[petsc-users] Memory usage scaling with number of processors
Matthew Knepley
knepley at gmail.com
Wed Jul 24 20:44:04 CDT 2024
On Wed, Jul 24, 2024 at 9:32 PM Matthew Thomas <matthew.thomas1 at anu.edu.au>
wrote:
> Hi Matt,
> I have attached the configuration file below.
>From the log:
MPI:
Version: 3
mpiexec: /apps/intel-tools/intel-mpi/2021.11.0/bin/mpiexec
Implementation: mpich3
I_MPI_NUMVERSION: 20211100300 MPICH_NUMVERSION: 30400002
so you want to use that mpiexec. This is what will be used if you try
make check
in $PETSC_DIR.
Matt
> Thanks,
> Matt
> On 25 Jul 2024, at 11:26 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jul 24, 2024 at 8:37 PM Matthew Thomas <matthew.thomas1 at anu.edu.au>
> wrote:
> Hello Matt,
> Thanks for the help. I believe the problem is coming from an incorrect
> linking with MPI and PETSc.
> I tried running with petscmpiexec from
> $PETSC_DIR/lib/petsc/bin/petscmpiexec. This gave me the error
> Error build location not found! Please set PETSC_DIR and PETSC_ARCH
> correctly for this build.
> Naturally I have set these two values and echo $PETSC_DIR gives the path I
> expect, so it seems like I am running my programs with a different version
> of MPI than petsc expects which could explain the memory usage.
> Do you have any ideas how to fix this?
> Yes. First we determine what MPI you configured with. Send configure.log,
> which has this information.
> Thanks,
> Matt
> Thanks,
> Matt
> On 24 Jul 2024, at 8:41 PM, Matthew Knepley <knepley at gmail.com> wrote:
> You don't often get email from knepley at gmail.com. Learn why this is
> important <https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!Z2rv8eb7Cg2HQOiE2c11H9inWPs58oj2IuqkyMjKueg_gDd5G7Ya_P8dkPggDNh_IrYKprQIK0WvlW0CILAi$ >
> On Tue, Jul 23, 2024 at 8:02 PM Matthew Thomas <matthew.thomas1 at anu.edu.au>
> wrote:
> Hello Matt,
> I have attached the output with mat_view for 8 and 40 processors.
> I am unsure what is meant by the matrix communicator and the partitioning.
> I am using the default behaviour in every case. How can I find this
> information?
> This shows that the matrix is taking the same amount of memory for 8 and
> 40 procs, so that is not your problem. Also,
> it is a very small amount of memory:
> 100K rows x 3 nz/row x 8 bytes/nz = 2.4 MB
> and 50% overhead for indexing, so something under 4MB. I am not sure what
> is taking up the rest of the memory, but I do not
> think it is PETSc from the log you included.
> Thanks,
> Matt
> I have attached the log view as well if that helps.
> Thanks,
> Matt
> Also, you could run with
> -mat_view ::ascii_info_detail
> and send the output for both cases. The storage of matrix values is not
> redundant, so something else is
> going on. First, what communicator do you use for the matrix, and what
> partitioning?
> Thanks,
> Matt
> On Mon, Jul 22, 2024 at 10:27 PM Barry Smith <bsmith at petsc.dev> wrote:
> This Message Is From an External Sender
> This message came from outside your organization.
> Send the code.
> On Jul 22, 2024, at 9:18 PM, Matthew Thomas via petsc-users <
> Hello,
> I am using petsc and slepc to solve an eigenvalue problem for sparse matrices. When I run my code with double the number of processors, the memory usage also doubles.
> I am able to reproduce this behaviour with ex1 of slepc’s hands on exercises.
> The issue is occurring with petsc not with slepc as this still occurs when I remove the solve step and just create and assemble the petsc matrix.
> With n=100000, this uses ~1Gb with 8 processors, but ~5Gb with 40 processors.
> This was done with petsc 3.21.3, on linux compiled with Intel using Intel-MPI
> Is this the expected behaviour? If not, how can I bug fix this?
> Thanks,
> Matt
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z2rv8eb7Cg2HQOiE2c11H9inWPs58oj2IuqkyMjKueg_gDd5G7Ya_P8dkPggDNh_IrYKprQIK0WvlSHTmW6H$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z2rv8eb7Cg2HQOiE2c11H9inWPs58oj2IuqkyMjKueg_gDd5G7Ya_P8dkPggDNh_IrYKprQIK0Wvlfv4A8zx$ >
> experiments lead.
> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z2rv8eb7Cg2HQOiE2c11H9inWPs58oj2IuqkyMjKueg_gDd5G7Ya_P8dkPggDNh_IrYKprQIK0WvlSHTmW6H$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Z2rv8eb7Cg2HQOiE2c11H9inWPs58oj2IuqkyMjKueg_gDd5G7Ya_P8dkPggDNh_IrYKprQIK0Wvlfv4A8zx$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240724/5fe92f16/attachment-0001.html>
