000000000000e+00
24 22 -1.5991442266413918e+01 0.0000000000000000e+00
24 23 -7.2358725872472220e+01 0.0000000000000000e+00
24 24 2.8945812711552080e+01 0.0000000000000000e+00
24 25 -2.7485402137076498e+01 0.0000000000000000e+00
24 26 -1.0182347795339140e+02 0.0000000000000000e+00
24 27 5.8708503357810450e+01 0.0000000000000000e+00
24 28 1.3047629412842440e+01 0.0000000000000000e+00
24 29 -4.4523491174977089e+01 0.0000000000000000e+00
24 64 7.6794754800235587e+00 0.0000000000000000e+00
24 65 -3.1551546012357772e+01 0.0000000000000000e+00
24 66 -4.9049650732321602e+01 0.0000000000000000e+00
24 86 3.0459770467219563e+01 0.0000000000000000e+00
24 120 1.7653444799937155e+01 0.0000000000000000e+00
24 150 -7.9192680165582928e+01 0.0000000000000000e+00
24 151 1.2539160347440311e+02 0.0000000000000000e+00
24 152 -2.2959242579385361e+01 0.0000000000000000e+00
24 153 3.9359866003641208e+01 0.0000000000000000e+00
25 21 -2.9622539752620966e+01 0.0000000000000000e+00
25 22 -5.3680897456830166e+01 0.0000000000000000e+00
25 23 -7.7835959133920642e+00 0.0000000000000000e+00
25 24 -2.7485402137076498e+01 0.0000000000000000e+00
25 25 1.2161136112223259e+02 0.0000000000000000e+00
25 26 -4.8909982019995432e+01 0.0000000000000000e+00
25 27 4.0698128093179875e+01 0.0000000000000000e+00
25 28 2.7105488487831757e+01 0.0000000000000000e+00
25 29 -7.7422622654916182e+01 0.0000000000000000e+00
25 74 5.0219313686965641e+01 0.0000000000000000e+00
25 88 3.3297687985228649e+01 0.0000000000000000e+00
25 111 -9.6124165763302869e+01 0.0000000000000000e+00
25 112 -3.1322090517381543e+01 0.0000000000000000e+00
25 126 4.7150779494431980e+01 0.0000000000000000e+00
25 135 -8.7877538278337425e+01 0.0000000000000000e+00
25 136 4.9553251012744632e+01 0.0000000000000000e+00
26 21 -8.2078463530218499e+00 0.0000000000000000e+00
26 22 3.2214972397570492e+01 0.0000000000000000e+00
26 23 7.3296876482375609e+01 0.0000000000000000e+00
26 24 -1.0182347795339140e+02 0.0000000000000000e+00
26 25 -4.8909982019995432e+01 0.0000000000000000e+00
26 26 3.0342499837362254e+01 0.0000000000000000e+00
26 64 -2.0687578020890115e+01 0.0000000000000000e+00
26 65 1.6270779691617872e+01 0.0000000000000000e+00
26 66 -2.7345733424251119e+01 0.0000000000000000e+00
26 67 -5.7695905190862646e+01 0.0000000000000000e+00
26 68 -1.2100252401931122e+01 0.0000000000000000e+00
26 69 -4.4663159887556333e+01 0.0000000000000000e+00
26 71 -3.0072951621540263e+01 0.0000000000000000e+00
26 112 -1.6706067789161043e+01 0.0000000000000000e+00
26 113 2.9582227812439811e+01 0.0000000000000000e+00
26 135 -2.3098911292313055e+01 0.0000000000000000e+00
26 136 3.8596301284753480e+01 0.0000000000000000e+00
26 137 -8.0589367291768525e+01 0.0000000000000000e+00
26 138 -1.2305676573776667e+02 0.0000000000000000e+00
27 27 1.0000000000000000e+00 0.0000000000000000e+00
28 28 1.0000000000000000e+00 0.0000000000000000e+00
29 21 2.7650498680337435e+01 0.0000000000000000e+00
29 24 -4.4523491174977089e+01 0.0000000000000000e+00
29 25 -7.7422622654916182e+01 0.0000000000000000e+00
29 27 -3.6309519968113356e+01 0.0000000000000000e+00
29 28 -2.0387928325740880e+01 0.0000000000000000e+00
29 29 8.5506376789615373e+01 0.0000000000000000e+00
29 86 8.1886415556992631e+00 0.0000000000000000e+00
29 88 -4.9825728880257245e+01 0.0000000000000000e+00
29 89 7.7257735520364195e+00 0.0000000000000000e+00
29 111 3.4963141930985500e+01 0.0000000000000000e+00
29 126 7.7892879573674534e+01 0.0000000000000000e+00
29 150 -2.7518010312262533e+01 0.0000000000000000e+00
29 151 1.7583610443698419e+01 0.0000000000000000e+00
30 30 1.0000000000000000e+00 0.0000000000000000e+00
31 31 1.0000000000000000e+00 0.0000000000000000e+00
32 32 1.0000000000000000e+00 0.0000000000000000e+00
33 30 -1.7489133700035499e+01 0.0000000000000000e+00
33 31 1.9090602567252954e+01 0.0000000000000000e+00
33 32 4.3159472534586030e+01 0.0000000000000000e+00
33 33 1.7796761857113410e+01 0.0000000000000000e+00
33 34 -1.6449340668467109e+01 0.0000000000000000e+00
33 35 -5.0043465199444199e+01 0.0000000000000000e+00
33 36 -2.3311600733532615e+01 0.0000000000000000e+00
33 37 -6.6232014670381671e+00 0.0000000000000000e+00
33 38 -3.8960206968330546e+01 0.0000000000000000e+00
33 54 -1.2467401100231264e+01 0.0000000000000000e+00
33 55 2.4199265566373644e+01 0.0000000000000000e+00
33 56 -2.6492805868184021e+01 0.0000000000000000e+00
33 77 1.6558003667545321e+01 0.0000000000000000e+00
33 79 3.3116007334970750e+00 0.0000000000000000e+00
33 156 -2.5670338834546357e+01 0.0000000000000000e+00
33 157 9.9130696007514718e+00 0.0000000000000000e+00
34 30 1.7489133699999243e+01 0.0000000000000000e+00
34 31 1.1601468867271382e+01 0.0000000000000000e+00
34 32 6.6232014670558499e+00 0.0000000000000000e+00
34 33 -1.6449340668467109e+01 0.0000000000000000e+00
34 34 2.4289567725257658e+01 0.0000000000000000e+00
34 35 -1.7380470701013881e+01 0.0000000000000000e+00
34 36 -1.9090602567154882e+01 0.0000000000000000e+00
34 37 -4.3159472534711540e+01 0.0000000000000000e+00
34 38 -5.0043465199479542e+01 0.0000000000000000e+00
34 44 -8.4419963318848490e-01 0.0000000000000000e+00
34 63 -2.0043465199753484e+01 0.0000000000000000e+00
34 116 1.2467401100150827e+01 0.0000000000000000e+00
34 117 -2.2467401100202494e+01 0.0000000000000000e+00
34 142 -1.7380470701013184e+01 0.0000000000000000e+00
34 148 -8.4419963324012137e-01 0.0000000000000000e+00
34 154 -3.8181205134621948e+01 0.0000000000000000e+00
35 30 1.2467401100197105e+01 0.0000000000000000e+00
35 31 -2.2467401100224539e+01 0.0000000000000000e+00
35 32 -4.3159472534605953e+01 0.0000000000000000e+00
35 33 -5.0043465199444199e+01 0.0000000000000000e+00
35 34 -1.7380470701013881e+01 0.0000000000000000e+00
35 35 2.4289567725157529e+01 0.0000000000000000e+00
35 40 1.1601468867212532e+01 0.0000000000000000e+00
35 43 -8.4419963324012515e-01 0.0000000000000000e+00
35 44 -2.0043465199574989e+01 0.0000000000000000e+00
35 54 1.7489133700055302e+01 0.0000000000000000e+00
35 55 -1.9090602567280939e+01 0.0000000000000000e+00
35 56 -1.6449340668524155e+01 0.0000000000000000e+00
35 60 6.6232014670438151e+00 0.0000000000000000e+00
35 61 -1.7380470701007273e+01 0.0000000000000000e+00
35 63 -8.4419963318849123e-01 0.0000000000000000e+00
35 154 -3.8181205134487584e+01 0.0000000000000000e+00
36 36 1.0000000000000000e+00 0.0000000000000000e+00
37 37 1.0000000000000000e+00 0.0000000000000000e+00
38 30 -1.2467401100116716e+01 0.0000000000000000e+00
38 33 -3.8960206968330546e+01 0.0000000000000000e+00
38 34 -5.0043465199479542e+01 0.0000000000000000e+00
38 36 3.5324303117407176e+01 0.0000000000000000e+00
38 37 4.3159472534731520e+01 0.0000000000000000e+00
38 38 -2.6616457947952846e+01 0.0000000000000000e+00
38 48 -1.3333333333426900e+01 0.0000000000000000e+00
38 77 -7.8786346169886894e+00 0.0000000000000000e+00
38 79 1.3311600733637299e+01 0.0000000000000000e+00
38 83 2.7596110819336921e+01 0.0000000000000000e+00
38 84 -1.7769971617777554e+01 0.0000000000000000e+00
38 114 -6.6232014670614507e+00 0.0000000000000000e+00
38 116 -1.7489133700019053e+01 0.0000000000000000e+00
38 117 1.9090602567182867e+01 0.0000000000000000e+00
38 118 9.9130696007514807e+00 0.0000000000000000e+00
38 139 -2.6492805868186984e+01 0.0000000000000000e+00
38 142 -1.6449340668524162e+01 0.0000000000000000e+00
38 156 -4.1123351671170269e+01 0.0000000000000000e+00
38 158 -2.2380470700976407e+01 0.0000000000000000e+00
39 39 1.0000000000000000e+00 0.0000000000000000e+00
40 40 1.0000000000000000e+00 0.0000000000000000e+00
41 41 1.0000000000000000e+00 0.0000000000000000e+00
42 39 1.7489133700142400e+01 0.0000000000000000e+00
42 40 -1.9090602567359184e+01 0.0000000000000000e+00
42 41 -4.3159472534807662e+01 0.0000000000000000e+00
42 42 2.6777493357726918e+01 0.0000000000000000e+00
42 43 -1.6449340668433251e+01 0.0000000000000000e+00
42 44 -5.0043465199611703e+01 0.0000000000000000e+00
42 45 1.1006230771933016e+01 0.0000000000000000e+00
42 46 6.6232014670071973e+00 0.0000000000000000e+00
42 47 -1.6764324960524110e+01 0.0000000000000000e+00
42 57 -2.1872163005067677e+01 0.0000000000000000e+00
42 58 1.2467401100311948e+01 0.0000000000000000e+00
42 59 -1.6764324960536669e+01 0.0000000000000000e+00
42 102 -1.3076171287669142e-01 0.0000000000000000e+00
42 103 -2.0784484760043853e+01 0.0000000000000000e+00
42 125 -1.3076171282183557e-01 0.0000000000000000e+00
42 155 4.1527049998609456e+01 0.0000000000000000e+00
43 35 -8.4419963324012515e-01 0.0000000000000000e+00
43 39 -1.7489133700130310e+01 0.0000000000000000e+00
43 40 -1.1601468867205874e+01 0.0000000000000000e+00
43 41 -6.6232014670130877e+00 0.0000000000000000e+00
43 42 -1.6449340668433251e+01 0.0000000000000000e+00
43 43 2.4289567725555703e+01 0.0000000000000000e+00
43 44 -1.7380470700985949e+01 0.0000000000000000e+00
43 45 1.9090602567326492e+01 0.0000000000000000e+00
43 46 4.3159472534977773e+01 0.0000000000000000e+00
43 47 -5.0043465199837883e+01 0.0000000000000000e+00
43 61 -2.0043465199699927e+01 0.0000000000000000e+00
43 142 -8.4419963329562342e-01 0.0000000000000000e+00
43 143 -2.2467401100323890e+01 0.0000000000000000e+00
43 148 -1.7380470700979110e+01 0.0000000000000000e+00
43 149 1.2467401100356563e+01 0.0000000000000000e+00
43 154 3.8181205134735698e+01 0.0000000000000000e+00
44 31 -1.1601468867182296e+01 0.0000000000000000e+00
44 34 -8.4419963318848490e-01 0.0000000000000000e+00
44 35 -2.0043465199574989e+01 0.0000000000000000e+00
44 39 -1.2467401100346098e+01 0.0000000000000000e+00
44 40 2.2467401100326356e+01 0.0000000000000000e+00
44 41 4.3159472534787710e+01 0.0000000000000000e+00
44 42 -5.0043465199611703e+01 0.0000000000000000e+00
44 43 -1.7380470700985949e+01 0.0000000000000000e+00
44 44 2.4289567725532908e+01 0.0000000000000000e+00
44 57 1.9090602567331175e+01 0.0000000000000000e+00
44 58 -1.7489133700122572e+01 0.0000000000000000e+00
44 59 -1.6449340668376195e+01 0.0000000000000000e+00
44 61 -8.4419963324011982e-01 0.0000000000000000e+00
44 62 -6.6232014670015706e+00 0.0000000000000000e+00
44 63 -1.7380470701004306e+01 0.0000000000000000e+00
44 154 3.8181205134533059e+01 0.0000000000000000e+00
45 45 1.0000000000000000e+00 0.0000000000000000e+00
46 46 1.0000000000000000e+00 0.0000000000000000e+00
47 39 1.2467401100319293e+01 0.0000000000000000e+00
47 42 -1.6764324960524110e+01 0.0000000000000000e+00
47 43 -5.0043465199837883e+01 0.0000000000000000e+00
47 45 -2.1872163005063907e+01 0.0000000000000000e+00
47 46 -4.3159472534999189e+01 0.0000000000000000e+00
47 47 2.6777493357764044e+01 0.0000000000000000e+00
47 68 6.6232014670190775e+00 0.0000000000000000e+00
47 102 -2.0784484760170976e+01 0.0000000000000000e+00
47 103 -1.3076171287695948e-01 0.0000000000000000e+00
47 143 1.9090602567357969e+01 0.0000000000000000e+00
47 144 -1.3076171293588179e-01 0.0000000000000000e+00
47 146 -1.1006230771956277e+01 0.0000000000000000e+00
47 147 -1.6764324960499092e+01 0.0000000000000000e+00
47 148 -1.6449340668493939e+01 0.0000000000000000e+00
47 149 -1.7489133700152156e+01 0.0000000000000000e+00
47 155 4.1527049998830122e+01 0.0000000000000000e+00
48 20 -1.7414916428258003e+01 0.0000000000000000e+00
48 38 -1.3333333333426900e+01 0.0000000000000000e+00
48 48 1.6016405898209033e+01 0.0000000000000000e+00
48 49 3.5488822097268788e+01 0.0000000000000000e+00
48 50 -1.7339039667063140e+01 0.0000000000000000e+00
48 51 -1.0894163608456564e+01 0.0000000000000000e+00
48 52 1.6175672477562717e+01 0.0000000000000000e+00
48 53 -1.4053360471994631e+00 0.0000000000000000e+00
48 83 1.7783889495298254e+01 0.0000000000000000e+00
48 114 -3.4179630537475248e+01 0.0000000000000000e+00
48 115 -2.8135536119673560e+01 0.0000000000000000e+00
48 116 -1.0459575115202444e+01 0.0000000000000000e+00
48 118 -1.9249782886004589e+01 0.0000000000000000e+00
48 139 4.8224670334251904e+01 0.0000000000000000e+00
48 142 -1.9090602567346330e+01 0.0000000000000000e+00
48 158 -1.5800734433625859e+01 0.0000000000000000e+00
49 17 -2.0381186490571285e+01 0.0000000000000000e+00
49 18 -1.7331655952024242e+01 0.0000000000000000e+00
49 20 -5.8035438684986659e+01 0.0000000000000000e+00
49 48 3.5488822097268788e+01 0.0000000000000000e+00
49 49 1.0964774914400550e+00 0.0000000000000000e+00
49 50 -3.9701701127612893e+01 0.0000000000000000e+00
49 51 -2.3697792022329636e+00 0.0000000000000000e+00
49 52 -2.2814274524002688e+01 0.0000000000000000e+00
49 53 4.3791673411322904e+01 0.0000000000000000e+00
49 70 -3.5815537467699436e+01 0.0000000000000000e+00
49 73 -8.0864434404526464e-01 0.0000000000000000e+00
49 80 1.9879352549751502e+01 0.0000000000000000e+00
49 83 1.7740766200929635e+01 0.0000000000000000e+00
49 105 -2.9692187617398202e-01 0.0000000000000000e+00
49 106 2.0726582079953101e+01 0.0000000000000000e+00
49 118 5.7191415197291157e+01 0.0000000000000000e+00
50 16 2.6615769043051355e+01 0.0000000000000000e+00
50 19 -5.1165882322008017e+01 0.0000000000000000e+00
50 20 -1.9471890319915452e+01 0.0000000000000000e+00
50 48 -1.7339039667063140e+01 0.0000000000000000e+00
50 49 -3.9701701127612893e+01 0.0000000000000000e+00
50 50 -1.3595792297217120e+00 0.0000000000000000e+00
50 51 -2.0073488294378681e+01 0.0000000000000000e+00
50 52 -3.7751152494324276e+00 0.0000000000000000e+00
50 53 4.0185699844313774e+01 0.0000000000000000e+00
50 72 -2.9860477361764172e+01 0.0000000000000000e+00
50 74 5.1766754357168931e-01 0.0000000000000000e+00
50 81 3.0715963936508487e+01 0.0000000000000000e+00
50 83 2.3244849821614178e+01 0.0000000000000000e+00
50 98 5.5584384299511463e+01 0.0000000000000000e+00
50 107 1.4070831509973505e+01 0.0000000000000000e+00
50 118 3.2584977267163240e-01 0.0000000000000000e+00
51 37 2.8574469510837048e+01 0.0000000000000000e+00
51 48 -1.0894163608456564e+01 0.0000000000000000e+00
51 49 -2.3697792022329636e+00 0.0000000000000000e+00
51 50 -2.0073488294378681e+01 0.0000000000000000e+00
51 51 1.6049811715602488e+01 0.0000000000000000e+00
51 52 -5.1953259294069030e+00 0.0000000000000000e+00
51 53 -1.6070237705369234e+01 0.0000000000000000e+00
51 72 -1.8209919778019914e+00 0.0000000000000000e+00
51 74 -6.9454711937223053e+00 0.0000000000000000e+00
51 81 1.2989722224216774e+01 0.0000000000000000e+00
51 108 1.4294001552189453e+01 0.0000000000000000e+00
51 109 -1.5814075860761474e+01 0.0000000000000000e+00
51 110 -4.4667381637868147e+01 0.0000000000000000e+00
51 111 -1.6449340668656632e+01 0.0000000000000000e+00
51 112 -2.2106421349559767e+01 0.0000000000000000e+00
51 114 -2.2106421349502497e+01 0.0000000000000000e+00
51 115 -1.6449340668570123e+01 0.0000000000000000e+00
51 116 -1.4294001552190565e+01 0.0000000000000000e+00
51 117 1.5814075860695594e+01 0.0000000000000000e+00
52 48 1.6175672477562717e+01 0.0000000000000000e+00
52 49 -2.2814274524002688e+01 0.0000000000000000e+00
52 50 -3.7751152494324276e+00 0.0000000000000000e+00
52 51 -5.1953259294069030e+00 0.0000000000000000e+00
52 52 3.8357350751084979e+01 0.0000000000000000e+00
52 53 -1.6043886574567782e+01 0.0000000000000000e+00
52 70 -3.4390863654096888e+00 0.0000000000000000e+00
52 73 -5.7908521760064646e+00 0.0000000000000000e+00
52 80 1.6943875186319083e+01 0.0000000000000000e+00
52 113 -6.0291147700082801e+00 0.0000000000000000e+00
52 114 5.0177241411698461e+01 0.0000000000000000e+00
52 115 -3.2345921378490161e+01 0.0000000000000000e+00
52 116 -6.0291147701710637e+00 0.0000000000000000e+00
53 48 -1.4053360471994631e+00 0.0000000000000000e+00
53 49 4.3791673411322904e+01 0.0000000000000000e+00
53 50 4.0185699844313774e+01 0.0000000000000000e+00
53 51 -1.6070237705369234e+01 0.0000000000000000e+00
53 52 -1.6043886574567782e+01 0.0000000000000000e+00
53 53 -1.4637408281264747e+01 0.0000000000000000e+00
53 70 3.6634917548642932e+01 0.0000000000000000e+00
53 71 -1.1094523464978372e+00 0.0000000000000000e+00
53 72 3.3252070786516093e+01 0.0000000000000000e+00
53 73 -1.6194585729829392e+01 0.0000000000000000e+00
53 74 -1.6408724421341621e+01 0.0000000000000000e+00
53 80 -2.6304420213644240e+00 0.0000000000000000e+00
53 81 -2.3386595213736805e+00 0.0000000000000000e+00
54 54 1.0000000000000000e+00 0.0000000000000000e+00
55 55 1.0000000000000000e+00 0.0000000000000000e+00
56 32 -6.6232014670496744e+00 0.0000000000000000e+00
56 33 -2.6492805868184021e+01 0.0000000000000000e+00
56 35 -1.6449340668524155e+01 0.0000000000000000e+00
56 40 1.9090602567248258e+01 0.0000000000000000e+00
56 54 -1.7489133700043229e+01 0.0000000000000000e+00
56 55 -3.7358738101191719e+01 0.0000000000000000e+00
56 56 8.3183442524020244e+00 0.0000000000000000e+00
56 60 4.3159472534776100e+01 0.0000000000000000e+00
56 61 -5.0043465199670393e+01 0.0000000000000000e+00
56 77 2.5713804034296917e+01 0.0000000000000000e+00
56 84 2.8960206968421225e+01 0.0000000000000000e+00
56 118 9.9130696007758523e+00 0.0000000000000000e+00
56 139 -2.6492805868244766e+01 0.0000000000000000e+00
56 140 -2.4199265566346938e+01 0.0000000000000000e+00
56 141 1.2467401100241741e+01 0.0000000000000000e+00
56 156 -3.6883992664818962e+01 0.0000000000000000e+00
56 157 7.2681355338944371e+01 0.0000000000000000e+00
56 158 -1.6449340668568073e+01 0.0000000000000000e+00
56 159 2.7271807701986358e+01 0.0000000000000000e+00
57 57 1.0000000000000000e+00 0.0000000000000000e+00
58 58 1.0000000000000000e+00 0.0000000000000000e+00
59 31 -1.9090602567233109e+01 0.0000000000000000e+00
59 41 6.6232014670192285e+00 0.0000000000000000e+00
59 42 -1.6764324960536669e+01 0.0000000000000000e+00
59 44 -1.6449340668376195e+01 0.0000000000000000e+00
59 57 1.1006230771987669e+01 0.0000000000000000e+00
59 58 1.7489133700086320e+01 0.0000000000000000e+00
59 59 2.6777493357847348e+01 0.0000000000000000e+00
59 62 -4.3159472534913199e+01 0.0000000000000000e+00
59 63 -5.0043465199646974e+01 0.0000000000000000e+00
59 103 -1.3076171282262211e-01 0.0000000000000000e+00
59 121 -2.1872163005043500e+01 0.0000000000000000e+00
59 124 1.2467401100265668e+01 0.0000000000000000e+00
59 125 -2.0784484760233202e+01 0.0000000000000000e+00
59 144 -1.3076171287746324e-01 0.0000000000000000e+00
59 147 -1.6764324960529994e+01 0.0000000000000000e+00
59 155 4.1527049998756240e+01 0.0000000000000000e+00
60 60 1.0000000000000000e+00 0.0000000000000000e+00
61 35 -1.7380470701007273e+01 0.0000000000000000e+00
61 40 -2.2467401100220776e+01 0.0000000000000000e+00
61 43 -2.0043465199699927e+01 0.0000000000000000e+00
61 44 -8.4419963324011982e-01 0.0000000000000000e+00
61 54 1.2467401100204443e+01 0.0000000000000000e+00
61 56 -5.0043465199670393e+01 0.0000000000000000e+00
61 60 -4.3159472534797487e+01 0.0000000000000000e+00
61 61 2.4289567725176678e+01 0.0000000000000000e+00
61 114 6.6232014670556927e+00 0.0000000000000000e+00
61 139 -1.6449340668584849e+01 0.0000000000000000e+00
61 140 1.9090602567279742e+01 0.0000000000000000e+00
61 141 -1.7489133700065072e+01 0.0000000000000000e+00
61 142 -1.7380470700988692e+01 0.0000000000000000e+00
61 143 -1.1601468867235742e+01 0.0000000000000000e+00
61 148 -8.4419963329562941e-01 0.0000000000000000e+00
61 154 -3.8181205134690224e+01 0.0000000000000000e+00
62 62 1.0000000000000000e+00 0.0000000000000000e+00
63 31 2.2467401100293539e+01 0.0000000000000000e+00
63 34 -2.0043465199753484e+01 0.0000000000000000e+00
63 35 -8.4419963318849123e-01 0.0000000000000000e+00
63 44 -1.7380470701004306e+01 0.0000000000000000e+00
63 58 -1.2467401100231541e+01 0.0000000000000000e+00
63 59 -5.0043465199646974e+01 0.0000000000000000e+00
63 62 4.3159472534933144e+01 0.0000000000000000e+00
63 63 2.4289567725507144e+01 0.0000000000000000e+00
63 68 -6.6232014670248569e+00 0.0000000000000000e+00
63 117 -1.1601468867247080e+01 0.0000000000000000e+00
63 121 1.9090602567261083e+01 0.0000000000000000e+00
63 124 -1.7489133700106120e+01 0.0000000000000000e+00
63 142 -8.4419963324011627e-01 0.0000000000000000e+00
63 147 -1.6449340668433234e+01 0.0000000000000000e+00
63 148 -1.7380470700980037e+01 0.0000000000000000e+00
63 154 3.8181205134667408e+01 0.0000000000000000e+00
64 64 1.0000000000000000e+00 0.0000000000000000e+00
65 65 1.0000000000000000e+00 0.0000000000000000e+00
66 23 8.5913042115943128e+00 0.0000000000000000e+00
66 24 -4.9049650732321602e+01 0.0000000000000000e+00
66 26 -2.7345733424251119e+01 0.0000000000000000e+00
66 64 2.9347815527649065e+01 0.0000000000000000e+00
66 65 5.4414158198222310e+01 0.0000000000000000e+00
66 66 1.2531207292774253e+02 0.0000000000000000e+00
66 67 -4.0279121954994665e+01 0.0000000000000000e+00
66 68 -2.6583572126570424e+01 0.0000000000000000e+00
66 69 -7.7667042901742050e+01 0.0000000000000000e+00
66 92 5.1374849561995696e+01 0.0000000000000000e+00
66 115 3.4963141930920521e+01 0.0000000000000000e+00
66 120 3.3626962294980871e+01 0.0000000000000000e+00
66 122 -9.8945155584021592e+01 0.0000000000000000e+00
66 126 4.7150779494343567e+01 0.0000000000000000e+00
66 152 -9.1333829836593821e+01 0.0000000000000000e+00
66 153 5.0430793667172779e+01 0.0000000000000000e+00
67 67 1.0000000000000000e+00 0.0000000000000000e+00
68 68 1.0000000000000000e+00 0.0000000000000000e+00
69 26 -4.4663159887556333e+01 0.0000000000000000e+00
69 64 -2.8178869553063542e+01 0.0000000000000000e+00
69 66 -7.7667042901742050e+01 0.0000000000000000e+00
69 67 3.6693608927872376e+01 0.0000000000000000e+00
69 68 2.0067219210538251e+01 0.0000000000000000e+00
69 69 8.4340332882360215e+01 0.0000000000000000e+00
69 73 5.4027514936553924e+00 0.0000000000000000e+00
69 113 7.5173341243419980e+00 0.0000000000000000e+00
69 115 -4.9660430814339179e+01 0.0000000000000000e+00
69 122 3.3297687985166128e+01 0.0000000000000000e+00
69 126 7.0545466581885734e+01 0.0000000000000000e+00
69 137 -2.1681074519067085e+01 0.0000000000000000e+00
69 138 -1.6775902145416758e+01 0.0000000000000000e+00
70 18 -4.6268979531464907e+01 0.0000000000000000e+00
70 49 -3.5815537467699436e+01 0.0000000000000000e+00
70 52 -3.4390863654096888e+00 0.0000000000000000e+00
70 53 3.6634917548642932e+01 0.0000000000000000e+00
70 70 2.3437741868106370e+00 0.0000000000000000e+00
70 71 1.6166835965483756e+01 0.0000000000000000e+00
70 72 -2.7349592077169369e+01 0.0000000000000000e+00
70 73 -1.7801120814678470e+01 0.0000000000000000e+00
70 74 4.7743969236933970e-01 0.0000000000000000e+00
70 80 -3.3472162748130280e+01 0.0000000000000000e+00
70 105 4.8439642095812459e+01 0.0000000000000000e+00
70 106 2.0205271870454915e+01 0.0000000000000000e+00
70 130 -4.2744776025083631e-01 0.0000000000000000e+00
70 131 -1.4194653042381727e+01 0.0000000000000000e+00
70 133 1.8736454892255125e+01 0.0000000000000000e+00
70 134 -1.9040010693805481e+01 0.0000000000000000e+00
71 71 1.0000000000000000e+00 0.0000000000000000e+00
72 19 -1.5686699693518971e+01 0.0000000000000000e+00
72 50 -2.9860477361764172e+01 0.0000000000000000e+00
72 51 -1.8209919778019914e+00 0.0000000000000000e+00
72 53 3.3252070786516093e+01 0.0000000000000000e+00
72 70 -2.7349592077169369e+01 0.0000000000000000e+00
72 71 -2.9453033061618637e+01 0.0000000000000000e+00
72 72 -1.1086724857403496e+00 0.0000000000000000e+00
72 73 -6.3201265412849661e-01 0.0000000000000000e+00
72 74 -1.5966165212681368e+01 0.0000000000000000e+00
72 81 -1.3959809194814346e+01 0.0000000000000000e+00
72 98 5.9765829742346427e-02 0.0000000000000000e+00
72 107 2.0510009301603581e+01 0.0000000000000000e+00
72 130 4.7615590644471411e+01 0.0000000000000000e+00
72 131 -3.9766653206274306e+01 0.0000000000000000e+00
72 132 2.3817787858948190e+01 0.0000000000000000e+00
72 133 1.6390054863474191e+01 0.0000000000000000e+00
73 49 -8.0864434404526464e-01 0.0000000000000000e+00
73 52 -5.7908521760064646e+00 0.0000000000000000e+00
73 53 -1.6194585729829392e+01 0.0000000000000000e+00
73 69 5.4027514936553924e+00 0.0000000000000000e+00
73 70 -1.7801120814678470e+01 0.0000000000000000e+00
73 71 2.7081177937700178e+00 0.0000000000000000e+00
73 72 -6.3201265412849661e-01 0.0000000000000000e+00
73 73 2.4090582253076455e+01 0.0000000000000000e+00
73 74 -3.2929412089304748e+01 0.0000000000000000e+00
73 80 -1.1099274865000130e+01 0.0000000000000000e+00
73 113 -1.5496664507549749e+00 0.0000000000000000e+00
73 114 -2.2106421349298813e+01 0.0000000000000000e+00
73 115 -2.6121572966439849e+01 0.0000000000000000e+00
73 126 -8.5090389053661966e+01 0.0000000000000000e+00
73 135 2.3096201770041297e+01 0.0000000000000000e+00
73 137 -2.3497985375763026e+01 0.0000000000000000e+00
74 25 5.0219313686965641e+01 0.0000000000000000e+00
74 50 5.1766754357168931e-01 0.0000000000000000e+00
74 51 -6.9454711937223053e+00 0.0000000000000000e+00
74 53 -1.6408724421341621e+01 0.0000000000000000e+00
74 70 4.7743969236933970e-01 0.0000000000000000e+00
74 71 -1.0337593869997969e+01 0.0000000000000000e+00
74 72 -1.5966165212681368e+01 0.0000000000000000e+00
74 73 -3.2929412089304748e+01 0.0000000000000000e+00
74 74 4.1990192765564522e+01 0.0000000000000000e+00
74 81 -1.6502172513268764e+01 0.0000000000000000e+00
74 108 6.0291147702444521e+00 0.0000000000000000e+00
74 111 -6.8766106137039799e+01 0.0000000000000000e+00
74 112 3.2407575082177992e+01 0.0000000000000000e+00
74 126 -4.9127550432182126e+01 0.0000000000000000e+00
74 135 -3.7704048746457630e+01 0.0000000000000000e+00
74 137 4.3920549752234976e+01 0.0000000000000000e+00
75 75 1.0000000000000000e+00 0.0000000000000000e+00
76 76 1.0000000000000000e+00 0.0000000000000000e+00
77 77 1.0000000000000000e+00 0.0000000000000000e+00
78 78 1.0000000000000000e+00 0.0000000000000000e+00
79 33 3.3116007334970750e+00 0.0000000000000000e+00
79 36 -7.4348022005954384e+00 0.0000000000000000e+00
79 38 1.3311600733637299e+01 0.0000000000000000e+00
79 75 6.6232014670561412e+00 0.0000000000000000e+00
79 76 -5.1521281988440970e+00 0.0000000000000000e+00
79 77 -2.5217325998193019e+00 0.0000000000000000e+00
79 78 -1.4978267400127701e+01 0.0000000000000000e+00
79 79 3.9635787279991894e+00 0.0000000000000000e+00
79 82 1.0490850646857598e-11 0.0000000000000000e+00
79 83 -1.0963728932341811e+01 0.0000000000000000e+00
79 84 -1.2543465199539856e+01 0.0000000000000000e+00
79 156 -6.8187948653282824e+00 0.0000000000000000e+00
79 158 6.6449340668385464e+00 0.0000000000000000e+00
80 80 1.0000000000000000e+00 0.0000000000000000e+00
81 81 1.0000000000000000e+00 0.0000000000000000e+00
82 16 -6.6666666666231240e+00 5.9676790943895563e-01
82 76 -1.0043465199680575e+01 0.0000000000000000e+00
82 78 1.0757749766886279e+01 -6.0762534852552182e-02
82 79 1.0490850646857598e-11 0.0000000000000000e+00
82 82 8.7072723266911556e+00 3.7583778255159461e+00
82 83 1.0043465199484812e+01 0.0000000000000000e+00
82 84 -1.0074890439491465e+01 7.3806700688669596e-02
82 97 -2.5535762623647805e+01 -1.1781048114242536e+00
82 98 8.6491799554800090e-12 0.0000000000000000e+00
82 163 3.4515451454850385e+01 3.8489110873569246e+00
82 166 -1.0753762576954568e+01 4.3151558690273251e-01
82 167 -8.9272429425853783e+00 -3.4589468699359380e+00
82 168 1.4206686392760542e+01 -1.9572360451562325e+00
82 169 -3.0214466474654518e+01 -5.2151641091413365e+00
82 171 -1.7882001707118309e+00 -2.1172957385442559e-02
82 184 1.8869095956946847e+01 1.7748727208668531e+00
83 16 1.0364306117981794e+01 0.0000000000000000e+00
83 19 -1.1075624703850663e+01 0.0000000000000000e+00
83 20 -1.6085168960056542e+01 0.0000000000000000e+00
83 38 2.7596110819336921e+01 0.0000000000000000e+00
83 48 1.7783889495298254e+01 0.0000000000000000e+00
83 49 1.7740766200929635e+01 0.0000000000000000e+00
83 50 2.3244849821614178e+01 0.0000000000000000e+00
83 76 -3.9478417604165529e+01 0.0000000000000000e+00
83 78 4.1297212469542018e+01 0.0000000000000000e+00
83 79 -1.0963728932341811e+01 0.0000000000000000e+00
83 82 1.0043465199484812e+01 0.0000000000000000e+00
83 83 -2.5442807651660807e+01 0.0000000000000000e+00
83 84 4.6003822371938995e+01 0.0000000000000000e+00
83 97 4.9348022004206094e+00 0.0000000000000000e+00
83 98 -3.2554805305031373e+01 0.0000000000000000e+00
83 118 -1.6642580518638933e+01 0.0000000000000000e+00
83 139 2.5713804034377343e+01 0.0000000000000000e+00
83 156 2.4414905684616095e+01 0.0000000000000000e+00
83 158 -2.4264463365716306e+01 0.0000000000000000e+00
84 84 1.0000000000000000e+00 0.0000000000000000e+00
85 5 -2.3288694994240505e+01 0.0000000000000000e+00
85 85 4.0526712438262294e+01 0.0000000000000000e+00
85 86 2.1472831089089233e+01 0.0000000000000000e+00
85 87 5.1917657271250583e+01 0.0000000000000000e+00
85 88 -2.6020774803349561e+01 0.0000000000000000e+00
85 89 -2.6075348151002844e+00 0.0000000000000000e+00
85 91 -2.3253842548856689e+01 0.0000000000000000e+00
85 93 -3.6949498603262718e+00 0.0000000000000000e+00
85 94 1.5604370003431024e+01 0.0000000000000000e+00
85 95 4.6968039050478239e+01 0.0000000000000000e+00
85 96 -5.9640945775636055e+01 0.0000000000000000e+00
85 99 -2.6473189944988551e+01 0.0000000000000000e+00
85 128 1.4568216033769625e+01 0.0000000000000000e+00
86 86 1.0000000000000000e+00 0.0000000000000000e+00
87 2 2.0508483800085742e-11 0.0000000000000000e+00
87 5 4.6646332361794848e+01 0.0000000000000000e+00
87 6 4.6646332361931655e+01 0.0000000000000000e+00
87 85 5.1917657271250583e+01 0.0000000000000000e+00
87 86 5.1473750709339434e+00 0.0000000000000000e+00
87 87 -2.6555536016582089e+00 0.0000000000000000e+00
87 88 -3.8216861041382714e+01 0.0000000000000000e+00
87 89 -2.9823700187739199e+01 0.0000000000000000e+00
87 90 5.1473750709501687e+00 0.0000000000000000e+00
87 91 5.1917657271147483e+01 0.0000000000000000e+00
87 92 -2.9823700187864056e+01 0.0000000000000000e+00
87 93 -3.8216861041312981e+01 0.0000000000000000e+00
87 99 3.8830350754536821e-11 0.0000000000000000e+00
88 5 2.5398402558336581e+00 0.0000000000000000e+00
88 25 3.3297687985228649e+01 0.0000000000000000e+00
88 28 -2.8753234156828732e+01 0.0000000000000000e+00
88 29 -4.9825728880257245e+01 0.0000000000000000e+00
88 62 7.6762526523928187e+00 0.0000000000000000e+00
88 85 -2.6020774803349561e+01 0.0000000000000000e+00
88 86 2.3947201006777554e+00 0.0000000000000000e+00
88 87 -3.8216861041382714e+01 0.0000000000000000e+00
88 88 4.6044948205896510e+01 0.0000000000000000e+00
88 89 -1.5913704524898709e+01 0.0000000000000000e+00
88 91 -3.6949498603651034e+00 0.0000000000000000e+00
88 93 -1.3510878614578672e+01 0.0000000000000000e+00
88 99 -1.0987129275639305e+01 0.0000000000000000e+00
88 109 1.8684937856646826e+01 0.0000000000000000e+00
88 110 -1.6449340668565711e+01 0.0000000000000000e+00
88 111 -6.2810053867582674e+01 0.0000000000000000e+00
88 123 -1.7089004829949083e+01 0.0000000000000000e+00
88 126 -7.3968809367457411e+01 0.0000000000000000e+00
88 150 2.4955872988872677e+01 0.0000000000000000e+00
89 2 2.2446144896095017e+00 0.0000000000000000e+00
89 5 -1.3477435071945351e+01 0.0000000000000000e+00
89 6 8.7834743682660665e+00 0.0000000000000000e+00
89 29 7.7257735520364195e+00 0.0000000000000000e+00
89 85 -2.6075348151002844e+00 0.0000000000000000e+00
89 86 -1.4502999917857944e+00 0.0000000000000000e+00
89 87 -2.9823700187739199e+01 0.0000000000000000e+00
89 88 -1.5913704524898709e+01 0.0000000000000000e+00
89 89 4.1283867847855262e+01 0.0000000000000000e+00
89 92 -3.8194216398696653e+01 0.0000000000000000e+00
89 126 -9.0650378382518852e+01 0.0000000000000000e+00
89 150 -2.4553962047864061e+01 0.0000000000000000e+00
89 152 2.8297725455989607e+01 0.0000000000000000e+00
90 3 1.0852485140256135e+01 0.0000000000000000e+00
90 4 -9.3878182451303580e+00 0.0000000000000000e+00
90 6 -6.6946413258602018e+00 0.0000000000000000e+00
90 12 -1.6935645517848045e+01 0.0000000000000000e+00
90 14 -1.1604651406136309e+01 0.0000000000000000e+00
90 87 5.1473750709501687e+00 0.0000000000000000e+00
90 90 1.4624784316126876e+01 0.0000000000000000e+00
90 91 2.1472831089100517e+01 0.0000000000000000e+00
90 92 -1.5234207653726999e+01 0.0000000000000000e+00
90 93 5.7878213972884396e+00 0.0000000000000000e+00
90 119 -1.4511438217375716e+01 0.0000000000000000e+00
90 120 -2.0609307911999629e+01 0.0000000000000000e+00
90 121 1.7355885974933507e+01 0.0000000000000000e+00
90 122 2.6780196646867150e+01 0.0000000000000000e+00
90 125 1.8095075137091108e+01 0.0000000000000000e+00
90 144 1.3382604049186964e+01 0.0000000000000000e+00
91 3 1.5604370003534353e+01 0.0000000000000000e+00
91 4 -5.9536194241145509e+01 0.0000000000000000e+00
91 6 -2.3288694994189619e+01 0.0000000000000000e+00
91 85 -2.3253842548856689e+01 0.0000000000000000e+00
91 87 5.1917657271147483e+01 0.0000000000000000e+00
91 88 -3.6949498603651034e+00 0.0000000000000000e+00
91 90 2.1472831089100517e+01 0.0000000000000000e+00
91 91 1.9987183943785425e+01 0.0000000000000000e+00
91 92 -2.6075348151653293e+00 0.0000000000000000e+00
91 93 -2.6020774803234076e+01 0.0000000000000000e+00
91 95 -7.6049649336359693e+00 0.0000000000000000e+00
91 96 -2.0434776960025673e+01 0.0000000000000000e+00
91 99 1.4255518621355611e+01 0.0000000000000000e+00
91 119 4.9528086829510066e+01 0.0000000000000000e+00
91 128 2.0032139326249474e+01 0.0000000000000000e+00
91 129 -2.2382684036448701e+01 0.0000000000000000e+00
92 2 7.7408918504385174e+00 0.0000000000000000e+00
92 5 8.7834743682865764e+00 0.0000000000000000e+00
92 6 -1.3477435072114222e+01 0.0000000000000000e+00
92 66 5.1374849561995696e+01 0.0000000000000000e+00
92 87 -2.9823700187864056e+01 0.0000000000000000e+00
92 89 -3.8194216398696653e+01 0.0000000000000000e+00
92 90 -1.5234207653726999e+01 0.0000000000000000e+00
92 91 -2.6075348151653293e+00 0.0000000000000000e+00
92 92 4.8126859401509321e+01 0.0000000000000000e+00
92 93 -4.0676346856151131e+00 0.0000000000000000e+00
92 120 -1.9422215090389944e+01 0.0000000000000000e+00
92 121 -1.5814075860780479e+01 0.0000000000000000e+00
92 122 -7.4395967888695111e+01 0.0000000000000000e+00
92 126 -5.2861465370024725e+01 0.0000000000000000e+00
92 150 5.2143212654248195e+01 0.0000000000000000e+00
92 152 -3.9361650367974505e+01 0.0000000000000000e+00
93 6 2.5398402557848376e+00 0.0000000000000000e+00
93 62 -4.1412937988349135e+01 0.0000000000000000e+00
93 85 -3.6949498603262718e+00 0.0000000000000000e+00
93 87 -3.8216861041312981e+01 0.0000000000000000e+00
93 88 -1.3510878614578672e+01 0.0000000000000000e+00
93 90 5.7878213972884396e+00 0.0000000000000000e+00
93 91 -2.6020774803234076e+01 0.0000000000000000e+00
93 92 -4.0676346856151131e+00 0.0000000000000000e+00
93 93 3.6605129437113803e+01 0.0000000000000000e+00
93 99 2.1237893729020371e+01 0.0000000000000000e+00
93 110 -4.9571093353742839e+01 0.0000000000000000e+00
93 120 1.0966120786086671e+01 0.0000000000000000e+00
93 121 -2.3584097786682609e+01 0.0000000000000000e+00
93 122 -2.6492805868140071e+01 0.0000000000000000e+00
93 123 -1.1846697480100222e+01 0.0000000000000000e+00
93 124 1.1846697480026791e+01 0.0000000000000000e+00
94 94 1.0000000000000000e+00 0.0000000000000000e+00
95 95 1.0000000000000000e+00 0.0000000000000000e+00
96 1 3.9086437101151272e+00 0.0000000000000000e+00
96 4 -5.9044935663294808e+01 0.0000000000000000e+00
96 5 -5.4704938971099068e+01 0.0000000000000000e+00
96 85 -5.9640945775636055e+01 0.0000000000000000e+00
96 86 -9.3878182450457377e+00 0.0000000000000000e+00
96 91 -2.0434776960025673e+01 0.0000000000000000e+00
96 94 -3.2994315576869099e+01 0.0000000000000000e+00
96 95 -4.8231052460292929e+01 0.0000000000000000e+00
96 96 4.4531507543960103e+01 0.0000000000000000e+00
96 99 2.2173180967405592e+01 0.0000000000000000e+00
96 119 8.1314905263216541e+00 0.0000000000000000e+00
96 128 -1.9825404177536374e+01 0.0000000000000000e+00
96 129 -2.7538428878798253e+01 0.0000000000000000e+00
97 97 1.0000000000000000e+00 0.0000000000000000e+00
98 98 1.0000000000000000e+00 0.0000000000000000e+00
99 99 1.0000000000000000e+00 0.0000000000000000e+00
100 100 1.0000000000000000e+00 0.0000000000000000e+00
101 101 1.0000000000000000e+00 0.0000000000000000e+00
102 7 1.9704305647103112e+01 0.0000000000000000e+00
102 10 -4.9938558690455395e+01 0.0000000000000000e+00
102 11 -1.6449340668442446e+01 0.0000000000000000e+00
102 42 -1.3076171287669142e-01 0.0000000000000000e+00
102 45 -1.1315492283762314e+01 0.0000000000000000e+00
102 47 -2.0784484760170976e+01 0.0000000000000000e+00
102 100 1.8095075137114236e+01 0.0000000000000000e+00
102 101 -5.1467486931143966e+00 0.0000000000000000e+00
102 102 2.4338204324231416e+01 0.0000000000000000e+00
102 103 -1.8534515960647752e+01 0.0000000000000000e+00
102 104 4.4725308532643950e+01 0.0000000000000000e+00
102 144 -1.8534515960636728e+01 0.0000000000000000e+00
102 145 1.3382604049143946e+01 0.0000000000000000e+00
102 146 -2.3088865822875555e+01 0.0000000000000000e+00
102 147 -1.3076171293508593e-01 0.0000000000000000e+00
102 155 -4.2995741129939603e+01 0.0000000000000000e+00
103 11 -4.9938558690229470e+01 0.0000000000000000e+00
103 13 1.9704305647106722e+01 0.0000000000000000e+00
103 14 -1.6449340668387485e+01 0.0000000000000000e+00
103 42 -2.0784484760043853e+01 0.0000000000000000e+00
103 45 2.3088865822876826e+01 0.0000000000000000e+00
103 47 -1.3076171287695948e-01 0.0000000000000000e+00
103 57 -1.1315492283742888e+01 0.0000000000000000e+00
103 59 -1.3076171282262211e-01 0.0000000000000000e+00
103 100 1.3382604049133356e+01 0.0000000000000000e+00
103 101 4.4725308532444068e+01 0.0000000000000000e+00
103 102 -1.8534515960647752e+01 0.0000000000000000e+00
103 103 2.4338204324209894e+01 0.0000000000000000e+00
103 119 -5.1467486931059216e+00 0.0000000000000000e+00
103 125 -1.8534515960668010e+01 0.0000000000000000e+00
103 127 1.8095075137100217e+01 0.0000000000000000e+00
103 155 -4.2995741129710538e+01 0.0000000000000000e+00
104 104 1.0000000000000000e+00 0.0000000000000000e+00
105 105 1.0000000000000000e+00 0.0000000000000000e+00
106 106 1.0000000000000000e+00 0.0000000000000000e+00
107 107 1.0000000000000000e+00 0.0000000000000000e+00
108 108 1.0000000000000000e+00 0.0000000000000000e+00
109 109 1.0000000000000000e+00 0.0000000000000000e+00
110 28 -5.5701502816725919e+00 0.0000000000000000e+00
110 37 -5.6012393306473179e+01 0.0000000000000000e+00
110 51 -4.4667381637868147e+01 0.0000000000000000e+00
110 62 4.6699834731317758e+01 0.0000000000000000e+00
110 68 -5.5701502816672406e+00 0.0000000000000000e+00
110 88 -1.6449340668565711e+01 0.0000000000000000e+00
110 93 -4.9571093353742839e+01 0.0000000000000000e+00
110 99 -1.9522950132493040e+01 0.0000000000000000e+00
110 108 -2.4674094276182615e+01 0.0000000000000000e+00
110 109 3.6324564183551701e+01 0.0000000000000000e+00
110 110 1.5629361379673297e+01 0.0000000000000000e+00
110 111 -2.6492805868309290e+01 0.0000000000000000e+00
110 115 -2.6492805868205451e+01 0.0000000000000000e+00
110 116 2.4674094276076779e+01 0.0000000000000000e+00
110 117 -3.6324564183482664e+01 0.0000000000000000e+00
110 121 1.9522950132407644e+01 0.0000000000000000e+00
110 122 -1.6449340668479199e+01 0.0000000000000000e+00
110 123 1.7915945424690477e+01 0.0000000000000000e+00
110 124 -1.7915945424637485e+01 0.0000000000000000e+00
111 25 -9.6124165763302869e+01 0.0000000000000000e+00
111 28 2.8911388257410497e+01 0.0000000000000000e+00
111 29 3.4963141930985500e+01 0.0000000000000000e+00
111 37 -8.8600184154211412e+00 0.0000000000000000e+00
111 51 -1.6449340668656632e+01 0.0000000000000000e+00
111 74 -6.8766106137039799e+01 0.0000000000000000e+00
111 81 2.8135536119804222e+01 0.0000000000000000e+00
111 88 -6.2810053867582674e+01 0.0000000000000000e+00
111 108 -2.6452672693858236e+01 0.0000000000000000e+00
111 109 -2.4841116200486788e+01 0.0000000000000000e+00
111 110 -2.6492805868309290e+01 0.0000000000000000e+00
111 111 9.0403347501215990e+01 0.0000000000000000e+00
111 112 -5.3875620264911724e+01 0.0000000000000000e+00
111 123 1.3114787574974235e+01 0.0000000000000000e+00
111 126 -5.2414568508313472e+01 0.0000000000000000e+00
111 135 4.9869806994679173e+01 0.0000000000000000e+00
112 112 1.0000000000000000e+00 0.0000000000000000e+00
113 113 1.0000000000000000e+00 0.0000000000000000e+00
114 114 1.0000000000000000e+00 0.0000000000000000e+00
115 37 -8.8600184153811892e+00 0.0000000000000000e+00
115 48 -2.8135536119673560e+01 0.0000000000000000e+00
115 51 -1.6449340668570123e+01 0.0000000000000000e+00
115 52 -3.2345921378490161e+01 0.0000000000000000e+00
115 66 3.4963141930920521e+01 0.0000000000000000e+00
115 68 2.8911388257303138e+01 0.0000000000000000e+00
115 69 -4.9660430814339179e+01 0.0000000000000000e+00
115 73 -2.6121572966439849e+01 0.0000000000000000e+00
115 80 -2.8135536119307094e+01 0.0000000000000000e+00
115 110 -2.6492805868205451e+01 0.0000000000000000e+00
115 113 2.3843651441156855e+01 0.0000000000000000e+00
115 114 -8.4021040675889608e+01 0.0000000000000000e+00
115 115 2.8685217943849054e+01 0.0000000000000000e+00
115 116 2.6452672693729774e+01 0.0000000000000000e+00
115 117 2.4841116200478140e+01 0.0000000000000000e+00
115 122 -6.2810053867281198e+01 0.0000000000000000e+00
115 124 -1.3114787574898628e+01 0.0000000000000000e+00
115 126 -6.9703611091676265e+01 0.0000000000000000e+00
115 137 1.9257522822590484e+01 0.0000000000000000e+00
116 34 1.2467401100150827e+01 0.0000000000000000e+00
116 37 1.8573837985352885e+01 0.0000000000000000e+00
116 38 -1.7489133700019053e+01 0.0000000000000000e+00
116 48 -1.0459575115202444e+01 0.0000000000000000e+00
116 51 -1.4294001552190565e+01 0.0000000000000000e+00
116 52 -6.0291147701710637e+00 0.0000000000000000e+00
116 110 2.4674094276076779e+01 0.0000000000000000e+00
116 114 3.1058087361754886e+01 0.0000000000000000e+00
116 115 2.6452672693729774e+01 0.0000000000000000e+00
116 116 2.0674004890939219e+01 0.0000000000000000e+00
116 117 -1.6620305244572116e+01 0.0000000000000000e+00
116 139 -1.2467401100284876e+01 0.0000000000000000e+00
116 142 1.7489133700079474e+01 0.0000000000000000e+00
117 34 -2.2467401100202494e+01 0.0000000000000000e+00
117 37 -2.1858170278467853e+01 0.0000000000000000e+00
117 38 1.9090602567182867e+01 0.0000000000000000e+00
117 51 1.5814075860695594e+01 0.0000000000000000e+00
117 63 -1.1601468867247080e+01 0.0000000000000000e+00
117 68 -1.6040587568851436e+01 0.0000000000000000e+00
117 110 -3.6324564183482664e+01 0.0000000000000000e+00
117 115 2.4841116200478140e+01 0.0000000000000000e+00
117 116 -1.6620305244572116e+01 0.0000000000000000e+00
117 117 1.7482138837763177e+01 0.0000000000000000e+00
117 122 -1.8684937856565870e+01 0.0000000000000000e+00
117 124 -1.3673584530817690e+01 0.0000000000000000e+00
117 142 1.1601468867171322e+01 0.0000000000000000e+00
117 147 -1.9090602567424561e+01 0.0000000000000000e+00
117 148 2.2467401100344624e+01 0.0000000000000000e+00
117 154 3.7030813913021143e-15 0.0000000000000000e+00
118 118 1.0000000000000000e+00 0.0000000000000000e+00
119 119 1.0000000000000000e+00 0.0000000000000000e+00
120 120 1.0000000000000000e+00 0.0000000000000000e+00
121 12 -1.8529352742312085e+01 0.0000000000000000e+00
121 59 -2.1872163005043500e+01 0.0000000000000000e+00
121 62 -1.6878599844663768e+01 0.0000000000000000e+00
121 63 1.9090602567261083e+01 0.0000000000000000e+00
121 90 1.7355885974933507e+01 0.0000000000000000e+00
121 92 -1.5814075860780479e+01 0.0000000000000000e+00
121 93 -2.3584097786682609e+01 0.0000000000000000e+00
121 110 1.9522950132407644e+01 0.0000000000000000e+00
121 120 -2.3912473529038962e+01 0.0000000000000000e+00
121 121 1.8386189882562711e+01 0.0000000000000000e+00
121 122 3.8419594873139047e+01 0.0000000000000000e+00
121 124 -1.3254578392777509e+01 0.0000000000000000e+00
121 125 -1.1315492283802474e+01 0.0000000000000000e+00
121 144 2.3088865822894064e+01 0.0000000000000000e+00
121 147 1.1006230771893897e+01 0.0000000000000000e+00
121 155 -1.3103411407798407e-12 0.0000000000000000e+00
122 62 7.6762526523808523e+00 0.0000000000000000e+00
122 66 -9.8945155584021592e+01 0.0000000000000000e+00
122 68 -2.8753234156699836e+01 0.0000000000000000e+00
122 69 3.3297687985166128e+01 0.0000000000000000e+00
122 90 2.6780196646867150e+01 0.0000000000000000e+00
122 92 -7.4395967888695111e+01 0.0000000000000000e+00
122 93 -2.6492805868140071e+01 0.0000000000000000e+00
122 110 -1.6449340668479199e+01 0.0000000000000000e+00
122 115 -6.2810053867281198e+01 0.0000000000000000e+00
122 117 -1.8684937856565870e+01 0.0000000000000000e+00
122 120 4.1206568474082488e+01 0.0000000000000000e+00
122 121 3.8419594873139047e+01 0.0000000000000000e+00
122 122 9.6033209253089808e+01 0.0000000000000000e+00
122 124 1.7089004829904916e+01 0.0000000000000000e+00
122 126 -5.2414568508100203e+01 0.0000000000000000e+00
122 152 5.4356250761189244e+01 0.0000000000000000e+00
123 123 1.0000000000000000e+00 0.0000000000000000e+00
124 59 1.2467401100265668e+01 0.0000000000000000e+00
124 62 1.3681197950840481e+01 0.0000000000000000e+00
124 63 -1.7489133700106120e+01 0.0000000000000000e+00
124 68 1.2832113993874794e+01 0.0000000000000000e+00
124 93 1.1846697480026791e+01 0.0000000000000000e+00
124 110 -1.7915945424637485e+01 0.0000000000000000e+00
124 115 -1.3114787574898628e+01 0.0000000000000000e+00
124 117 -1.3673584530817690e+01 0.0000000000000000e+00
124 121 -1.3254578392777509e+01 0.0000000000000000e+00
124 122 1.7089004829904916e+01 0.0000000000000000e+00
124 124 2.0522287454795265e+01 0.0000000000000000e+00
124 147 1.7489133700166555e+01 0.0000000000000000e+00
124 148 -1.2467401100399702e+01 0.0000000000000000e+00
125 3 1.9704305647036673e+01 0.0000000000000000e+00
125 12 -1.6449340668440335e+01 0.0000000000000000e+00
125 14 -4.9938558690263804e+01 0.0000000000000000e+00
125 42 -1.3076171282183557e-01 0.0000000000000000e+00
125 57 2.3088865822845005e+01 0.0000000000000000e+00
125 59 -2.0784484760233202e+01 0.0000000000000000e+00
125 90 1.8095075137091108e+01 0.0000000000000000e+00
125 103 -1.8534515960668010e+01 0.0000000000000000e+00
125 119 4.4725308532591029e+01 0.0000000000000000e+00
125 120 -5.1467486931251205e+00 0.0000000000000000e+00
125 121 -1.1315492283802474e+01 0.0000000000000000e+00
125 125 2.4338204324197150e+01 0.0000000000000000e+00
125 127 1.3382604049018745e+01 0.0000000000000000e+00
125 144 -1.8534515960642914e+01 0.0000000000000000e+00
125 147 -1.3076171287615540e-01 0.0000000000000000e+00
125 155 -4.2995741129862054e+01 0.0000000000000000e+00
126 2 2.3845487198258589e+01 0.0000000000000000e+00
126 25 4.7150779494431980e+01 0.0000000000000000e+00
126 28 1.6654539457568518e+00 0.0000000000000000e+00
126 29 7.7892879573674534e+01 0.0000000000000000e+00
126 66 4.7150779494343567e+01 0.0000000000000000e+00
126 68 1.6654539457543964e+00 0.0000000000000000e+00
126 69 7.0545466581885734e+01 0.0000000000000000e+00
126 71 -2.0824347982193679e+01 0.0000000000000000e+00
126 73 -8.5090389053661966e+01 0.0000000000000000e+00
126 74 -4.9127550432182126e+01 0.0000000000000000e+00
126 86 1.7230099436836259e+01 0.0000000000000000e+00
126 88 -7.3968809367457411e+01 0.0000000000000000e+00
126 89 -9.0650378382518852e+01 0.0000000000000000e+00
126 92 -5.2861465370024725e+01 0.0000000000000000e+00
126 111 -5.2414568508313472e+01 0.0000000000000000e+00
126 112 3.4950669228647313e-01 0.0000000000000000e+00
126 113 1.3854771328935094e+01 0.0000000000000000e+00
126 115 -6.9703611091676265e+01 0.0000000000000000e+00
126 120 2.9814011991935550e+00 0.0000000000000000e+00
126 122 -5.2414568508100203e+01 0.0000000000000000e+00
126 126 -1.6280212876367690e+02 0.0000000000000000e+00
126 135 4.5753430920864929e+01 0.0000000000000000e+00
126 137 1.0578089928095244e+02 0.0000000000000000e+00
126 150 1.2238074974045800e+02 0.0000000000000000e+00
126 152 5.2215371683106106e+01 0.0000000000000000e+00
127 127 1.0000000000000000e+00 0.0000000000000000e+00
128 128 1.0000000000000000e+00 0.0000000000000000e+00
129 129 1.0000000000000000e+00 0.0000000000000000e+00
130 130 1.0000000000000000e+00 0.0000000000000000e+00
131 15 7.7976060511603873e-01 0.0000000000000000e+00
131 18 -2.7722719906458007e+01 0.0000000000000000e+00
131 19 -2.7972608592053906e+01 0.0000000000000000e+00
131 70 -1.4194653042381727e+01 0.0000000000000000e+00
131 71 1.6817502623725026e+01 0.0000000000000000e+00
131 72 -3.9766653206274306e+01 0.0000000000000000e+00
131 105 1.1427000994260009e+01 0.0000000000000000e+00
131 107 -1.0793348766169260e+01 0.0000000000000000e+00
131 130 -3.5647361892048963e+01 0.0000000000000000e+00
131 131 3.1893340446453596e+01 0.0000000000000000e+00
131 132 -2.7905295652513615e+01 0.0000000000000000e+00
131 133 -1.5111365352317932e+01 0.0000000000000000e+00
131 134 -1.7582714884627066e+01 0.0000000000000000e+00
132 132 1.0000000000000000e+00 0.0000000000000000e+00
133 133 1.0000000000000000e+00 0.0000000000000000e+00
134 134 1.0000000000000000e+00 0.0000000000000000e+00
135 22 3.2847183223583592e+01 0.0000000000000000e+00
135 25 -8.7877538278337425e+01 0.0000000000000000e+00
135 26 -2.3098911292313055e+01 0.0000000000000000e+00
135 71 -6.8471544113370930e+00 0.0000000000000000e+00
135 73 2.3096201770041297e+01 0.0000000000000000e+00
135 74 -3.7704048746457630e+01 0.0000000000000000e+00
135 111 4.9869806994679173e+01 0.0000000000000000e+00
135 112 1.1646265066406764e+01 0.0000000000000000e+00
135 126 4.5753430920864929e+01 0.0000000000000000e+00
135 135 6.6742535265327945e+01 0.0000000000000000e+00
135 136 -2.6302969726668621e+01 0.0000000000000000e+00
135 137 -4.8530024155810395e+01 0.0000000000000000e+00
135 138 -3.3150802270595378e+01 0.0000000000000000e+00
136 136 1.0000000000000000e+00 0.0000000000000000e+00
137 26 -8.0589367291768525e+01 0.0000000000000000e+00
137 67 1.2806325667023055e+01 0.0000000000000000e+00
137 69 -2.1681074519067085e+01 0.0000000000000000e+00
137 71 1.8761698330425258e+01 0.0000000000000000e+00
137 73 -2.3497985375763026e+01 0.0000000000000000e+00
137 74 4.3920549752234976e+01 0.0000000000000000e+00
137 113 -1.6010611270798254e+01 0.0000000000000000e+00
137 115 1.9257522822590484e+01 0.0000000000000000e+00
137 126 1.0578089928095244e+02 0.0000000000000000e+00
137 135 -4.8530024155810395e+01 0.0000000000000000e+00
137 136 3.0778506490551161e+00 0.0000000000000000e+00
137 137 6.8088251883491168e+01 0.0000000000000000e+00
137 138 6.5067057938926666e+01 0.0000000000000000e+00
138 138 1.0000000000000000e+00 0.0000000000000000e+00
139 38 -2.6492805868186984e+01 0.0000000000000000e+00
139 48 4.8224670334251904e+01 0.0000000000000000e+00
139 56 -2.6492805868244766e+01 0.0000000000000000e+00
139 60 -6.6232014670380028e+00 0.0000000000000000e+00
139 61 -1.6449340668584849e+01 0.0000000000000000e+00
139 83 2.5713804034377343e+01 0.0000000000000000e+00
139 114 4.3159472534672005e+01 0.0000000000000000e+00
139 116 -1.2467401100284876e+01 0.0000000000000000e+00
139 118 5.7833483537418630e+01 0.0000000000000000e+00
139 139 3.1347421188505429e+01 0.0000000000000000e+00
139 140 3.7358738101214797e+01 0.0000000000000000e+00
139 141 1.7489133700101345e+01 0.0000000000000000e+00
139 142 -5.0043465199635079e+01 0.0000000000000000e+00
139 143 -1.9090602567377832e+01 0.0000000000000000e+00
139 158 -4.3463728932235412e+01 0.0000000000000000e+00
139 159 2.5713804034426939e+01 0.0000000000000000e+00
140 140 1.0000000000000000e+00 0.0000000000000000e+00
141 141 1.0000000000000000e+00 0.0000000000000000e+00
142 34 -1.7380470701013184e+01 0.0000000000000000e+00
142 37 6.6232014670320378e+00 0.0000000000000000e+00
142 38 -1.6449340668524162e+01 0.0000000000000000e+00
142 43 -8.4419963329562342e-01 0.0000000000000000e+00
142 48 -1.9090602567346330e+01 0.0000000000000000e+00
142 61 -1.7380470700988692e+01 0.0000000000000000e+00
142 63 -8.4419963324011627e-01 0.0000000000000000e+00
142 114 -4.3159472534650575e+01 0.0000000000000000e+00
142 116 1.7489133700079474e+01 0.0000000000000000e+00
142 117 1.1601468867171322e+01 0.0000000000000000e+00
142 139 -5.0043465199635079e+01 0.0000000000000000e+00
142 141 -1.2467401100322142e+01 0.0000000000000000e+00
142 142 2.4289567725206084e+01 0.0000000000000000e+00
142 143 2.2467401100254907e+01 0.0000000000000000e+00
142 148 -2.0043465199521435e+01 0.0000000000000000e+00
142 154 -3.8181205134555896e+01 0.0000000000000000e+00
143 143 1.0000000000000000e+00 0.0000000000000000e+00
144 9 -1.9704305647236016e+01 0.0000000000000000e+00
144 10 -1.6449340668505251e+01 0.0000000000000000e+00
144 12 -4.9938558690418944e+01 0.0000000000000000e+00
144 47 -1.3076171293588179e-01 0.0000000000000000e+00
144 59 -1.3076171287746324e-01 0.0000000000000000e+00
144 90 1.3382604049186964e+01 0.0000000000000000e+00
144 102 -1.8534515960636728e+01 0.0000000000000000e+00
144 104 -5.1467486931015891e+00 0.0000000000000000e+00
144 120 4.4725308532538321e+01 0.0000000000000000e+00
144 121 2.3088865822894064e+01 0.0000000000000000e+00
144 125 -1.8534515960642914e+01 0.0000000000000000e+00
144 144 2.4338204324112478e+01 0.0000000000000000e+00
144 145 1.8095075137176806e+01 0.0000000000000000e+00
144 146 1.1315492283700914e+01 0.0000000000000000e+00
144 147 -2.0784484759981577e+01 0.0000000000000000e+00
144 155 -4.2995741129788058e+01 0.0000000000000000e+00
145 145 1.0000000000000000e+00 0.0000000000000000e+00
146 146 1.0000000000000000e+00 0.0000000000000000e+00
147 47 -1.6764324960499092e+01 0.0000000000000000e+00
147 59 -1.6764324960529994e+01 0.0000000000000000e+00
147 62 6.6232014669954147e+00 0.0000000000000000e+00
147 63 -1.6449340668433234e+01 0.0000000000000000e+00
147 68 -4.3159472534852263e+01 0.0000000000000000e+00
147 102 -1.3076171293508593e-01 0.0000000000000000e+00
147 117 -1.9090602567424561e+01 0.0000000000000000e+00
147 121 1.1006230771893897e+01 0.0000000000000000e+00
147 124 1.7489133700166555e+01 0.0000000000000000e+00
147 125 -1.3076171287615540e-01 0.0000000000000000e+00
147 144 -2.0784484759981577e+01 0.0000000000000000e+00
147 146 2.1872163005102287e+01 0.0000000000000000e+00
147 147 2.6777493357773082e+01 0.0000000000000000e+00
147 148 -5.0043465199802533e+01 0.0000000000000000e+00
147 149 -1.2467401100436994e+01 0.0000000000000000e+00
147 155 4.1527049998683303e+01 0.0000000000000000e+00
148 34 -8.4419963324012137e-01 0.0000000000000000e+00
148 43 -1.7380470700979110e+01 0.0000000000000000e+00
148 46 -6.6232014670014090e+00 0.0000000000000000e+00
148 47 -1.6449340668493939e+01 0.0000000000000000e+00
148 61 -8.4419963329562941e-01 0.0000000000000000e+00
148 63 -1.7380470700980037e+01 0.0000000000000000e+00
148 68 4.3159472534873686e+01 0.0000000000000000e+00
148 117 2.2467401100344624e+01 0.0000000000000000e+00
148 124 -1.2467401100399702e+01 0.0000000000000000e+00
148 142 -2.0043465199521435e+01 0.0000000000000000e+00
148 143 1.1601468867146648e+01 0.0000000000000000e+00
148 146 -1.9090602567456074e+01 0.0000000000000000e+00
148 147 -5.0043465199802533e+01 0.0000000000000000e+00
148 148 2.4289567725451942e+01 0.0000000000000000e+00
148 149 1.7489133700188429e+01 0.0000000000000000e+00
148 154 3.8181205134601356e+01 0.0000000000000000e+00
149 149 1.0000000000000000e+00 0.0000000000000000e+00
150 2 -2.2132360342272484e+01 0.0000000000000000e+00
150 24 -7.9192680165582928e+01 0.0000000000000000e+00
150 27 -1.2876160023521139e+01 0.0000000000000000e+00
150 29 -2.7518010312262533e+01 0.0000000000000000e+00
150 86 -1.7947431573196184e+01 0.0000000000000000e+00
150 88 2.4955872988872677e+01 0.0000000000000000e+00
150 89 -2.4553962047864061e+01 0.0000000000000000e+00
150 92 5.2143212654248195e+01 0.0000000000000000e+00
150 126 1.2238074974045800e+02 0.0000000000000000e+00
150 150 6.2809099964821300e+01 0.0000000000000000e+00
150 151 -6.5525594455901853e+01 0.0000000000000000e+00
150 152 -5.8574147841957966e+01 0.0000000000000000e+00
150 153 3.2570497402591396e+00 0.0000000000000000e+00
151 151 1.0000000000000000e+00 0.0000000000000000e+00
152 2 6.6326709989783401e+00 0.0000000000000000e+00
152 24 -2.2959242579385361e+01 0.0000000000000000e+00
152 65 -3.2777348867235624e+01 0.0000000000000000e+00
152 66 -9.1333829836593821e+01 0.0000000000000000e+00
152 89 2.8297725455989607e+01 0.0000000000000000e+00
152 92 -3.9361650367974505e+01 0.0000000000000000e+00
152 120 -1.3749929598159451e+01 0.0000000000000000e+00
152 122 5.4356250761189244e+01 0.0000000000000000e+00
152 126 5.2215371683106106e+01 0.0000000000000000e+00
152 150 -5.8574147841957966e+01 0.0000000000000000e+00
152 151 3.3958510568592885e+01 0.0000000000000000e+00
152 152 6.9394813869233687e+01 0.0000000000000000e+00
152 153 -2.6377417283614818e+01 0.0000000000000000e+00
153 153 1.0000000000000000e+00 0.0000000000000000e+00
154 31 6.9087338386101216e-15 0.0000000000000000e+00
154 34 -3.8181205134621948e+01 0.0000000000000000e+00
154 35 -3.8181205134487584e+01 0.0000000000000000e+00
154 40 -3.7030813424529693e-15 0.0000000000000000e+00
154 43 3.8181205134735698e+01 0.0000000000000000e+00
154 44 3.8181205134533059e+01 0.0000000000000000e+00
154 61 -3.8181205134690224e+01 0.0000000000000000e+00
154 63 3.8181205134667408e+01 0.0000000000000000e+00
154 117 3.7030813913021143e-15 0.0000000000000000e+00
154 142 -3.8181205134555896e+01 0.0000000000000000e+00
154 143 6.9087338874477051e-15 0.0000000000000000e+00
154 148 3.8181205134601356e+01 0.0000000000000000e+00
154 154 2.1130095190560020e+01 0.0000000000000000e+00
155 42 4.1527049998609456e+01 0.0000000000000000e+00
155 45 -2.6659418781667979e-13 0.0000000000000000e+00
155 47 4.1527049998830122e+01 0.0000000000000000e+00
155 57 7.8677161342840645e-13 0.0000000000000000e+00
155 59 4.1527049998756240e+01 0.0000000000000000e+00
155 102 -4.2995741129939603e+01 0.0000000000000000e+00
155 103 -4.2995741129710538e+01 0.0000000000000000e+00
155 121 -1.3103411407798407e-12 0.0000000000000000e+00
155 125 -4.2995741129862054e+01 0.0000000000000000e+00
155 144 -4.2995741129788058e+01 0.0000000000000000e+00
155 146 -7.9377207121057590e-13 0.0000000000000000e+00
155 147 4.1527049998683303e+01 0.0000000000000000e+00
155 155 2.4261434594136784e+01 0.0000000000000000e+00
156 33 -2.5670338834546357e+01 0.0000000000000000e+00
156 36 1.1190235350485764e+01 0.0000000000000000e+00
156 38 -4.1123351671170269e+01 0.0000000000000000e+00
156 55 1.5800734433545442e+01 0.0000000000000000e+00
156 56 -3.6883992664818962e+01 0.0000000000000000e+00
156 77 -2.2056167583452986e+01 0.0000000000000000e+00
156 79 -6.8187948653282824e+00 0.0000000000000000e+00
156 83 2.4414905684616095e+01 0.0000000000000000e+00
156 84 -3.1860574185002545e+01 0.0000000000000000e+00
156 156 6.1083625907012493e+00 0.0000000000000000e+00
156 157 -3.9956534800313072e+01 0.0000000000000000e+00
156 158 -2.5800734433504406e+01 0.0000000000000000e+00
156 159 -5.8007344335686266e+00 0.0000000000000000e+00
157 157 1.0000000000000000e+00 0.0000000000000000e+00
158 38 -2.2380470700976407e+01 0.0000000000000000e+00
158 48 -1.5800734433625859e+01 0.0000000000000000e+00
158 56 -1.6449340668568073e+01 0.0000000000000000e+00
158 79 6.6449340668385464e+00 0.0000000000000000e+00
158 83 -2.4264463365716306e+01 0.0000000000000000e+00
158 84 1.6558003667506682e+01 0.0000000000000000e+00
158 118 -2.8311600733340470e+01 0.0000000000000000e+00
158 139 -4.3463728932235412e+01 0.0000000000000000e+00
158 140 -1.5800734433651087e+01 0.0000000000000000e+00
158 156 -2.5800734433504406e+01 0.0000000000000000e+00
158 157 2.3159472534852597e+01 0.0000000000000000e+00
158 158 3.4072241726803639e+01 0.0000000000000000e+00
158 159 -1.4286195965629952e+01 0.0000000000000000e+00
159 159 1.0000000000000000e+00 0.0000000000000000e+00
160 160 1.0000000000000000e+00 0.0000000000000000e+00
161 161 1.0000000000000000e+00 0.0000000000000000e+00
162 162 1.0000000000000000e+00 0.0000000000000000e+00
163 82 3.4515451454850385e+01 3.8489110873569246e+00
163 160 2.1497524395734768e+01 1.9499899280662724e+01
163 161 1.4008478840608420e+00 -7.5343307515763003e-01
163 162 -1.2196825653632661e+01 1.5641330155775298e+01
163 163 2.2510410138436065e+01 8.4389156143333963e+01
163 164 -2.6183089251002929e+01 8.6097363071076423e+00
163 165 -2.2436653748193390e+01 2.0499084456452238e+01
163 166 5.0298975349574206e+01 1.4842150400670381e+01
163 167 -2.6803695779278112e+01 -1.6132892868185778e+01
163 168 -3.8511325096442931e+01 2.5522627483546486e+01
163 169 -9.1553036700265849e+01 -1.1969997845311958e+01
163 170 -8.9999833448501079e+00 1.2837647954409164e+01
163 173 1.4023624292469641e+01 1.9347448736703832e+01
164 78 1.6590702102767654e+01 2.5586036767465039e+00
164 160 -2.3496219493310520e+01 2.3101912918228471e+01
164 161 -1.8390402191384574e+01 -5.5835314161534377e-01
164 162 -2.5227587137054397e-01 -6.1843708796908436e-01
164 163 -2.6183089251002929e+01 8.6097363071076423e+00
164 164 1.6090134049183398e+01 8.1907504887071283e+01
164 165 -2.4774915147828050e+01 6.2374778930169015e+00
164 166 -1.2512603446336957e+01 1.6229142857435956e+01
164 169 -3.0806366712554560e+01 2.1201538897996496e+01
164 171 -8.2250515124419906e+01 -5.8065976892442253e+00
164 172 5.6835408712472145e+01 2.0833724947083610e+01
164 173 2.1223388950964001e+01 4.2457678757167701e+00
164 174 1.9602853188813874e-01 1.4165539466535193e+01
165 84 -3.7832961478118847e+01 -3.2825698559557090e+00
165 160 1.6531237554313862e+00 -1.3499598718854555e-01
165 161 8.6690401492833384e+00 -5.9408447443407626e+00
165 162 1.6822584276158057e+01 2.0046174854679055e+01
165 163 -2.2436653748193390e+01 2.0499084456452238e+01
165 164 -2.4774915147828050e+01 6.2374778930169015e+00
165 165 2.7925821841252557e+01 7.1671489930421686e+01
165 167 -1.4901819251935590e+01 -1.7991375455703238e+01
165 168 -7.9172211541475633e+01 -9.9940099647525749e+00
165 170 3.7634590701983306e+01 1.9032139126938894e+01
165 171 -2.6922610425819837e+01 1.6826922659380720e+01
165 172 -6.6425878394926841e+00 9.4899508626992883e+00
165 174 2.5694747932135407e+01 1.4173086481163089e+01
166 166 1.0000000000000000e+00 0.0000000000000000e+00
167 16 -6.5797362673579425e+00 3.1453696833497071e+00
167 82 -8.9272429425853783e+00 -3.4589468699359380e+00
167 97 2.0514030023817060e+01 1.3750491365210835e+00
167 162 -1.2009288976612700e+01 -3.3238629006396518e+00
167 163 -2.6803695779278112e+01 -1.6132892868185778e+01
167 165 -1.4901819251935590e+01 -1.7991375455703238e+01
167 166 7.9610550891068108e+00 5.4202610275181451e-01
167 167 5.0279026533077049e+00 1.6752772562320168e+01
167 168 1.3212294088659988e+01 6.4276134106577265e+00
167 169 2.3463265772322465e+01 6.3067088567663845e+00
167 170 9.5671907912704546e-01 -1.2540959472463484e+00
167 183 -6.6232014670208859e+00 4.7224363315093463e+00
167 184 -1.7267627089756875e+01 -4.7711414554528426e+00
167 185 -6.5797362673925370e+00 8.0496906781747928e+00
167 186 4.0663038595682153e+00 3.6532251534193549e+00
167 187 7.3127067936802908e+00 2.7704069572967001e+00
168 78 6.6231920572396881e+00 6.4955004263128363e-02
168 82 1.4206686392760542e+01 -1.9572360451562325e+00
168 84 3.8704564266914616e+01 4.9984024816194159e+00
168 162 -2.3901802596785696e+01 -5.1537275012940764e+00
168 163 -3.8511325096442931e+01 2.5522627483546486e+01
168 165 -7.9172211541475633e+01 -9.9940099647525749e+00
168 166 1.1052185682527918e+01 -2.4577977694094590e+00
168 167 1.3212294088659988e+01 6.4276134106577265e+00
168 168 9.2906839383176845e+00 3.5430033938111322e+01
168 169 -3.9160866933322978e+01 3.4649119354767262e+00
168 170 -3.7400213694563348e+01 -7.4078929939014753e+00
168 171 -6.1300079343989779e+01 2.8655437744915164e+00
168 174 -2.3820369262687976e+01 -7.2183305879539237e+00
169 78 1.9733780972010294e+01 -1.8882279229275989e+00
169 82 -3.0214466474654518e+01 -5.2151641091413365e+00
169 84 4.8349918865278578e+00 4.3782046877685804e-02
169 160 -2.6536227738806595e+01 -3.1183058792678757e+00
169 163 -9.1553036700265849e+01 -1.1969997845311958e+01
169 164 -3.0806366712554560e+01 2.1201538897996496e+01
169 166 -4.5757031052494646e+01 -6.8735580603817015e+00
169 167 2.3463265772322465e+01 6.3067088567663845e+00
169 168 -3.9160866933322978e+01 3.4649119354767262e+00
169 169 2.7197071783798865e+01 3.1807878361464454e+01
169 171 -6.8156782193453807e+01 4.2292399774230205e+00
169 172 1.0482812795975917e+01 -2.3680673405288548e+00
169 173 -1.4510293492790126e+01 -8.3719705317788318e+00
170 170 1.0000000000000000e+00 0.0000000000000000e+00
171 78 -4.5173441605140226e+01 -1.6420918169113734e+00
171 82 -1.7882001707118309e+00 -2.1172957385442559e-02
171 84 -4.2542846387966357e+01 2.8294796794326182e+00
171 161 6.8386163713808230e+00 4.6755886038359051e+00
171 164 -8.2250515124419906e+01 -5.8065976892442253e+00
171 165 -2.6922610425819837e+01 1.6826922659380720e+01
171 168 -6.1300079343989779e+01 2.8655437744915164e+00
171 169 -6.8156782193453807e+01 4.2292399774230205e+00
171 170 1.4012592215430869e+01 -3.9357607319982124e+00
171 171 3.1564298185478602e+01 2.7567842105724523e+01
171 172 -5.3142773245384276e+01 -1.3879379995436587e+01
171 173 -6.1078893067917361e+00 -4.9266710172753587e+00
171 174 -1.2269555282418729e+01 2.6478918365952859e+00
172 172 1.0000000000000000e+00 0.0000000000000000e+00
173 173 1.0000000000000000e+00 0.0000000000000000e+00
174 174 1.0000000000000000e+00 0.0000000000000000e+00
175 175 1.0000000000000000e+00 0.0000000000000000e+00
176 176 1.0000000000000000e+00 0.0000000000000000e+00
177 15 -2.2120239984752685e+00 -1.5742632787019710e+00
177 16 -2.0514030023892047e+01 -1.3750491365268884e+00
177 17 -1.8258022158409172e+01 -5.2307929015138777e-01
177 132 2.0514030023840387e+01 1.3750491365246227e+00
177 134 6.5797362674102011e+00 -3.1453696833694891e+00
177 175 -4.0663038595717591e+00 -3.6532251533722970e+00
177 176 -6.5797362673756066e+00 8.0496906781495401e+00
177 177 -1.1449666170561510e+01 1.1223961504197458e+01
177 178 6.6232014670210191e+00 -4.7224363315167324e+00
177 179 -1.7267627089746107e+01 -4.7711414554909073e+00
177 180 -7.3127067936141499e+00 -2.7704069573139103e+00
177 181 -1.5122720435175783e+01 -2.2296970940601595e+00
177 182 -5.9905882338681682e+00 1.8855374488560275e+00
177 183 -2.4585073482092710e+01 -2.9352703161712053e+00
177 186 -1.3977758956056478e+01 -8.9354862101273724e+00
177 188 8.3449525576290906e+00 9.2530887962220500e+00
178 178 1.0000000000000000e+00 0.0000000000000000e+00
179 179 1.0000000000000000e+00 0.0000000000000000e+00
180 180 1.0000000000000000e+00 0.0000000000000000e+00
181 181 1.0000000000000000e+00 0.0000000000000000e+00
182 182 1.0000000000000000e+00 0.0000000000000000e+00
183 183 1.0000000000000000e+00 0.0000000000000000e+00
184 184 1.0000000000000000e+00 0.0000000000000000e+00
185 185 1.0000000000000000e+00 0.0000000000000000e+00
186 15 1.8869095957030670e+01 1.7748727208705120e+00
186 16 1.6743244955299030e+01 1.5342864293916341e+00
186 17 1.6449340668561572e+01 -6.8962254315661315e+00
186 162 -5.6677727268187281e+00 -5.6223910390649907e+00
186 167 4.0663038595682153e+00 3.6532251534193549e+00
186 170 -1.0842324520214579e+01 -1.7999646897466231e+01
186 177 -1.3977758956056478e+01 -8.9354862101273724e+00
186 181 1.1558003667605412e+01 -8.9356719865239960e+00
186 182 -9.8696044010799859e+00 1.1229564491304252e+01
186 183 -4.2213671360907462e+01 -1.1712719559224167e+01
186 184 -2.2209031116839633e+00 6.3774795047488428e+00
186 185 -1.2626968689679341e+01 9.2466315867935478e+00
186 186 -1.1898226800989411e+01 2.7683004412550762e+01
186 187 1.7329751716346326e+01 -1.1413502120251970e+01
186 188 4.6170075053954935e+00 -3.6119755249001813e+00
186 189 3.6125989485269844e-01 -4.8246483795686501e+00
187 187 1.0000000000000000e+00 0.0000000000000000e+00
188 188 1.0000000000000000e+00 0.0000000000000000e+00
189 189 1.0000000000000000e+00 0.0000000000000000e+00
Mat_0x84000000_1 = spconvert(zzz);
%Vec Object: 1 MPI process
% type: seq
Vec_0x84000000_1 = [
2.2149713067704293e+00 - 4.8295838887390877e-03i
9.5903389407682701e-17 - 2.0911036767973006e-19i
-3.6868434123478322e-01 + 3.0513170294283582e-03i
1.5619954673770539e-01 + 2.5190766051046936e-03i
7.3459676461649392e-01 + 1.1506907791226789e-03i
2.2149713067704822e+00 - 4.8295838887390313e-03i
-1.0655749333642738e-03 - 2.1861864422900962e-02i
-9.1078509832788834e-01 - 6.8671710905254799e-02i
5.1699366018877513e-01 + 6.3658120523194264e-02i
-1.9916340605556908e-02 + 2.5589848968919013e-02i
-2.2430504846423166e-01 + 2.3328695522948018e-01i
2.7986500910351538e-02 + 6.7659051119051170e-02i
-2.7640085878933623e-01 - 2.2432869438568891e-03i
-1.4525745715363511e-01 + 4.7496218115772426e-02i
-4.8131812451502623e-02 - 7.0557009142595550e-02i
2.1904426186367892e-01 + 4.7232491009985708e-02i
-2.2628927812459666e-02 - 2.2088625467595081e-02i
9.5792371015845354e-02 + 1.4121427037546532e-02i
-9.0606856543329867e-02 - 2.4996897374991854e-02i
-3.2538592138746797e-01 + 8.7405387973851334e-02i
8.5209034052166274e-02 + 5.3272411800119032e-02i
1.1020218440973585e-03 - 1.1081546008804379e-02i
5.8865428246754073e-02 - 2.3737598065440721e-02i
7.4163510569459051e-02 - 2.6706655694135281e-03i
5.7408696183814623e-01 + 1.0059973223066754e-01i
3.1354875155634360e-01 + 5.8726066681349647e-03i
3.0033068492567433e-01 + 4.0522447085718637e-02i
2.8486370554654372e-01 - 1.3019158466321579e-01i
3.8222897573310821e-02 - 5.4259092185802047e-03i
9.8392311703494148e-02 + 3.9625081813548742e-02i
3.6046490835975242e-01 - 2.1477434987026263e-02i
3.6193076193987089e-01 + 2.1376067710013876e-02i
1.0009043675417224e-01 + 6.7895074667704489e-03i
-1.4704549105311218e-01 + 6.6184038169534443e-03i
8.0849580079885422e-02 - 5.4751730547655642e-02i
1.6552869793474925e-01 - 6.5843589394226340e-02i
-1.7125938819699302e-01 - 1.9333174307095802e-02i
-5.6614450002707395e-01 + 1.8747123089751627e-02i
-4.3392724887512341e-01 + 3.0072656833225749e-02i
2.5139958478151686e-01 - 7.8069500567605324e-02i
1.5186001541372279e-01 + 1.9329170755019689e-02i
6.8363493213486493e-01 - 4.4761005147435376e-02i
-1.4669658712551548e-01 - 2.5410875022849895e-02i
-5.9738192623665931e-01 + 1.1595760296284106e-01i
4.8817214072817694e-02 + 6.2400362030879702e-02i
1.6705532588118854e-01 - 1.2325187077489568e-02i
2.6848009784020915e-01 - 1.2786461966365781e-01i
-4.8158918995159561e-01 + 1.6182039505749073e-02i
-7.0117812660062717e-01 - 7.9411466534748426e-02i
8.5346777679070074e-01 - 4.3598264095322255e-02i
1.0027364094130973e+00 + 6.8347814002461413e-02i
-3.9377376769652572e-01 + 3.1921602288948400e-02i
9.6679119421085269e-01 + 2.4141696875398435e-02i
3.6072402946357807e-01 - 2.2952147885558435e-02i
8.4175632735151870e-02 - 4.8328341895552566e-02i
8.5427759718834498e-02 - 1.5384867772496980e-02i
-9.1609106585751299e-01 - 5.2001200669095263e-02i
2.0196257164332685e-02 + 1.0549789263397061e-01i
-4.5788661713242457e-01 - 2.7618780247400991e-02i
5.9712257333260868e-02 + 4.5440924439338016e-03i
7.7596649640496251e-01 - 1.9544517402705391e-01i
4.5307436420745872e-01 + 8.9403042266077579e-02i
4.2634499804593196e-01 + 5.9122516661190679e-02i
-6.8729437329787285e-02 - 3.2041837788226057e-02i
1.0994917436856230e-02 - 1.4435863897199525e-02i
4.2293694300650686e-01 + 2.7840887508704195e-02i
6.1952181668983815e-02 + 9.0832583678214420e-03i
-7.6450570860746678e-02 + 3.6154825887408426e-02i
1.2479628909898192e-01 - 4.1520201207910688e-02i
2.7549854188988138e-01 - 2.1788754805580453e-02i
1.6970614350827157e-01 - 4.8164568064454391e-02i
9.0038717575489910e-02 - 5.8426528036116296e-02i
8.5847070401321668e-01 + 6.0699185151494523e-03i
-1.6254493218475649e-01 - 8.5713761292492793e-02i
-3.8595480506538787e-01 - 5.4276857457363985e-02i
3.1568369630357795e-01 - 3.0029110354376398e-03i
1.7474237407394697e-01 + 4.2145233990959000e-02i
1.3988305319257480e-01 - 5.2300796674830584e-02i
2.5440595485120737e-01 + 1.6915838215439322e-02i
-2.9698280452395176e-01 + 9.2218600279524929e-02i
3.5912349185162251e-01 - 2.6086281076175891e-02i
-5.6487725285284474e-03 - 1.6011337718813540e-02i
-3.9484498769499993e-03 - 3.1441265657118786e-02i
-4.1517393080220642e-03 + 8.7815596932424578e-03i
3.8585709194248530e-02 - 7.9201669546819217e-02i
-2.4413635092351851e-02 + 2.3810397947847745e-02i
2.8725628908471350e-02 + 1.4771492905419188e-02i
2.1199082557847436e-02 - 1.0419460603712183e-02i
7.2477462297039039e-02 + 5.6886809621827565e-02i
-1.3208827441732857e-01 - 1.9543748266906196e-03i
% type: seq
2.2214414690804367e+00
9.6183533215257419e-17
2.2214414690804896e+00
