[petsc-users] MKL Pardiso returning NAN values
Mark Adams mfadams at lbl.gov
Thu Jul 11 09:37:52 CDT 2024
Not sure I understand the question but if you use '-ksp_type richardson'
then you get a convergence check. Then you might say '-ksp_rtol 1e-1
-ksp_max_it 1' just to check if it failed with convered _reason. Just
requires one residual calculation.
On Wed, Jul 10, 2024 at 5:02 PM Chris Hewson <chris at resfrac.com> wrote:
> Hi There, We have a matrix that is singular and trying to solve it. We
> first use an iterative solve with KSPBCGS, the solution vector is nan
> values and the converged reason from PETSc of KSP_DIVERGED_NANORINF, that's
> great and what I would
> ZjQcmQRYFpfptBannerStart
> This Message Is From an External Sender
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> Hi There,
> We have a matrix that is singular and trying to solve it. We first use an
> iterative solve with KSPBCGS, the solution vector is nan values and the
> converged reason from PETSc of KSP_DIVERGED_NANORINF, that's great and what
> I would expect.
> Sometimes in our program we redo a failed solve using the MKL Pardiso
> solver, when the same matrix and vectors get put into that solver which is
> a KSPPREONLY, I get KSP_CONVERGED_ITS as a converged reason and solution
> vector with nan values in it.
> Stepping through the PETSc calls, I see that the external call to Pardiso
> doesn't return an error for this, so not really the fault of PETSc, but
> curious if y'all have seen this before or a solution/workaround to this?
> *Chris Hewson*
> Senior Reservoir Simulation Engineer
> ResFrac
> +1.587.575.9792
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240711/c8f04c72/attachment.html>
