[petsc-users] PETSc crashes when different rank sets row, col and A values using MatCreateSeqAIJWithArrays
Barry Smith
bsmith at petsc.dev
Thu Feb 8 08:52:48 CST 2024
No, it uses the exact layout you provided.
You can use https://petsc.org/release/manualpages/PC/PCREDISTRIBUTE/#pcredistribute to have the solver redistribute the rows to have an equal number per MPI process during the solve process, which will give you the effect you are looking for.
Barry
> On Feb 8, 2024, at 4:07 AM, Maruthi NH <maruthinh at gmail.com> wrote:
> Hi Barry,
> Thanks. Yes, the global column index was wrong. I have one more question regarding MatCreateMPIAIJWithArrays. If I have 100 elements in rank 0 and 50 in rank 1, does PETSc redistribute equally among procs before solving?
> Regards,
> Maruthi
> On Mon, Feb 5, 2024 at 2:18 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>> Is each rank trying to create its own sequential matrix with MatCreateSeqAIJWithArrays() or did you mean MatCreateMPIAIJWithArrays()?
>> If the latter, then possibly one of your size arguments is wrong or the indices are incorrect for the given sizes.
>> Barry
>> > On Feb 4, 2024, at 3:15 PM, Maruthi NH <maruthinh at gmail.com <mailto:maruthinh at gmail.com>> wrote:
>> > Hi all,
>> > I have a row, col, and A values in CSR format; let's say rank 0 has 200 unknowns and rank 1 has 100 unknowns. If I use MatCreateSeqAIJWithArrays to create a Matrix, it crashes. However, if each rank has an equal number of unknowns, it works fine. Please let me know how to proceed
>> > Regards,
>> > Maruthi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240208/fd18f44d/attachment.html>
