[petsc-users] PETSC configuration on linux with intel MKL
Pierre Jolivet
pierre at joliv.et
Sun Dec 29 13:44:58 CST 2024
> On 30 Dec 2024, at 2:24 AM, Bruno Ramon Batista Fernande <brbfernandes at utexas.edu> wrote:
> Hi Satish,
> Thank you for your prompt response.
> It seems like it doesn't reach the point of writing the configure.log for this issue.
> The command used is below. I am using mpich and oneAPI both installed from apt from Ubuntu.
> ./configure --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --with-debugging=0 --download-hypre --with-blaslapack-libs=["/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_blas95_lp64.a", "/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_lapack95_lp64.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_gf_lp64.a", "/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_sequential.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_core.a"] --with-scalapack-libs=["/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_scalapack_lp64.a","/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_blacs_lp64.a"] --with-scalapack-include=/opt/intel/oneapi/mkl/2025.0/include
It’s not -libs=, it’s -lib=, and there is no need for quotation marks.
Try again, and if it still does not work, please send configure.log, there is no reason for it not being generated.
Pierre
> Best regards,
> Bruno
> On Sun, Dec 29, 2024 at 8:15 AM Satish Balay <balay.anl at fastmail.org <mailto:balay.anl at fastmail.org>> wrote:
>> Hm - what was the configure command [with options] used here? Can you send corresponding configure.log?
>> Satish
>> On Sat, 28 Dec 2024, Bruno Ramon Batista Fernande wrote:
>> > Hi,
>> > I am trying to use the oneAPI MKL 2025 into my PETSC configuration on
>> > Linux. However, I get the following error as I enter the names of the mkl
>> > libraries:
>> > ERROR in COMMAND LINE ARGUMENT to ./configure
>> > The option
>> > /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_lapack95_lp64.a,/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl_gf_lp64.a,
>> > should probably be
>> > /opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl-lapack95-lp64.a,/opt/intel/oneapi/mkl/2025.0/lib/intel64/libmkl-gf-lp64.a,
>> > As you can see, the configure suggest to use libraries with hyphen in their
>> > names but the original libraries have underscores in it. Any way to bypass
>> > this issue without creating links or creating copies of files?
>> > Best regards,
>> > Bruno
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241229/aaa2c726/attachment.html>
