[petsc-users] PetscSection: Fortran interfaces
Matthew Knepley
knepley at gmail.com
Sat Feb 3 10:51:27 CST 2024
Can you give us a simple code that is not working for you? My test should
work
src/dm/impls/plex/tests/ex26f90
Matt
On Sat, Feb 3, 2024 at 11:36 AM Barry Smith <bsmith at petsc.dev> wrote:
> The Fortran "stubs" (subroutines) should be in
> $PETSC_ARCH/src/vec/is/section/interface/ftn-auto/sectionf.c and compiled
> and linked into the PETSc library.
> The same tool that builds the interfaces in
> $PETSC_ARCH/src/vec/f90-mod/ftn-auto-interfaces/petscpetscsection.h90,
> also builds the stubs so it is surprising one would exist but not the other.
> Barry
> > On Feb 3, 2024, at 11:27 AM, Martin Diehl <martin.diehl at kuleuven.be>
> wrote:
> > Dear PETSc team,
> > I currently can't make use of Fortran interfaces for "section".
> > In particular, I can't see how to use
> > PetscSectionGetFieldComponents
> > PetscSectionGetFieldDof
> > PetscSectionGetFieldOffset
> > The interfaces for them are created in $PETSC_ARCH/src/vec/f90-mod/ftn-
> > auto-interfaces/petscpetscsection.h90, but it seems that they are not
> > exposed to the public.
> > Could you give me a hint how to use them or fix this?
> > with best regards,
> > Martin
> > KU Leuven
> > Department of Computer Science
> > Department of Materials Engineering
> > Celestijnenlaan 200a
> > 3001 Leuven, Belgium
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240203/8d64f549/attachment-0001.html>
