[petsc-users] Bound exceed when running code with PETSc
TAY Wee Beng zonexo at gmail.com
Mon Feb 5 07:48:36 CST 2024
Hi all,
Not in my code, nor in PETSc.
On 5/2/2024 8:21 pm, Matthew Knepley wrote:
> On Mon, Feb 5, 2024 at 4:29 AM TAY Wee Beng <zonexo at gmail.com> wrote:
>     Hi,
>     I have a code which uses PETSc and it was working fine. However, I
>     haven't used the code for a while and now we've migrated to a new
>     cray
>     cluster so the compilers have been updated. I'm using gnu fortran.
>     When running the code now, I got the error:
>     Error termination. Backtrace:
>     At line 294 of file
>     /home/users/nus/tsltaywb/myprojects/ibm2d_high_Re_staggered_coef/PETSc_solvers.F90
>     Fortran runtime error: Index '-17591876251192' of dimension 1 of
>     array
>     'ppv' below lower bound of 1
>     I have attached my makefile. Wonder what I should change to
>     prevent the
>     above error.
> This looks like an integer overflow error. DId you configure with
> 64-bit ints?
>    Thanks,
>       Matt
>     Compiler should be v11.2
>     Thank you very much.
>     Yours sincerely,
>     TAY Wee-Beng 郑伟明 (Zheng Weiming)
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Yours sincerely,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240205/3723ab40/attachment.html>
