[petsc-users] [petsc-maint] DMSwarm on multiple processors
Joauma Marichal joauma.marichal at uclouvain.be
Thu Oct 26 09:35:37 CDT 2023
Hello,
Here is a very simple version where I have issues.
Which I run as follows:
cd Grid_generation
make clean
make all
./grid_generation
cd ..
make clean
make all
./cobpor # on 1 proc
# OR
mpiexec ./cobpor -ksp_type cg -pc_type pfmg -dm_mat_type hyprestruct -pc_pfmg_skip_relax 1 -pc_pfmg_rap_time non-Galerkin # on multiple procs
The error that I get is the following:
munmap_chunk(): invalid pointer
[cns266:2552391] *** Process received signal ***
[cns266:2552391] Signal: Aborted (6)
[cns266:2552391] Signal code:  (-6)
[cns266:2552391] [ 0] /lib64/libc.so.6(+0x4eb20)[0x7fd7fd194b20]
[cns266:2552391] [ 1] /lib64/libc.so.6(gsignal+0x10f)[0x7fd7fd194a9f]
[cns266:2552391] [ 2] /lib64/libc.so.6(abort+0x127)[0x7fd7fd167e05]
[cns266:2552391] [ 3] /lib64/libc.so.6(+0x91037)[0x7fd7fd1d7037]
[cns266:2552391] [ 4] /lib64/libc.so.6(+0x9819c)[0x7fd7fd1de19c]
[cns266:2552391] [ 5] /lib64/libc.so.6(+0x9844c)[0x7fd7fd1de44c]
[cns266:2552391] [ 6] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscFreeAlign+0xe)[0x7fd7fe63d50e]
[cns266:2552391] [ 7] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetMatType+0x3d)[0x7fd7feab87ad]
[cns266:2552391] [ 8] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetFromOptions+0x109)[0x7fd7feab8b59]
[cns266:2552391] [ 9] ./cobpor[0x402df9]
[cns266:2552391] [10] /lib64/libc.so.6(__libc_start_main+0xf3)[0x7fd7fd180cf3]
[cns266:2552391] [11] ./cobpor[0x40304e]
[cns266:2552391] *** End of error message ***
Thanks a lot for your help.
Best regards,
Joauma
De : Matthew Knepley <knepley at gmail.com>
Date : mercredi, 25 octobre 2023 à 14:45
À : Joauma Marichal <joauma.marichal at uclouvain.be>
Cc : petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-maint] DMSwarm on multiple processors
On Wed, Oct 25, 2023 at 8:32 AM Joauma Marichal via petsc-maint <petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>> wrote:
Hello,
I am using the DMSwarm library in some Eulerian-Lagrangian approach to have vapor bubbles in water.
I have obtained nice results recently and wanted to perform bigger simulations. Unfortunately, when I increase the number of processors used to run the simulation, I get the following error:
free(): invalid size
[cns136:590327] *** Process received signal ***
[cns136:590327] Signal: Aborted (6)
[cns136:590327] Signal code:  (-6)
[cns136:590327] [ 0] /lib64/libc.so.6(+0x4eb20)[0x7f56cd4c9b20]
[cns136:590327] [ 1] /lib64/libc.so.6(gsignal+0x10f)[0x7f56cd4c9a9f]
[cns136:590327] [ 2] /lib64/libc.so.6(abort+0x127)[0x7f56cd49ce05]
[cns136:590327] [ 3] /lib64/libc.so.6(+0x91037)[0x7f56cd50c037]
[cns136:590327] [ 4] /lib64/libc.so.6(+0x9819c)[0x7f56cd51319c]
[cns136:590327] [ 5] /lib64/libc.so.6(+0x99aac)[0x7f56cd514aac]
[cns136:590327] [ 6] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscSFSetUpRanks+0x4c4)[0x7f56cea71e64]
[cns136:590327] [ 7] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(+0x841642)[0x7f56cea83642]
[cns136:590327] [ 8] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(PetscSFSetUp+0x9e)[0x7f56cea7043e]
[cns136:590327] [ 9] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(VecScatterCreate+0x164e)[0x7f56cea7bbde]
[cns136:590327] [10] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp_DA_3D+0x3e38)[0x7f56cee84dd8]
[cns136:590327] [11] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp_DA+0xd8)[0x7f56cee9b448]
[cns136:590327] [12] /gpfs/home/acad/ucl-tfl/marichaj/marha/lib_petsc/lib/libpetsc.so.3.019(DMSetUp+0x20)[0x7f56cededa20]
[cns136:590327] [13] ./cobpor[0x4418dc]
[cns136:590327] [14] ./cobpor[0x408b63]
[cns136:590327] [15] /lib64/libc.so.6(__libc_start_main+0xf3)[0x7f56cd4b5cf3]
[cns136:590327] [16] ./cobpor[0x40bdee]
[cns136:590327] *** End of error message ***
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpiexec noticed that process rank 84 with PID 590327 on node cns136 exited on signal 6 (Aborted).
When I reduce the number of processors the error disappears and when I run my code without the vapor bubbles it also works.
The problem seems to take place at this moment:
DMCreate(PETSC_COMM_WORLD,swarm);
    DMSetType(*swarm,DMSWARM);
    DMSetDimension(*swarm,3);
    DMSwarmSetType(*swarm,DMSWARM_PIC);
    DMSwarmSetCellDM(*swarm,*dmcell);
Things that would help us track this down:
1) The smallest example where it fails
2) The smallest number of processes where it fails
3) A stack trace of the failure
4) A simple example that we can run that also fails
     Matt
Best regards,
Joauma
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231026/86d305fe/attachment-0001.html>
