[petsc-users] KSP has an extra iteration when use shell matrix
Yi Hu
y.hu at mpie.de
Sun Feb 4 15:43:12 CST 2024
Thanks for your response. You are correct. I overlooked this step.
Now I am trying to correct my "shell matrix approach" for ex1f.F90 of
snes solver
(https://github.com/hyharry/small_petsc_test/blob/master/test_shell_jac/ex1f.F90).
I realized that I need to record the base vector X in the context of
shell matrix and then use this info to carry MyMult. However, the
context cannot be obtained through MatShellGetContext(). Here are the
critical parts of my code.
INTERFACE MatCreateShell
SUBROUTINE MatCreateShell(comm,mloc,nloc,m,n,ctx,mat,ierr)
USE solver_context
MPI_Comm :: comm
PetscInt :: mloc,nloc,m,n
Vec :: ctx
Mat :: mat
PetscErrorCode :: ierr
END SUBROUTINE MatCreateShell
END INTERFACE MatCreateShell
INTERFACE MatShellSetContext
SUBROUTINE MatShellSetContext(mat,ctx,ierr)
USE solver_context
Mat :: mat
!TYPE(MatCtx) :: ctx
Vec :: ctx
END SUBROUTINE MatShellSetContext
END INTERFACE MatShellSetContext
INTERFACE MatShellGetContext
SUBROUTINE MatShellGetContext(mat,ctx,ierr)
USE solver_context
Mat :: mat
Vec, Pointer :: ctx
END SUBROUTINE MatShellGetContext
END INTERFACE MatShellGetContext
in my FormShellJacobian() I did
subroutine FormJacobianShell(snes,X,jac,B,dummy,ierr)
call MatShellSetContext(jac,X,ierr)
Then in MyMult() I tried to recover this context by
call MatShellGetContext(J,x,ierr)
call VecView(x,PETSC_VIEWER_STDOUT_WORLD,ierr)
Then the program failed with
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Pointer: Parameter # 1
In MyMult, I actually defined x to be a pointer. So I am confused here.
Best regards,
Yi
On 1/31/24 03:18, Barry Smith wrote:
> It is not running an extra KSP iteration. This "extra" matmult is
> normal and occurs in many of the SNESLineSearchApply_* functions, for
> example,
> https://petsc.org/release/src/snes/linesearch/impls/bt/linesearchbt.c.html#SNESLineSearchApply_BT It
> is used to decide if the Newton step results in sufficient decrease of
> the function value.
> Barry
>> On Jan 30, 2024, at 3:19 PM, Yi Hu <y.hu at mpie.de> wrote:
>> Hello Barry,
>> Thanks for your reply. The monitor options are fine. I actually meant
>> my modification of snes tutorial ex1f.F90 does not work and has some
>> unexpected behavior. I basically wanted to test if I can use a shell
>> matrix as my jacobian (code is here
>> After compile my modified version and run with these monitor options,
>> it gives me the following,
>> ( in rhs )
>> ( leave rhs )
>> 0 SNES Function norm 6.041522986797e+00
>> ++++++++++++ in jac shell +++++++++++
>> 0 KSP Residual norm 6.041522986797e+00
>> === start mymult ===
>> === done mymult ===
>> 1 KSP Residual norm 5.065392549852e-16
>> Linear solve converged due to CONVERGED_RTOL iterations 1
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> 1 SNES Function norm 3.512662245652e+00
>> 0 KSP Residual norm 3.512662245652e+00
>> === done mymult ===
>> 1 KSP Residual norm 6.230314124713e-16
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> 2 SNES Function norm 8.969285922373e-01
>> 0 KSP Residual norm 8.969285922373e-01
>> === done mymult ===
>> 1 KSP Residual norm 0.000000000000e+00
>> Linear solve converged due to CONVERGED_ATOL iterations 1
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> 3 SNES Function norm 4.863816734540e-01
>> 0 KSP Residual norm 4.863816734540e-01
>> === done mymult ===
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> 4 SNES Function norm 3.512070785520e-01
>> 0 KSP Residual norm 3.512070785520e-01
>> === done mymult ===
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> 5 SNES Function norm 2.769700293115e-01
>> 0 KSP Residual norm 2.769700293115e-01
>> === done mymult ===
>> 1 KSP Residual norm 1.104778916974e-16
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> 6 SNES Function norm 2.055345318150e-01
>> 0 KSP Residual norm 2.055345318150e-01
>> === done mymult ===
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> 7 SNES Function norm 1.267482220786e-01
>> 0 KSP Residual norm 1.267482220786e-01
>> === done mymult ===
>> 1 KSP Residual norm 1.498679601680e-17
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> 8 SNES Function norm 3.468150619264e-02
>> 0 KSP Residual norm 3.468150619264e-02
>> === done mymult ===
>> 1 KSP Residual norm 5.944160522951e-18
>> === done mymult ===
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> ( in rhs )
>> ( leave rhs )
>> === done mymult ===
>> Nonlinear solve did not converge due to DIVERGED_LINE_SEARCH iterations 8
>> Number of SNES iterations = 8
>> After each "Linear solve converged due to CONVERGED_ATOL iterations",
>> the code starts to do mymult again. So I thought it did an extra
>> (unwanted) KSP iteration. I would like to ask if this extra iteration
>> could be disabled, or maybe I am wrong about it.
>> Best regards,
>> Yi
>> On 1/30/24 18:35, Barry Smith wrote:
>>> How do I see a difference? What does "hence ruin my previous
>>> converged KSP result" mean? A different answer at the end of the KSP
>>> solve?
>>> $ ./joe > joe.basic
>>> ~/Src/petsc/src/ksp/ksp/tutorials*(barry/2023-09-15/fix-log-pcmpi=)*arch-fix-log-pcmpi
>>> $ ./joe -ksp_monitor -ksp_converged_reason -snes_monitor > joe.monitor
>>> $ diff joe.basic joe.monitor
>>> 0a1,36
>>> > Linear solve converged due to CONVERGED_RTOL_NORMAL iterations 1
>>> > 1 KSP Residual norm 1.535110861002e-17
>>>> On Jan 30, 2024, at 11:19 AM, Yi Hu <y.hu at mpie.de> wrote:
>>>> Dear PETSc team,
>>>> I am still trying to sort out my previous
>>>> threadhttps://lists.mcs.anl.gov/pipermail/petsc-users/2024-January/050079.htmlusing
>>>> a minimal working example. However, I encountered another problem.
>>>> Basically I combined the basic usage of SNES solver and shell
>>>> matrix and tried to make it work. The jacobian of my snes is
>>>> replaced by a customized MATOP_MULT. The minimal example code can
>>>> be viewed
>>>> herehttps://github.com/hyharry/small_petsc_test/blob/master/test_shell_jac/ex1f.F90
>>>> When running with -ksp_monitor -ksp_converged_reason, it shows an
>>>> extra mymult step, and hence ruin my previous converged KSP result.
>>>> Implement a customized converged call-back also does not help. I am
>>>> wondering how to skip this extra ksp iteration. Could anyone help
>>>> me on this?
>>>> Thanks for your help.
>>>> Best wishes,
>>>> Yi
>>>> Stay up to date and follow us on LinkedIn, Twitter and YouTube.
>>>> Max-Planck-Institut für Eisenforschung GmbH
>>>> Max-Planck-Straße 1
>>>> D-40237 Düsseldorf
>>>> Handelsregister B 2533
>>>> Amtsgericht Düsseldorf
>>>> Geschäftsführung
>>>> Prof. Dr. Gerhard Dehm
>>>> Prof. Dr. Jörg Neugebauer
>>>> Prof. Dr. Dierk Raabe
>>>> Dr. Kai de Weldige
>>>> Ust.-Id.-Nr.: DE 11 93 58 514
>>>> Steuernummer: 105 5891 1000
>>>> Please consider that invitations and e-mails of our institute are
>>>> only valid if they end with …@mpie.de.
>>>> If you are not sure of the validity please contact rco at mpie.de
>>>> Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
>>>> aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
>>>> In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
>> Max-Planck-Straße 1
>> D-40237 Düsseldorf
>> Geschäftsführung
>> Dr. Kai de Weldige
Max-Planck-Straße 1
D-40237 Düsseldorf
Geschäftsführung
Dr. Kai de Weldige
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240204/d4ff5332/attachment-0001.html>
