[petsc-users] PETSC configuration on linux with intel MKL
Bruno Ramon Batista Fernande brbfernandes at utexas.edu
Sun Dec 29 14:09:05 CST 2024
Hi Pierre,
I tried it and got the same error message. Still, no configure.log was
generated. It seems like it doesn't even start the configuration.
Best regards,
Bruno
On Sun, Dec 29, 2024 at 1:45 PM Pierre Jolivet <pierre at joliv.et> wrote:
> On 30 Dec 2024, at 2:24 AM, Bruno Ramon Batista Fernande <
> brbfernandes at utexas.edu> wrote:
> Hi Satish,
> Thank you for your prompt response.
> It seems like it doesn't reach the point of writing the configure.log for
> this issue.
> The command used is below. I am using mpich and oneAPI both installed from
> apt from Ubuntu.
> ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
> --with-debugging=0 --download-hypre
> --with-blaslapack-libs=["/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_blas95_lp64.a",
> "/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_lapack95_lp64.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_gf_lp64.a",
> "/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_sequential.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_core.a"]
> --with-scalapack-libs=["/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_scalapack_lp64.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_blacs_lp64.a"]
> --with-scalapack-include=/opt/intel/oneapi/mkl/2025.0/include
> It’s not -libs=, it’s -lib=, and there is no need for quotation marks.
> Try again, and if it still does not work, please send configure.log, there
> is no reason for it not being generated.
> Thanks,
> Pierre
> Best regards,
> Bruno
> On Sun, Dec 29, 2024 at 8:15 AM Satish Balay <balay.anl at fastmail.org>
> wrote:
>> Hm - what was the configure command [with options] used here? Can you
>> send corresponding configure.log?
>> Satish
>> On Sat, 28 Dec 2024, Bruno Ramon Batista Fernande wrote:
>> > Hi,
>> > I am trying to use the oneAPI MKL 2025 into my PETSC configuration on
>> > Linux. However, I get the following error as I enter the names of the
>> mkl
>> > libraries:
>> >                         ERROR in COMMAND LINE ARGUMENT to ./configure
>> >   The option
>> /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_lapack95_lp64.a,/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_gf_lp64.a,
>> >   should probably be
>> /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl-lapack95-lp64.a,/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl-gf-lp64.a,
>> > As you can see, the configure suggest to use libraries with hyphen in
>> their
>> > names but the original libraries have underscores in it. Any way to
>> bypass
>> > this issue without creating links or creating copies of files?
>> > Best regards,
>> > Bruno
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241229/4f7aeca4/attachment-0001.html>
