[petsc-users] Bound exceed when running code with PETSc
Mon Feb 5 07:50:25 CST 2024
On Mon, Feb 5, 2024 at 8:48 AM TAY Wee Beng <zonexo at gmail.com> wrote:
> Hi all,
> Not in my code, nor in PETSc.
I would try this. Of course, it would be best to see where exactly the
overflow is happening.
   THanks,
     Matt
> On 5/2/2024 8:21 pm, Matthew Knepley wrote:
> On Mon, Feb 5, 2024 at 4:29 AM TAY Wee Beng <zonexo at gmail.com> wrote:
>> Hi,
>> I have a code which uses PETSc and it was working fine. However, I
>> haven't used the code for a while and now we've migrated to a new cray
>> cluster so the compilers have been updated. I'm using gnu fortran.
>> When running the code now, I got the error:
>> Error termination. Backtrace:
>> At line 294 of file
>> /home/users/nus/tsltaywb/myprojects/ibm2d_high_Re_staggered_coef/PETSc_solvers.F90
>> Fortran runtime error: Index '-17591876251192' of dimension 1 of array
>> 'ppv' below lower bound of 1
>> I have attached my makefile. Wonder what I should change to prevent the
>> above error.
> This looks like an integer overflow error. DId you configure with 64-bit
> ints?
>    Thanks,
>       Matt
>> Compiler should be v11.2
>> Thank you very much.
>> Yours sincerely,
>> TAY Wee-Beng 郑伟明 (Zheng Weiming)
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> Yours sincerely,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240205/44d169ae/attachment-0001.html>
