[petsc-users] KSP has an extra iteration when use shell matrix
Yi Hu y.hu at mpie.de
Tue Jan 30 10:19:44 CST 2024
Dear PETSc team,
I am still trying to sort out my previous thread https://lists.mcs.anl.gov/pipermail/petsc-users/2024-January/050079.html using a minimal working example. However, I encountered another problem. Basically I combined the basic usage of SNES solver and shell matrix and tried to make it work. The jacobian of my snes is replaced by a customized MATOP_MULT. The minimal example code can be viewed here https://github.com/hyharry/small_petsc_test/blob/master/test_shell_jac/ex1f.F90
When running with -ksp_monitor -ksp_converged_reason, it shows an extra mymult step, and hence ruin my previous converged KSP result. Implement a customized converged call-back also does not help. I am wondering how to skip this extra ksp iteration. Could anyone help me on this?
Thanks for your help.
Best wishes,
Yi
Stay up to date and follow us on LinkedIn, Twitter and YouTube.
Max-Planck-Institut für Eisenforschung GmbH
Max-Planck-Straße 1
D-40237 Düsseldorf
Handelsregister B 2533
Amtsgericht Düsseldorf
Geschäftsführung
Prof. Dr. Gerhard Dehm
Prof. Dr. Jörg Neugebauer
Prof. Dr. Dierk Raabe
Dr. Kai de Weldige
Ust.-Id.-Nr.: DE 11 93 58 514
Steuernummer: 105 5891 1000
Please consider that invitations and e-mails of our institute are
only valid if they end with …@mpie.de.
If you are not sure of the validity please contact rco at mpie.de
Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240130/27444b5b/attachment.html>
