[petsc-users] PetscSection: Fortran interfaces
Martin Diehl
martin.diehl at kuleuven.be
Sat Feb 3 11:09:33 CST 2024
thanks for the quick reply
I think my question was not clear enough:
With "interfaces" I ment the Fortran module files that ensure correct
calling signatures.
In the example (ex26f90), I can replace "ierr" of PetscSectionGetDof
with anything without getting complaints from the compiler. This does
not work for other functions, e.g. "ISRestoreIndicesF90" in line 272.
Martin
On Sat, 2024-02-03 at 11:51 -0500, Matthew Knepley wrote:
> Can you give us a simple code that is not working for you? My test
> should work
> src/dm/impls/plex/tests/ex26f90
> Thanks,
> Matt
> On Sat, Feb 3, 2024 at 11:36 AM Barry Smith <bsmith at petsc.dev> wrote:
> > The Fortran "stubs" (subroutines) should be in
> > $PETSC_ARCH/src/vec/is/section/interface/ftn-auto/sectionf.c and
> > compiled and linked into the PETSc library.
> > The same tool that builds the interfaces in
> > $PETSC_ARCH/src/vec/f90-mod/ftn-auto-
> > interfaces/petscpetscsection.h90, also builds the stubs so it is
> > surprising one would exist but not the other.
> > Barry
> > > On Feb 3, 2024, at 11:27 AM, Martin Diehl
> > > <martin.diehl at kuleuven.be> wrote:
> > > Dear PETSc team,
> > > I currently can't make use of Fortran interfaces for "section".
> > > In particular, I can't see how to use
> > > PetscSectionGetFieldComponents
> > > PetscSectionGetFieldDof
> > > PetscSectionGetFieldOffset
> > > The interfaces for them are created in $PETSC_ARCH/src/vec/f90-
> > > mod/ftn-
> > > auto-interfaces/petscpetscsection.h90, but it seems that they are
> > > not
> > > exposed to the public.
> > > Could you give me a hint how to use them or fix this?
> > > with best regards,
> > > Martin
> > > KU Leuven
> > > Department of Computer Science
> > > Department of Materials Engineering
> > > Celestijnenlaan 200a
> > > 3001 Leuven, Belgium
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
KU Leuven
Desc: This is a digitally signed message part
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240203/b4e95944/attachment.sig>
