[petsc-users] Read/Write large dense matrix
    Sreeram R Venkat
    srvenkat at utexas.edu
    Mon Aug  5 12:26:45 CDT 2024
I do have 64 bit indices turned on. The problem I think is that the
PetscMPIInt is always a 32 bit int, and that's what's overflowing
On Mon, Aug 5, 2024 at 12:25 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Aug 5, 2024 at 1:10 PM Sreeram R Venkat <srvenkat at utexas.edu>
> wrote:
>> I have a large dense matrix (size ranging from 5e4 to 1e5) that arises as
>> a result of doing MatComputeOperator() on a MatShell. When the total number
>> of nonzeros exceeds the 32 bit integer value, I get an error (MPI buffer
>> size too big) when
>> ZjQcmQRYFpfptBannerStart
>> This Message Is From an External Sender
>> This message came from outside your organization.
>> ZjQcmQRYFpfptBannerEnd
>> size too big) when trying to do MatView() on this to save to binary. Is
>> there a way I can save this matrix to load again for later use?
> I think you need to reconfigure with --with-64-bit-indices.
>   Thanks,
>      Matt
>> The other thing I tried was to save each column as a separate dataset in
>> an hdf5 file. Then, I tried to load this in python, combine them to an np
>> array, and then create/save a dense matrix with petsc4py. I was able to
>> create the dense Mat, but the MatView() once again resulted in an error
>> (out of memory).
>> Thanks,
>> Sreeram
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YEWGX-ox3ARoPA3Pbscem_Hb7EN32OeIgge1kzxkTWE7WIoLiKNb_-TCX9RvQvrJDbraBDj_vhi63DtOgAjbEhbzEA$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YEWGX-ox3ARoPA3Pbscem_Hb7EN32OeIgge1kzxkTWE7WIoLiKNb_-TCX9RvQvrJDbraBDj_vhi63DtOgAg4dLZUNg$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240805/60c42c9c/attachment-0001.html>
