[petsc-users] SNES seems not use my matrix-free operation
Yi Hu y.hu at mpie.de
Mon Jan 8 11:24:00 CST 2024
Dear PETSc Experts,
I am implementing a matrix-free jacobian for my SNES solver in Fortran. (command line option -snes_type newtonls -ksp_type gmres)
In the main program, I define my residual and jacobian and matrix-free jacobian like the following,
call DMDASNESSetFunctionLocal(DM_mech, INSERT_VALUES, formResidual, PETSC_NULL_SNES, err_PETSc)
call DMSNESSetJacobianLocal(DM_mech, formJacobian, PETSC_NULL_SNES, err_PETSc)
subroutine formJacobian(residual_subdomain,F,Jac_pre,Jac,dummy,err_PETSc)
#include <petsc/finclude/petscmat.h>
  use petscmat
  implicit None
  DMDALocalInfo, dimension(DMDA_LOCAL_INFO_SIZE) :: &
    residual_subdomain        !< DMDA info (needs to be named "in" for macros like XRANGE to work)
  real(pREAL), dimension(3,3,cells(1),cells(2),cells3), intent(in) :: &
    F        !< deformation gradient field
  Mat                                  :: Jac, Jac_pre
  PetscObject                          :: dummy
  PetscErrorCode                       :: err_PETSc
  PetscInt                             :: N_dof ! global number of DoF, maybe only a placeholder
  N_dof = 9*product(cells(1:2))*cells3
  print*, 'in my jac'
  call MatCreateShell(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,N_dof,N_dof,0,Jac,err_PETSc)
  CHKERRQ(err_PETSc)
  call MatShellSetOperation(Jac,MATOP_MULT,GK_op,err_PETSc)
  CHKERRQ(err_PETSc)
  print*, 'in my jac'
  ! for jac preconditioner
  call MatCreateShell(PETSC_COMM_WORLD,PETSC_DECIDE,PETSC_DECIDE,N_dof,N_dof,0,Jac_pre,err_PETSc)
  CHKERRQ(err_PETSc)
  call MatShellSetOperation(Jac_pre,MATOP_MULT,GK_op,err_PETSc)
  CHKERRQ(err_PETSc)
  print*, 'in my jac'
end subroutine formJacobian
subroutine GK_op(Jac,dF,output,err_PETSc)  real(pREAL), dimension(3,3,cells(1),cells(2),cells3), intent(in) :: &    dF        real(pREAL), dimension(3,3,cells(1),cells(2),cells3), intent(out) :: &    output        real(pREAL),  dimension(3,3) :: &    deltaF_aim = 0.0_pREAL   Mat                                  :: Jac  PetscErrorCode                       :: err_PETSc   integer :: i, j, k, e   … a lot of calculations …   print*, 'in GK op'  end subroutine GK_op The first question is that: it seems I still need to explicitly define the interface of MatCreateShell() and MatShellSetOperation() to properly use them, even though I include them via “use petscmat”. It is a little bit strange to me, since some examples do not perform this step.
Then the main issue is that I can build my own Jacobian from my call back function formJacobian, and confirm my Jacobian is a shell matrix (by MatView). However, my customized operator GK_op is not called when solving the nonlinear system (not print my “in GK op”). When I try to monitor my SNES, it gives me some conventional output not mentioning my matrix-free operations. So I guess my customized MATOP_MULT may be not associated with Jacobian. Or my configuration is somehow wrong. Could you help me solve this issue?
Yi
Stay up to date and follow us on LinkedIn, Twitter and YouTube.
Max-Planck-Institut für Eisenforschung GmbH
Max-Planck-Straße 1
D-40237 Düsseldorf
Handelsregister B 2533
Amtsgericht Düsseldorf
Geschäftsführung
Prof. Dr. Gerhard Dehm
Prof. Dr. Jörg Neugebauer
Prof. Dr. Dierk Raabe
Dr. Kai de Weldige
Ust.-Id.-Nr.: DE 11 93 58 514
Steuernummer: 105 5891 1000
Please consider that invitations and e-mails of our institute are
only valid if they end with …@mpie.de.
If you are not sure of the validity please contact rco at mpie.de
Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240108/b3dd41e6/attachment-0001.html>
