[petsc-users] ex19: Segmentation Violation when run with MUMPS on MacOS (arm64)
Zongze Yang
yangzongze at gmail.com
Tue Apr 2 01:10:19 CDT 2024
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240402/99f4bea4/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240402/99f4bea4/attachment-0001.gz>
> On 2 Apr 2024, at 04:14, Satish Balay <balay at mcs.anl.gov> wrote:
> On Mon, 1 Apr 2024, Zongze Yang wrote:
>> Thank you for your update.
>> I found some links that suggest this issue is related to the Apple linker, which is causing problems with Fortran linking.
>> 1. https://urldefense.us/v3/__https://github.com/open-mpi/ompi/issues/12427__;!!G_uCfscf7eWS!bHY4uqpTfwl0jKopATQs3gw--TZSBmDp0Lb1gzDBeEu4ZB_zTph-jfw49yIr3jvPx0YEhQbk1PjYbGYVpjjms6Wb$
>> 2. https://urldefense.us/v3/__https://x.com/science_dot/status/1768667417553547635?s=46__;!!G_uCfscf7eWS!bHY4uqpTfwl0jKopATQs3gw--TZSBmDp0Lb1gzDBeEu4ZB_zTph-jfw49yIr3jvPx0YEhQbk1PjYbGYVptASYXS2$
> https://urldefense.us/v3/__https://github.com/Homebrew/homebrew-core/issues/162714__;!!G_uCfscf7eWS!eGiVH2meEkLSEHvkY6Y-m7U1wPG4ZDxHod7lLZI3HTu6itzNEDm7n3cz4GNly925EEHvVRnyNQYn2aAt0Z1p53tZ$ recommends "downgrade CLT (or xcode?) to 15.1"
> Satish
