[petsc-users] Issue configuring PETSc with HYPRE in Polaris
Matthew Knepley
knepley at gmail.com
Fri Aug 9 15:12:20 CDT 2024
As a start, please send configure.log
Matt
On Fri, Aug 9, 2024 at 1:17 PM Vanella, Marcos (Fed) via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi All, I keep running into this issue when trying to configure PETSc
> downloading HYPRE in Polaris.
> My modules are:
> export *MPICH_GPU_SUPPORT_ENABLED*=1
> module use /soft/modulefiles
> module load spack-pe-base cmake
> module unload darshan
> module load cudatoolkit-standalone PrgEnv-gnu cray-libsci
> and my configure line is:
> $./configure COPTFLAGS="-O2" CXXOPTFLAGS="-O2" FOPTFLAGS="-O2"
> FCOPTFLAGS="-O2" CUDAOPTFLAGS="-O2" --with-debugging=1
> --download-suitesparse --download-hypre --with-cuda --with-cc=cc
> --with-cxx=CC --with-fc=ftn --with-cudac=nvcc --with-cuda-arch=80
> What I see in the configure phase is:
> Configuring PETSc to compile on your system
> Trying to download https://urldefense.us/v3/__https://bitbucket.org/petsc/pkg-sowing.git__;!!G_uCfscf7eWS!bC2nF0niuYrmvBqOKJhC2c7ynXepezhMCen7e9RqnIO_bj8qEvum1TAPesC1XjzU0AEgkVpR4B20xSeFpvUg$
> <https://urldefense.us/v3/__https://bitbucket.org/petsc/pkg-sowing.git__;!!G_uCfscf7eWS!cmVCEe9Yo9XY7yJT97YkbQmjoCgOuxhiJ2FQxtDUKX1EeWJlKWt0pLawxoHeUS0ZDgSfwCHAoJNUjc5uQW3gQdHH9OXszklO$>
> for SOWING
> Running configure on SOWING; this may take several
> minutes
> Running make on SOWING; this may take several minutes
> Running make install on SOWING; this may take several
> minutes
> Running arch-polaris-dbg/bin/bfort to generate Fortran
> stubs
> Trying to download https://urldefense.us/v3/__https://github.com/DrTimothyAldenDavis/SuiteSparse__;!!G_uCfscf7eWS!bC2nF0niuYrmvBqOKJhC2c7ynXepezhMCen7e9RqnIO_bj8qEvum1TAPesC1XjzU0AEgkVpR4B20xQ43P-ld$
> <https://urldefense.us/v3/__https://github.com/DrTimothyAldenDavis/SuiteSparse__;!!G_uCfscf7eWS!cmVCEe9Yo9XY7yJT97YkbQmjoCgOuxhiJ2FQxtDUKX1EeWJlKWt0pLawxoHeUS0ZDgSfwCHAoJNUjc5uQW3gQdHH9Ho5-hpl$>
> for SUITESPARSE
> Configuring SUITESPARSE with CMake; this may take several
> minutes
> Compiling and installing SUITESPARSE; this may take several
> minutes
> Trying to download https://urldefense.us/v3/__https://github.com/hypre-space/hypre__;!!G_uCfscf7eWS!bC2nF0niuYrmvBqOKJhC2c7ynXepezhMCen7e9RqnIO_bj8qEvum1TAPesC1XjzU0AEgkVpR4B20xeK92H5d$
> <https://urldefense.us/v3/__https://github.com/hypre-space/hypre__;!!G_uCfscf7eWS!cmVCEe9Yo9XY7yJT97YkbQmjoCgOuxhiJ2FQxtDUKX1EeWJlKWt0pLawxoHeUS0ZDgSfwCHAoJNUjc5uQW3gQdHH9JxTYrQ0$>
> for HYPRE
> Running configure on HYPRE; this may take several minutes
> Running make on HYPRE; this may take several minutes
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> Error running make; make install on HYPRE
> the configure.log file ends with:
> details):
> File "/home/mnv/Software/petsc/config/configure.py", line 462, in
> petsc_configure
> framework.configure(out = sys.stdout)
> File "/home/mnv/Software/petsc/config/BuildSystem/config/framework.py",
> line 1455, in configure
> self.processChildren()
> line 1443, in processChildren
> self.serialEvaluation(self.childGraph)
> line 1418, in serialEvaluation
> child.configure()
> File "/home/mnv/Software/petsc/config/BuildSystem/config/package.py",
> line 1354, in configure
> self.executeTest(self.configureLibrary)
> File "/home/mnv/Software/petsc/config/BuildSystem/config/base.py", line
> 138, in executeTest
> ret = test(*args,**kargs)
> File
> "/home/mnv/Software/petsc/config/BuildSystem/config/packages/hypre.py",
> line 199, in configureLibrary
> config.package.Package.configureLibrary(self)
> line 1041, in configureLibrary
> for location, directory, lib, incl in self.generateGuesses():
> line 609, in generateGuesses
> d = self.checkDownload()
> line 743, in checkDownload
> return self.getInstallDir()
> line 545, in getInstallDir
> installDir = self.Install()
> line 1892, in Install
> raise RuntimeError('Error running make; make install on '+self.PACKAGE)
> Finishing configure run at Fri, 09 Aug 2024 15:44:54 +0000
> Any help in debugging this is much appreciated. I can provide the whole
> configure.log file if needed.
> Thank you for your time,
> Marcos
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bC2nF0niuYrmvBqOKJhC2c7ynXepezhMCen7e9RqnIO_bj8qEvum1TAPesC1XjzU0AEgkVpR4B20xdqmkbnf$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!bC2nF0niuYrmvBqOKJhC2c7ynXepezhMCen7e9RqnIO_bj8qEvum1TAPesC1XjzU0AEgkVpR4B20xZJqvPeJ$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240809/9e29005e/attachment-0001.html>
