[petsc-users] ex19: Segmentation Violation when run with MUMPS on MacOS (arm64)
Mon Apr 1 15:14:56 CDT 2024
On Mon, 1 Apr 2024, Zongze Yang wrote:
> Thank you for your update.
> I found some links that suggest this issue is related to the Apple linker, which is causing problems with Fortran linking.
> 1. https://urldefense.us/v3/__https://github.com/open-mpi/ompi/issues/12427__;!!G_uCfscf7eWS!bHY4uqpTfwl0jKopATQs3gw--TZSBmDp0Lb1gzDBeEu4ZB_zTph-jfw49yIr3jvPx0YEhQbk1PjYbGYVpjjms6Wb$
> 2. https://urldefense.us/v3/__https://x.com/science_dot/status/1768667417553547635?s=46__;!!G_uCfscf7eWS!bHY4uqpTfwl0jKopATQs3gw--TZSBmDp0Lb1gzDBeEu4ZB_zTph-jfw49yIr3jvPx0YEhQbk1PjYbGYVptASYXS2$
https://urldefense.us/v3/__https://github.com/Homebrew/homebrew-core/issues/162714__;!!G_uCfscf7eWS!chekWa3R3JhHB1MVv33Oqj9fPFhbnx9sm7cm7Lk5-n7PHicsVkY0n7XoSkWmk259VLNjTzEus6xBpRL20MmLo1g$  recommends "downgrade CLT (or xcode?) to 15.1"
Satish
