[petsc-users] Weird handling of compiler flags by the build system
meator
meator.dev at gmail.com
Mon Jul 1 14:53:43 CDT 2024
On 7/1/24 6:53 PM, Stefano Zampini wrote:> Since you said "your
package", I have a few questions:
> - why do your users need to know how to compile with PETSc?
I provide two main packages: petsc and petsc-devel. petsc-devel contains
header files, symlinks to dynamic library & more. petsc-devel should
also be fully usable for personal development of PETSc dependent programs.
> - Shouldn't this be handled by you?
I compile PETSc. That's what the users of my package will get from me.
But they may link with it however they wish. And since the Makefile
method is official & provided by upstream, I don't see a reason why I
shouldn't take care in supporting it. The extra pkg-config variables are
not standard and most systems integrating with PETSc using pkg-config
will simply ignore these, but that isn't true for the Makefile.user.
> - And also, can't you tell your users how to use PETSc? (for example not
> to use the Makefile.user)
This is a decision I leave to upstream. As a packager, I try to not
alter the functionality of programs & libraries I package, because that
would make my packages less trustworthy. If I'd believed that
Makefile.user should be removed (which I don't), I would first write on
this mailing list requesting its removal from PETSc or I would create an
issue/MR on GitLab.
> > And /usr/share/petsc/Makefile.user or /usr/share/petsc/CMakeLists.txt
> are officially supported ways of using PETSc,
> Those two files are not the "officially supported ways of using PETSc."
> They are examples of how to set up compilations using PETSc.
I do not view these two files as the only officially supported ways of
linking with PETSc. If these files weren't part of PETSc, I wouldn't be
compelled to support them. If that was the case, I would simply delete
the offending lines in the pkg-config file. But these files are example
build definition files provided by PETSc meant to be used in projects
which depend on PETSc. Users of my package may or may not choose to use
them.
> > leaving junk flags in /usr/lib/pkgconfig/petsc.pc is not tolerable
> for me.
> Those are not junk flags, since they are not part of the pkg config standard
> https://people.freedesktop.org/~dbn/pkg-config-guide.html
> <https://people.freedesktop.org/~dbn/pkg-config-guide.html>
By "junk flags" I meant flags that were used when building PETSc for the
petsc package. These flags got put into cflags_extra, which is then used
in user projects thanks to Makefile.user.
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240701/31951de1/attachment-0001.bin>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240701/31951de1/attachment-0001.sig>
